Question about Refrigerators
Need to speed up the ice maker, side by side Kenmore
I have a kenmore 106.552444000 side by side, I've found that the ice maker on the unit has always been very, very slow to make ice. Is there a way to adjust the speed. The ice it does make is very frozen and I think speeding it up a bit would not cause problems. Thanks so much for your help ..
  • trevinrube May 03, 2009
    GE icemaker same issues: slow ice making, solid ice made but very infrequently
catriver
  • 878 Answers
SOURCE: Icemaker issue: cubes melting at the bottom causing water leak out the front
J, sounds like your dispensor flapper is not closing properly and you are drawing warm air up into the ice bucket. This model had an issue where the flapper pin holder was part of the housing and would break off. They have a kit now that fixes that problem. The only other thing it could be would be low freezer temps or it's staying in defrost too long. With out being there, I would start with the dispensor flapper. Check it out and post back.. Catriver.
Posted on Apr 22, 2007
catriver
  • 878 Answers
SOURCE: Ice Maker too slow
bayfishr, I'll try to give you an idea on how this thing works and let you do some checks. The cycle is controlled by temp. The harvesting process begins when the IM thermostat closes signaling the harvest temp has been reached. The closed thermostat supplies power to the IM motor and heater. Therefore the colder you keep it, the faster the production unless something has failed. I see a lot of heaters fail. You can test this. When the IM starts it cycle, test the voltage from L to H on the module,they will be marked. Should read 120V. The heater on the bottom of the mold should be getting hot. Disconnect the harnes and ohm it. Should ohm out at approx 72 ohms, same test points. If this checks good, check the center wheel on the module itself. Two clips keep the wheel in place. If one is cracked off, the IM will not fucntion properly. Other than colder temps, there is no way to adjust the speed of the cycle. Keep the flap in front of the ice-maker down so that the cold air is drawn across that IM. Catriver.
Posted on Aug 06, 2007
  • 100 Answers
SOURCE: Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Posted on Oct 30, 2007
  • 27 Answers
SOURCE: kenmore indoor icemaker frozen wil not dispense ice
Hi. I need more information to help you with your problem. Model number and a better discription of your problem. Will not come out of the ice maker itself or the ice dispenser? Thanks, Mack
Posted on Mar 23, 2008
tech master
  • 120 Answers
SOURCE: Kenmore Coldspot Side by Side Model #57562791
hi debie normaly the life of these ice maker range from 3 to 4 years then the wtr hardness eats them up and the mold start leaking wtr but if is a fairly new model the you have a faulty wtr vale that is not closing sending wtr all the time to the ice maker repl the ice maker is you see is peeling of the texture inside if it is ok repl the valve
Posted on Oct 17, 2008
I have a Kenmore side by side model # 106.53609202 and its about 8 years old. About a month ago it stopped making ice. I've already replaced the water valve behind the fridge and waited 24 hours and...
OK, remove the cover on the face of the ice maker and let me know if the model look like this picture:
12_17_2011_1_36_01_am.jpgIf it looks like this model, I have the service manual for it with all the testing procedures.If it doesn't, see if you can get a model number off the unit. They make about 4 different model for this unit.
Happy Holidays!Richard
Dec 17, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice Dispenser clogged with frozen ice
I have the same problem. Found this posting:
http://www.applianceblog.com/mainforums/sears-kenmore/10491-kenmore-ice-maker-dispenser-door-shute-clogging-missing-heating-element.html
Maybe our heater is not working?
Jul 05, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore Ice Maker Not Working
Probably need a new ice maker, whirlpoolpartssurplus.com
Jun 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
Kenmore icemaker does not work
Hand drawn of the GE # WR30X1009 found in 10-12 yr old Kenmore/sears/GE side by side refers. Couldn't find one ANYWHERE so forgive the hand drawn. Mine would not eject ice, intermintant. Bad microswitch on the on/off/vacation mode between the normally open side.
Apr 03, 2009 | Kenmore Refrigerators
Kenmore Component Ice Maker, What Else Could It Be...
remove ice maker maker sure is clear and also check the fill tube that supplies water to mold they sometimes have a plug of ice and no wtr comes out to mold that is if you already sure that there is wtr being supplied ok to unit
Oct 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore elite, will not make ice, but it does dispeanse
Dear tnsmarchini
You said, Kenmore elite, ice maker in door...........................???What????????
And we need more detail than Ice maker in door.
What does your ice maker do?
Sep 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I recently had trouble with both my water dispenser and my ice maker. I determined that my filter was clogged, so I replaced it. That fixed the water dispenser but the ice maker still wasn't working. I investigated further and found that the water inlet tube was frozen solid. Aparently, when the filter was clogged the water came in so slowly that it froze before it got to the icetray. I tried pouring hot water over the inlet tube to melt it and it mostly worked, but there was still some ice in the tube further back where I couldn't reach. Finally I defrosted the freezer so all the ice could melt and turned it back on and now it works great! Hope this might help.
Dec 17, 2007 | Kenmore 21.7 cu. ft. Side-by-Side...
Refrigerators Logo
261 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
