Question about Acer Aspire 5315 Notebook
Remove DVD on Acer Aspire 5315
The cable or ******** the DVD rom is crimped and apparently keeps the DVD from working. Where are the screws that hold it in place on an Acer Aspire 5315?
  • 1 more comment
  • bruch1936 Apr 20, 2009
    Thank you for taking your time to respond to my request.
    Bruce Hill
  • bruch1936 Apr 22, 2009
    I did get the DVD removed after your advice. Thank you.
    Bruce Hill
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    just beneath the drive remove the panel in which ram is located just next to ram slots u will see a small screw that holds the drive just open it up and pull drive outwards let me know if i can help more
    President:
  • 1,223 Answers
Could u pls kindly rate me if ur problem is FIXED now ! or is there anything else i can do for u
Regards
Posted on Apr 21, 2009
  • Shoaib Rais
    Shoaib Rais Apr 23, 2009
    so glad that ur problem solved
    Keep cpming to FIxya for help in ur problems
    We are here to assist
    Regards
How to tke out dvd rom
1. Turn your computer off 2. remove screws that are in the panels 3. remove the panels 4. gently pull out the cables connected to the DVD rom 5. unscrew the screws in the bay 6. push the dvd rom out the fornt panel 7. screw the panels back into place.
hope this works =)
Jan 24, 2012 | Acer Aspire 5315 Notebook
How do i remove the dvd drive from laptop.
to do this check the note used to hold the \cd\rom under the system . then you will loose it to remove it
Apr 14, 2011 | Acer Aspire 5315 Notebook
HOW DO I REMOVE DVD ROM FROM ACER ASPIRE 5315
im assuming the "eject" button is not respomding, no worries REAL easy fix, if you have a paper clip, if not find something the same diameter, if so, unfold paper clip and there should be a small hole on the door next to the "eject" button, insert end of paper clip, retrieve dvd.. :)
I want to format and reinstall windows on my aspire 5315 ive tried pressing f8 on start up and no screen that says boot from cd comes up what else can i try
Go into your BIOS and select DVD/CD rom as first boot device.
Put your System Disc in the DVD/CD rom drive and restart the laptop.
Mar 25, 2011 | Acer Aspire 5315 Notebook
Hi, I have a problem with my laptop, acer aspire 5315 with Vista 32 bit, the problem is no longer reconose the dvd and cd! could give me any solution? would greatly appreciate it, my email is: selas...
Open "my computer" and in a empty spot in the folder right click and select "properties" in the top right hand corner you should see "device manager"
opening that do you see any red X's or yellow !s at the "DVD/CD-ROM" entry?
If you do you can right click them and select "uninstall" reboot and the Operating System will reinstall the drivers.... if it has them which it should.
Even if you don't see any marks at the "DVD/CD-ROM" (if its there) uninstall all entries.
If you don't see "DVD/CD-ROM" listed you may have it disabled in the bios, some virtual drive software holding it out or malware.
Post your answers as a comment or reply and I'll be notified
Feb 01, 2011 | Acer Aspire 5315 Notebook
It wont detect a dvd on my acer aspire 5315 laptop
If your laptop won't detect DVD drive try and check connection first. Turn your laptop upside down and remove three maybe four screw (deepens on laptop) directly over a DVD drive and pull drive out. Blow some compressed air inside of laptop and check for anything abnormal on drive itself. Then put it back in and check if it works. If not it's either bad DVD drive or bad motherboard. Thanks and good luck.
Apr 17, 2010 | Acer Aspire 5315 Notebook
Acer aspire 5315
well i think you are asking for to use your dell cd to install in your sister's laptop.maybe it will not work because they are specific system configured .you can't use them everywhere.
Mar 31, 2010 | Acer Aspire 5315 Notebook
My acer aspire 5315 dvd rom doesnt work at all but somtime it do
There is a problem with the DVD ROM. Maybe it is not well fixed and causing conflict which result in making the computer slow. And maybe it is not contacting the system well again, that's why it worked and later not worked when it loose contact.
I would advice that you shut down your system, loose the DVD ROM and put the system back on without the DVD ROM after a little while when the windows must have settled, shut down the system again and fixed back the DVD ROM. Make sure it is well connected and put the system back on again. Test the DVD ROM and see if it would give the same problem. If it does, then may be you will have to replace the DVD ROM.
One a DVD ROM is bad, another one needs to be purchased, because it is usually difficult to repair DVD ROM expect in minor case.
I wish you the best.
Dec 18, 2009 | Acer Aspire 5315 Notebook
Cd/dvd-rom drive E: not detected
plz check in the bios the cd rom is enable, then check the datacables try with a new data cable
Jun 19, 2009 | Acer Aspire 5315-2153 Notebook
How to instal a laptop dvd rw
open cd rom tray.open laptop lcd screen flat, remove the 2 screens on the back of the hinges.carefully remove the bezel(just above the keyboard, with the power buttons etc )from right to left.remove 2 screws securing keyboard.you will see one screw that holds the cd/dvd rom in place.remove screw,pul on tray carefully, cd rom will slide out. replace with new cd rom.
Dec 07, 2007 | Acer Aspire 5100-5033 Notebook
Acer Aspire 5315 Notebook Logo
1,400 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
