Question about Sony KV-13M42 13" TV
Image too large for the screen
I have a Sony KV-13M42 CRT TV set. As the set gets older the image size grows larger, so I can't see the right or left sides, or the top and bottom, of the images. The manual doesn't say how to fix this. Can you tell me how to reduce the image size, so all of it is visible on the screen?
Thank you.
Nick
  • 666 Answers
You need to replace filter capacitor from vertical section area and horizontal section area. i already encounter tha kind of problem and fix replacing vertical section capacitor.
Posted on Apr 03, 2010
How do I turn off the "video 1" display in the upper left-hand corner?
With almost any Sony remote with the button marked display this can be done---if left on too long it will burn the image into the screen of the set.
Oct 15, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Can I run auto program on my Sony KV-13M42 without a remote?
You may. I still think that your best solution is to find a SONY universal remote. It will have all the necessary inputs you will need, as time passes. Thanks for asking and show all hands of support!
Aug 31, 2011 | Sony KV-13M42 13" TV
I have an old Sony tv from 1992 and it's image is now compressed verticaly to less than half of original dimension. This 'half image' is distorted to center giving the impression that it's divided...
Vertical out transistors bad solder, or return linearity capacitor bad (a large capacitor, usually between 1000uf and 2200uf.) They're near where yellow and brown wires from picture tube connect to main board. They are larger transistors.
May 05, 2010 | Sony KV-35S66 35" TV
Screen size problem on 720p
Best to contact sony, local game repair shop.
Dec 30, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Tv image shifted right
Horizontal hold IC and circuit is failing The remote signal will cause it to spasm because of this faulty set of parts. It needs professional intervention to fix this properly
Sep 25, 2009 | Sony FD Trinitron WEGA KV-27FV310 27" TV
SONY KV-20FV10 blinks off
Bad solder contacts on connector/component pins, oxydized connectors, dried up, inflated or blown electrolytic filter capacitors, burnt resistors.
Could be in the main or high voltage power supply, video section power supply, possibly in any of the other sections.
(these are just some ideas)
regards
3rq8 (Triarcuate)
Jul 27, 2009 | Sony KV-20FV10 20" TV
Sony KV-32FS12 Component Video 4 Has A Wavy Picture
sounds to me like the differnence between watchiing in progressive and interlace. these older tube tv's are not capable of displaying a progressive scanned image. like the first dvd players. check your video out settings on your ipod to make sure its an interlace output.
Apr 23, 2009 | Sony KV-32FS12 32" TV
Top of screen slants on the right and left side horizontally
go in touch with SONY i assume ur set is still under warrenty.....call customer help and support
Mar 12, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sone TV Picture not aligned.
This looks like Pincushion problem. nothing you can do. Only a Trained technecian can do this adjustment to reproduce a perfectly aligned image. It requires a pattern Generator and other tools. call the company tech.
May 10, 2007 | Sony KV-36FS100 36" TV
Sony KV-13M42 13" TV Logo
80 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
