Question about Logitech Audio Players & Recorders
The sound cuts off sometimes the wire seems to be the problem...
Ok my headphone sound cuts off sometimes... the mic works well. sometimes when i turn my head, the sound cuts off.
  • 469 Answers
The wire leading into the headset is likely broken. Usually this occurs at the entrance point of the jack or at the point where the wire enters the speaker, if they are worh repairing, open the speaker and check the condition of the wire. this can be as easy as pulling gently on the wire either side of the suspected break. if the wire is firm then it is likely alright, if the wire stretches, the wire is broken inside and only the insolation is keeping it togehter.
if this doesn't work then you will need an ohm meter and ohm out the cable, remember to flex the cable at the suspected area with the meter on, if the meter drops off you found your break.
solder up the break or if in the case of the jack solder on a new jack.
Hope this is of some help.
Ed
Posted on Apr 19, 2009
HP-H700MV - windows xp sp3 - .headphone is ok. connection of device is ok.microphone not work.
check in the windows mixer setup that mic is not muted
check the wire connection to the sound blaster of the microphone
it should have a seperate line
Apr 25, 2014 | HP Audio Players & Recorders
My Road NT 1A Microphone is not work In Sometimes. Mic cable is OK But Sound not to came in My Alesis Sound Card the Mic gain is Very hi level Coming sound in Sound Card but it is Very low level, But...
seems like u have a damaged capsule... the damage maybe caused by accumulated moisture or spit that must've got to the capsule... i have the same problem... if ur mic is still under the 10 yr warranty rode will repair it for free
Jan 16, 2011 | Rode NT1A Professional Microphone
Have sony STR DE445,sound cuts off ,will come back when I tap on cabinet,seems to work ok with headphones.
remove all the speakers clean wires and connectors put a drop of oil in headphone socket and try again this is due to rusting and dust
Jun 04, 2010 | Audio Players & Recorders
Peavey minx 110 no sound from main speaker but headphone jack is ok. speaker wires are attached ok.everything on the board appears to be in good shape.amp powers up and all controls work great through...
Inside the headphone jack is a built in switching mechanism. It is there to cut off the sound to the speaker when you are using headphones to practice quietly. For some reason or another it seems as if this is no longer working correctly. One of the causes of this can be bad solder joints on the circuit board where this jack is located. Another cause is a failure of the jack itself. If you are capable, Take the circuit board out and have a look. Hope this helps.
Oct 27, 2009 | Music
Distorted sound from new Dell desktop
1. In most cases the problem maybe due to the powersupply. If the filter capacitor or the diodes are not working properly in the power supply, it could give the distortion sound. Use a different powersupply to see if it solves the problem.
2. The mic wire can also catch some hissing noise sometimes. Disconnect the mic wire from the motherboard and see if it solves the problem.
Thanks
Jul 02, 2009 | Dell Inspiron 530 Desktop Computer
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Apr 07, 2009 | Logitech Premium Headset
Sound in left earbud shorts in and out
If its not hard to open the case, just solder the connection again (only if you found out that the problem is inside).
Also check the wire if it have 100% connection. You may also check skin of the wire. If found out no good, so possibly this could fix the problem.
Mar 02, 2009 | Etymotic Research Isolator ER-6i Consumer...
I cant use my microphone on my skullcandy lowrider headphones
OK OK OK, the lowriders use dolby digital with WMA playback, and there is a setting in ur xbox settings where u can change that. BUT UR NOT DONE YET. press the Xbox button, go to settings go to prefrences, go to mic and check the box that sais "play through both." and now u can hear the ppl and talk. however, what they dont tell u is that the mic interfears with the WMA, so all u need to do is just buy an inline volume adjuster at walmart (wally world) for like 3 bux (the one that coems with it is regualted by FDA or wtvr and has no sound which is verry unlike skull candy). THESE headsetes arnt cheaply made at all 2 tell the truth, they shooda came with instructions, but once u get em going, they r insane! i have a pair of turtle beach x5s and its nice, but not as good asthe lowriders. and anotehr feture they dont tell u, if u get a volume adjuster with the "base gain" swicth, it works on the lowriders, so u can add a little rumble and umph to ur headset.
Jan 06, 2009 | Skull Candy Lowrider Headphones
Mic
Try a different set of headphone, if it works, then it is the headphone set.
If you get same problem with all headphones, then
If you get no sound: ensure that you have sound from speaker, if you get sound from speakers and no headphone working, then there is a problem in the headphone connection.
If you have no sound at all , not even with speakers, then check audio settings in control panel, ensure audio is not muted. If audio settings are OK, then you need to reinstall audio driver, or you have a faulty audio card.
Additionally, if it is only the mic not working then do the following:
Go to control panel and open sound and audio device.
Open volume settings and find settings for mic.
Tick off the mute option.
The mic is muted by default in Windows, that is usually the reason why it is not working.
Sep 14, 2008 | Compaq Presario 700 470024-192 Notebook
Headphone and mic
my presario c700 has a built in mic try just connecting headphones in and using the built i mic
Jul 23, 2008 | Compaq Presario 700 470024-192 Notebook
439 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
