Question about Dryers
Belt and cannot get back panel off dryer
I heard a noise last night, dryer would keep running, but drum inside was still. I have been having squeaking nosies for about a month and let it go. I think it is the belt, but I do not know how to get the back off the dryer. I unscrewed all the screws but cannot seem to see how to get back off. Single Mom, Need help. Thank you
  • 43 Answers
What brand?
Posted on Apr 25, 2009
While cleaning the inside drum and turned the drum by hand. She heard a "loud noise" and will not turn. The control panel will come on andselect the mode, but when start is pushed nothing happens.
When you rotated to drum you caused to belt to pop off the pulley .it has a safety switch so it won't run if belt breaks . With unit unplugged remove top than control panel than front panel to access bottom to put belt back on just enough room for hands to fix inside
Mar 26, 2016 | Samsung DV218AEW Electric Dryer
Dryer hums but will not start
bad motor,if it does start and runs then shuts down and you can't restart it until it cools down you have a bad motor,or open the door and see if you can spin the drum,i found a dryer that the belt cut through the pastic belt pulley and the motor couldn't turn,also something could be stuck inthe blower wheel but if you can spin the drum then it's the motor.the noise you heard is either a bad roller,the belt pulley or the motor bearing.next time send the model number and i can look up you dryer to see what parts are in it.hope this helps.
Dec 29, 2013 | Maytag Dryers
I used the dryer last night with no issue. When I went to use it this morning, I pressed the start button, I heard the motor run, but the drun did not move. After a second, the motor stopped trying. ...
i would say the belt that turns drum is broke,slipping or jumped off motor.try running without clothes in it.if drum dosent turn belt is broke or off
Oct 22, 2013 | Electrolux EIED55H Dryer
Samsung front load dryer will turn on but not spinning or drying. I was wiping it out and turning the drum I heard a snap sound.
I was cleaning mine and doing the same thing last night. Washed a load of clothes tonight and went to dry them and everything works on it except it won't spin or heat. Heard the same type of popping noise last night cleaning it out. Have you found any solutions? Mine is just over a year old. I did some reading and thing that the dryer belt came off its assembly possibly. Have you found a solution?
Jan 10, 2011 | Samsung Dryers
Heard a thumping noise everytime we turned dryer on...lasted a week or so.....drying a blanket last night cycle stopped half way thru.....still getting hot, just not turning. Thinking this is some type of...
The thumping noise comes when the drum is rubbing against the body surface. This could be due to the suspenders/support which is holding the drier drum are not steadfast. May be one has given the way. To know exactly if it is the belt or the coupling with motor or the support for drum , you have to open the back cover which you can do it by removing the screws at the back and then inspecting the machine.
Nov 02, 2010 | Frigidaire Electric Dryer
Kenmore electric dryer making loud noise when running
It sounds like the belt that goes around the drum. I have a similar Kenmore, and I get that same rotational thumping noise. The belt is probably about to break or come apart. If you take it off and run it trough your hands, I think that you'll find either belt separation, or a bad spot missing a chunk.
Fortunately the belt is a cheap item. I've kept my Kenmore dryer running over 20 years now.
Mar 18, 2017 | Kenmore Dryers
Dryer is scraping as it turns. Is there a belt that is worn? Started doing it after 3rd load. Did the same last time we used it.
The dryer drum is suspended between the front panel and the back panel by extrusions that protrude into the front and rear of the drum. There are thick felt pads attached to the protrusions that support the drum and isolate the metal of the drum from the metal of the front and rear panel protrusions, allowing the drum to rotate freely. A large belt encircles the drum and a pulley attached to a motor mounted under the drum. A spring "thing" applies tension to the belt to prevent the belt from slipping. If the noise is a metal on metal sound, check the condition of the felts. Other causes of noise have been stretched belt slipping on drum, weak spring "thing" not keeping belt tight, motor bearings dry (oil) or worn (replace motor), and pulley on spring "thing needs lube (lube). Hope this helps.
Jan 12, 2010 | Maytag Dryers
Heat and fan are on, but no action with drum
In my expierence with dryers you usually have to take the back pannel off not that one.
Oct 06, 2009 | Kenmore Elite HE4 Electric Dryer
Whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool dryer to be noisy. To find out what is causing the noises, you need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to pinpoint where in the dryer the noises is coming from. Once you have an idea of the area, you will need to disconnect the dryer from the wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of the drum, in other words, the baffles job is to separate the pieces of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot, the drum baffles holding screws will become loose. Loose drum baffles will cause noises. All you need to do, is to open the top panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the front and two on the rear. The job of the drum support rollers is to keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start to make squeaking noises and the roller bearing will start to wear out until the bearing on the roller is gone. When the bearing on the roller is gone, the noise will change from squeaking to a clanking noise.
The blower wheel:
The blower wheel is use to circulate the air inside of the dryer drum. The most common Whirlpool blower noises are cause by something falling inside of the blower housing and hitting the blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on the belt. There are two types of idler pulleys, the pulley with the wheel and the pulley with the teflon slide. A bad idler pulley could cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to run kind of noisy. When the motor starts making noises, the solution to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These belts work very hard making the drum tumble. When the belt stretch just 1/2 inch more that it supposed to, the belt will start slipping and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become noisy in your dryer. When your dryer starts making noises, make sure to check it out before it gets worse.
Feb 09, 2009 | Whirlpool LER4634J Electric Dryer
Dryer making loud clunking noise
Make sure the drum is not catching the back panel, and that the fan is not loose on the motor.
Dec 14, 2008 | Kenmore Dryers
Dryers Logo
57 people viewed this question
Top Dryers Experts
