Question about Acer TravelMate 2434WLMi Notebook
Usb port is not working good - Acer TravelMate 2434WLMi Notebook
Device will not work with 3.5mm usb connection. how do i fix
Depends on what 'will not work' means.
Basics first:
1) Is the cable good - plug a USB device that you know works to your computer with the cable. Can you see that device from your desktop?
2) Is the USB port live and functional? With a known good cable and external device, does it come up? (Might combine with (1) if you can get the device + cable to come up on another computer or USB port. If it works on another system, do you get any tone or indication from your computer that something has been plugged in? Go to the USB devices page - it's in Hardware Manager in Windows, and check that the port is being seen. If you're getting a not-in-use or warning icon for the port, you may need to go update the driver.
3) If you have the documentation, or if your GPS still has a manual (or an external charger), see how much current the device draws on the USB (it should be in milli-amps or Amps (mA or A). If it's substantial, you could be overloading the USB port with the power draw. Try plugging into an external, powered USB hub that is attached to your computer. That may do the trick.
Good Luck!
Nov 09, 2015 | GPS
Printer not talking to desk top.
Please check usb cable first, make sure that it is ok. Then check usb port,move the usb cable to other port. Then check if usb cable and port are ok, try to connect other printer or device by using that usb cable and port. If works well means the usb port on printer got a problem. But if still not work the problem could be on usb cable or usb port on computer.
If you are sure that both the printer and computer are ok, try to reinstall the printer driver. Good luck!.
Source: Printer Clinic - Where printer problem get solved
Sep 18, 2012 | Canon Pixma MX310 All in One
My usb port on monitor isn't working. how can i fix this?
The USB ports on the monitor will work only if you connect the monitor via a USB cable to your PC/Laptop's USB port. Sounds awkward. Doesn't it? There must be a USB cable with flat socket on one end and trapezium shape jack on one end. It should be in the box which the monitor came in. The USB ports in the monitor are just another extended USB ports for your PC/Laptop. If you can't find the cable mentioned above, it is the same cable you connect to a printer, scanner,........ In some cases you might need to install a driver which should also come along with monitor. Mostly you don't need to install.
Good luck.
Apr 13, 2012 | NEC MultiSync 1770NX 17" LCD Monitor
None of my USB ports on my p2210 monitor are working How do I fix. Thanks
be sure that you connect usb cable between pc usb port and monitor usb port and try its usb
good luck sir
Apr 01, 2011 | Dell P2210 Monitor
Ok i have this mouse that does not work when i plug it into the usb port. the mouse dosent light up or any thing... what do i do?
First thing to do is to determine which one is at fault : is it the mouse, or the other way around?
Here's how :
  • Try another (known working) USB port
  • Try the mouse onto another known working computer
  • Try another known working mouse
  • Try another known working USB device (flash drive, etc) on USB port
Typically, the mouse needs replacement if it still does not work with another known good usb port or computer. If it's the other way around, then you may have USB port issues with your system.
Thank you for using Fixya.
Feb 20, 2011 | Computers & Internet
Computer is saying it has malfunctioned.
Well, it probably does have a problem if it worked on this same computer before without a problem. You could try the memory stick in the following to isolate the source:
1) try in a different USB port (to see if it is USB port related - only this port has failed - others ports will work).
2) try in a port on a different USB controller (to see if it is USB controller related - all ports on this controller will fail. Other ports on other controllers will work).
3) try in a different computer (to see if it is related to the USB stick itself ).
4) repeat the process with known good USB device such as a mouse or other storage device (this will confirm or cast doubt on the results found above).
That's about all you can do. Retire or replace the source of the problem. I hope thgis helps - good luck!
Jan 12, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Doesn't work.....no laser light appears on the bottom of the mouse. Nothing happens when I hit the "connect" button.
It sounds like these is either a problem with the USB port on the motherboard or with the mouse itself.
Assuming that if a wireless mouse: the batteries are new, the device is actually turned on and the transmitter has been removed from the mouse and plugged into the the USB port and it still does not work, it should be tried on all the other USB ports of the computer. If none work, try on another computer.
This will help determine if the mouse or the computer is the problem. If the mouse does not work on other ports or on the other computer, a defective mouse is likely. If it does work in a different USB port of the original computer, the first USB port is suspect.
If it only works on a different computer, the problem my lie in the setup or BIOS page of the computer. Look for a setting for USB ports. Enable the ports if disabled, and try again. If still no luck, there is some other issue at the motherboard level. Unless fairly new and under warranty, it will probably not be worth trying to fix the problem, when a $20 USB expansion card could be purchased and installed to provide USB connectivity needed.
You could also try connecting a different USB device (if available) to test the USB port. A USB webcam, hard drive, mechanical mouse, etc. are all good choices to test the port. You should indicate or cover any ports that are found to be defective.
I hope this helped and good luck!
Nov 01, 2010 | Computers & Internet
DELL LATITUDE D600 USB PORT NOT WORKING
You can solve this issue by installing usb 2.0 driver in your DELL LATITUDE D600 laptop find Blow Drivers Download Link:
.DELL LATITUDE D600 Drivers Download Link
Feb 05, 2010 | Dell Latitude D600 Notebook
Why don't my USB ports on my monitor work
1) good USB cable from Monitor USB input port to PC USB port?
2) Check pin 1 of the USB port, you should have 5vdc.
3) Your monitor's USB ports are basically the powered USB hub, but it must be connected to the PC USB port.
Jan 25, 2010 | Dell E176FP 17" LCD Monitor
Why does my iOmega LPHD-UP USB external HD not work with 7-Port USB hub? Is it the 500mV limitation per port or something else? Works fine if plugged directly into the laptops only USB port.
you got it! may need to get a 'powered' usb hub. another 'wall wart!', but will probably allow use of hub to power usb hdd!
good luck!
Oct 11, 2009 | Computers & Internet
Acer TravelMate 2434WLMi Notebook Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
