Question about InFocus LP640 Multimedia Projector
Error when powering on the projector
When the unit is powering up I get a msg.that the lamp is not striping.What may that be?
  • ollie20 Apr 06, 2009
    it keeps saying lamp didn't strike
    nd how can u tell whn the bulb has gone
That was it for me! I took some needle nose and pulled the projector connecter back into it's slot. It had fallen down past where it should have been.
Posted on May 20, 2008
You need to make sure that the wiring that connects the power from the project and the bulb is touching. You may have to take off the top and press on the opposite end of the connection as you put the bulb in.
Posted on Jan 23, 2008
Projector posted error, "replace bulb" Projector
Your projector need replacement of lamp unit if you don't want yet you just reset the lamp counter
Power on projector
press MENU key
Press right arrow key to select Option
Press down arrow key to select lamp Hours
Press and hold down the ENTER key 5 second (lamp hour counter show red)
press POWER button to turns off the projector
now you power on your projector and no error displaed and no itself turn off after 15 minutes
Apr 13, 2011 | Panasonic PT-L785U Multimedia Projector
NEC MT1050 Lamp Error
Does the status light stay on red? If it does then the lamp timer has exspired and will not let the projector turn back on until it is reset, at which time you should replace the lamp. To reset the timer you need the remote control, with the unit plugged in in standby mode hold down the power off button for 30 to 45 seconds until the status light goes off.
Feb 05, 2009 | NEC MT850, MT1050, MT1055, MT1056...
Christie DS+60 projector turns off spontaneously
Here is a list of error codes for your unit:
12 Software bug. Contact dealer/factory.
13 Flash memory corrupted. Download new software.
14 Engineering only programming is complete. Call Christie, replace TIPM.
15 Attempting to download code without being in boot mode
16 Invalid interrupt. Power off/on. If it persists, contact dealer/factory.
17 Forced boot mode. Keys held down too long.
18 Attempting to program boot mode without jumper
21 Lamp compartment too hot
25 Lamp 1 not installed
26 Lamp 1 Interlock: door open, lamp not installed
27 Unable to turn lamp 1 ON
28 Lamp 1 shut off unexpectedly
29 Lamp 1 driver overheated
2A Lamp 1 driver operation error (e.g. too hot can’t start)
2C Lamp 1 driver UART communications failure
30 Lamp 2 not installed
31 Lamp 2 door open
32 Unable to turn lamp 2 ON (unknown reason)
33 Lamp 2 shut off unexpectedly
34 Lamp 2 driver overheated
35 Lamp 2 driver reports operation error (e.g. too hot can’t start)
36 Lamp 2 driver UART communications failure
37 Lamp Watchdog Tripped – Unless lamps turn on again after 3 minutes, assume software hung.
Jan 16, 2009 | Christie DS+60 Multimedia Projector
Dell 2300 projects verticle stripes accross the projector screen.
this is due to improper power supply or a loose connection inside. the symptoms are of power supply unit inside projector. check out the current and amperes inside the projector on board. sometime the current stable but the ampears are down.also check the switching transistors & filters inside.......
Feb 12, 2008 | Dell 2300MP Multimedia Projector
Lamp will not strike error message
this can sometimes indicate either an overheating issue, a lamp service life problem, or that the cover to the lamp housing has not been secured properly.
Dec 14, 2007 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Faded Black Strip on Side of Projection
I had a similar problem with my InFocus LP600 although my black stripe was straight up and down. I am guessing this is caused when the unit is bumped or dropped. This is not an easy fix unless you have a lot of experience with small tools and parts and you may need an extra set of hands. I found some tiny alignment screws under the lamp cover and hidden beneath a peel-off 0.5" x 2" black plastic strip. The screws are located between the bulb assembly and the main projection lens and are oriented 90 degrees apart around the light projection path. The trick is in getting the projector to temporarily function with the lamp cover off -- it has an interlock tab on one edge that pushes on a microswitch when closed. We turned the projector upside down but raised on some slats for heat dissipation, gently held the interlock switch in with a small screw driver, and plugged in the power cord. After pushing the power switch to get the image, I adjusted the tiny screw that is angled towards the front of the projector and the stripe dissapeared! Since your stripe is angled, you may need to adjust both alignment screws. The screw heads are very tiny torx bit types but I was able to use a 3/64" (.05") allen (hex) wrench that came in a set of cheap jewelers type tools that are widely available. Be very careful while operating the unit with the lamp cover off as there are very hot surfaces and exposed wiring.
Nov 08, 2007 | InFocus LP 600 Multimedia Projector
InFocus LP640 Multimedia Projector Logo
242 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
