Question about HP Compaq Computer Speakers
Volume on computer too loud i can't find the volume control icon
I unpluged the computer all wires and remover the computer and then replug all the wires. I now can't get the volume control to work. I had a volume icon on the bottom of my screen but it is now gone.
  • Roberta Smith
    Roberta Smith May 11, 2010
    recheck that you have plugged the speakers into the right hole
Go to control panel->sound and audio devices-> in volume tab see that "place volume icon in the taskbar" is checked. then you'll get your icon back in task bar.
Posted on Apr 20, 2009
It'll work listening to the radio just fine for about 5 minutes, then the sound goes away.
If you are running at high volume for even a short period of time, the overload signal to the microprocessor(computer within your unit) will cause the unit to shut down. If you are running it that loud, try turning the level to 1/3 of your normal listening mode. If it runs, try to keep the volume with reason.
Aug 04, 2015 | Audio Players & Recorders
Volume icon missing
Which operating system ??
In Windows and on a Mac, you can use an icon shaped like an audio speaker to adjust the computer's volume or mute the sound output completely.
Whichever operating system you are running, it is possible to remove the volume icon from the screen.
If you have removed the volume icon accidentally, you may not have a convenient way to adjust your computer's sound volume.
Restore the sound icon to resume using it to adjust the volume or mute your computer's sound output.
Click the "System Preferences" icon on the dock.
If you have removed this icon from the dock, click the Apple icon at the top of the screen, then click "System Preferences."
Click the "Sound" icon in the "System Preferences" window.
Place a check in the box at the bottom of the window labeled "Show volume in menu bar."
The sound icon appears at the top of the screen.
Close the window to resume using your computer.
Restoring the sound icon in Windows 7
Click the Windows Orb (Start button), then click "Control Panel."
Click "Taskbar and Start Menu."
If you do not see this icon, click the "View by:" drop-down menu at the top of the window and select "Small icons."
Click the "Taskbar" tab, then click the "Customize" button.
Click the drop-down menu next to "Volume" and select "Show icon and notifications."
Click "OK" twice and close the Control Panel.
Restoring the sound icon in Windows Vista
Double-click "Taskbar and Start Menu."
If you do not see this icon, click the "Classic View" link.
Select the "Notification Area" tab. Place a check in the box labeled "Volume."
Click "OK" and close the Control Panel.
Restoring the sound icon in Windows XP
Click the "Start" button, then click "Control Panel."
Double-click the "Sounds and Audio Devices" icon, or click "Sounds, Speech and Audio Devices," then click "Sounds and Audio Devices."
Place a check in the box labeled "Place volume icon in the taskbar."
Restoring the sound icon in Windows 2000
Click the "Start" button, then click "Settings" and "Control Panel."
Double-click "Sounds and Multimedia."
Place a check in the box labeled "Show volume control on the taskbar."
Restoring the sound icon in Windows Millennium Edition (ME)
If you do not see this icon, click the "View All Control Panel Options" link.
Restoring the sound icon in Windows 98
Double-click "Multimedia."
Click the "Audio" tab.
Dec 04, 2013 | Computers & Internet
Speakers are not loud
Hi ,
down on the very right side of your task bar is a icon of a speaker , click on that and it will allow you to adjust the sound level............let me know if this works ,,,,,,,,,,,,,Roy
Jul 21, 2011 | HP Audio Players & Recorders
Well i am trying to figure out how the **** an i suppose to volume up this grey little speakers???
if you are referring on volume loudness
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume adjustment you will need to right click on the volume icon depending on your operating system select adjust volume
hope this helps you
Jul 18, 2011 | Polk Audio AMR50 Computer Speakers
The Volume goes nice and loud but the sound is tinny.
At bottom right of our screen you will see an icon for the volume (shape of a speaker). Double click on the icon to access the full volume control dialog box. Try in creasing the volume from here and set it to a reasonable level. Once set, you can use the volume control on your monitor.
Jun 25, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Speaker volume too loud
Go to your bottom right task tray. Right mouse click on the speaker icon, select open volume mixer. You should be able to adjust to your preference from there. Hope this helps.
Apr 14, 2009 | Dell 5650 Computer Speakers
Dryer buzzer is SO LOUD - How can I adjust volume/turn off?
Buzzer mounted to back of control panel.
**UNPLUG POWER BEFORE REMOVING CONTROL PANEL OR TOUCHING -ANYTHING-!**
Located on left side of control panel, bolted to back. Small rectangular device with two connections and no associated button or dial.
Remove the panel and disconnect one of the leads. Fold the connector back against its wire, carefully and securely tape the connector with electrical tape so it cannot touch anything. Also tape the connector on the buzzer that you removed the wire from.
Re-assemble the control panel.
As with anything mechanical, hours of frustration trying to take something apart can be avoided by taking a few minutes at the beginning to look closely at how it is assembled.
Mar 01, 2009 | Frigidaire GLET1031 Top Load Stacked...
No sound on my computer. it was working until two days ago.
u don't need to restore it's dound setting problem iu just chek volume control and chek master sound and wave sound is on or mexmimum
Jan 08, 2009 | Bose MediaMate Computer Speakers
Volume stuck on high
Go in control panel -> sound and activate icon or adjust volume there.
Dec 15, 2008 | Microsoft Windows Vista Home Premium with...
When i try to print, a message comes up that the printer is not ready
delete the printer icon from the printers folder in your control panel. unplug the printer from the computer, reboot the computer, after reboot, replug printer, check the icon if it appears back in the printer folder then try to print...
Jul 17, 2008 | Office Equipment & Supplies
HP Compaq Computer Speakers Logo
823 people viewed this question
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
richie46
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
