The F60 was called the N60 in some parts of the world. You may download the N60 manual from http://butkus.org/chinon/nikon/nikon_n60/nikon_n60.htm
SOURCE: Putting film into nikon f60
It is fairly simple. Insert the film canister with the hole side (not the projection) down. Insert the spool of the camera into this hole and slide the canister inside the chamber. Now pull the film out slightly so that the leader (the narrow portion at the end of the film) aligns with the orange mark at the lower right end of the film chamber. Make sure there is no slack in the film. Close the door and turn on the camera.
SOURCE: Problem with loading film in my Nikon F60.
Draw the film all the way to the receiving spool. There's an 'eye' inside the film compartment to check that the film is loaded. When the film is not correctly loaded the camera thinks it's empty and rewinds the film.
SOURCE: Hi I have a Nikon F60 35mm camera purchased second
http://safemanuals.com/annexe_INSTRUCTION%20MANUAL_NIKON_F60-_E.htm
Took the liberty o testing the download- a pop up comes askin you to rate the camera- just pop all the stars to where ever that unlocks the download button- definately works.
If that dont work or you dont trust the site i can always just email you it
