Question about Fuji FinePix F10 Digital Camera
Photography menu operation
As it says on page 45 of my manual I turned on the menu by pushing the menu button. Again, as it says, the menu appears. I can toggle between page one and page 2 and alter things on page 2 but I have no apparent access to page 1. Whenever I touch the up or down arrows I toggle pages. I would like to alter, for example, exposure compensation but I simply can't! Any advice gratefully received.
    President:
  • 423 Answers
You are on the fully automatic shooting settings, and as such, are prevented from making exposure (etc.) adjustments. Change the shooting mode to manual, and they should all be accessible.
Posted on Feb 17, 2008
How reset photoconductor ibm infoprint ibm1512 thank you
The instructions for IBM Infoprint 1412/1512 printer's photoconductor is the same as the Lexmark E342.
The instructions are located here: http://support.lexmark.com/index?page=content&id=HO2564&locale=en&userlocale=EN_US
Recap of Instructions:
To Reset Photoconductor page count:
1. Turn off printer
2. Press and hold the Select and Return buttons at the same time on the panel and turn the printer on (continue holding down buttons until printer screen displays "Performing Self Test" or "CONFIG MENU").
3. If "Reset PC Cnt" does not appear on screen, press the left or right menu button until it appears.
4. Press "Select" and the message "Resettting PC Cnt Value" should briefly appear indicating the page count is reset.
5. Turn off printer when "CONFIG MENU" appears again.
6. Wait 5 or more seconds and turn back on. Done.
7. It is suggested to check and verify that the PC Count is reset by printing a menu setting page:
a. Press left or right menu buttons until you see "Utilities Menu" and press "Select".
b. Press left or right menu button until you see "Print Menus" and press "Select".
c. This should print out the information. Look for "Cartridge Info" and the word "Photoconductor". It should indicate "OK" or close to 100%.
d. If not showing "OK", print 10-20 pages and Print Menu again to check. If still not, reset PC again and check again.
Jan 13, 2011 | IBM Infoprint 1512 Laser Printer
Toshiba 32A42A - Menu options pop up all by themself, and the TV is making its own choices. Can this be fixed or do I call a Preist for an exercism or just get rid of it ?
I had the exact same problem yesterday. It took me 1 hour and 45 minutes to find a solution. Here is the solution: It is not a stuck button or the television being 'posessed' that is resulting in the menu cycling. It is the fact that the television is in the DEMO mode. I was able to read the manual for this television online at the Toshiba website. On page 30 it states 'To stop the DEMO mode press 'recall', ''exit', or 'power'. Unfortunately the 'recall', and 'exit' button are on the original remote which I no longer have. The power button on my model is broken. I use the cable box to 'turn on the television'. In reality, the TV is never off, it is just showing a black screen when the cable box and DVD player is off. I suspect this defect in the power button has occured on other TV's experiencing this problem. I was able to push the broken power button to the inside and side of the television casing exposing a round circle that the power button pushes when the power button is not broken. I pushed this small circle to turn the television off. After about 5 seconds I pushed the button again and the television went on without the annoying menu popping up. Just unplugging the television and plugging the television back in does not work. You need to be able to push the power button, or one of the other 2 buttons on the remote previously mentioned.
Also on page 30 it explains how to activate the DEMO mode. It's not too hard to accidentally do, especially when you have kids pushing buttons haphazardly.
I hope this helps someone outthere in cyberspace! Kevin
Sep 20, 2010 | Toshiba Televison & Video
How do I turn off the low tire pressure light?
Owners manual; or may have to go to dealership.... The info starts on page 5-66 under "Tire pressure Monitor System" hope it helps.
If you cut off the radio press and hod the the tune button until tire pressure pop up then press the tune button again and it will reset.
Aug 01, 2010 | 2002 Chevrolet Impala
I have the SVP t600 hd and i can not figure out how to look at the pictures I have taken. I have misplaced my user manuel, can you tell me where I might find a user guide on the internet?
Simple operation guide for SVP t600 HD digital camcorder
press the video/photo button to select which type of files to access, video or photography
then press the button marked with the play (triangle) symbol.
Doing this will access the photos or video on the installed sd card.
you can also plug it into your computer by USB, turn it on and it appears as a HDD in my computer.
menu is found by pushing the tele/wide button in,
menu control is by pushing t/w button up or down and in to select. the rest is on screen.
Jun 19, 2010 | SVP HDDV T-600 HD Camcorder
My tv is block and i dont know wat to do. how can i unblock it?
Don't use the remote control the signal it block.Go to ur manual contol on the tv right side.Push the power button to turn tv on.Push button Menu now U in the tv Menu,Use the volume + or - button move the Menu function to OPTION,now use the Channel + or - go down to the word said Operation lock out(ON) Now push manual contol button said INPUT.Now the word said Operation lock out(OFF).Now remote control is relase,u can use the remote control now.Tell me this work ok.This is how i unlock the Sharp Aquos tv.
May 09, 2010 | Hisense TL1700 17 in. LCD Television
I need to locate an operating manual for a kenwood
Most Keenwood stereos require the radio to be in standby mode. this is done by pushing the source button. Once in standby push and hold source button down and menu should appear. scroll through until you find aux. on or off switch to desired setting. dothis by the control lever or knob.Then push source again to get out of menu.
Mar 11, 2010 | Car Audio & Video
Ink system failure error 0xc18a0101
I had this problem, was about to buy me a new printer but than found the perfect solution. Just excuse my english (I am German). I have to translate the menue German into English and I hope I do it right.
Push the Setup and the arrow that shows to the left at the same time! Than push ok. A menue opens that says something with support. Push the arrow right button until system configuration appears. open it with the OK button. Now it should show the hardware failure status. If not look for it with the arrow button. When found the hardware failure status, again push OK button. Than something like clear inquiry should appear, push OK. As soon as the "hardware failure status cleared" appears, you can leave the menue by disconnecting the printer from the powercable.
Reconnect it with the powercable and it should work again.
Aug 24, 2009 | HP Photosmart C5180 All-In-One InkJet...
Sharp AR-275 copier with fax module. Need to edit sender ID
push custom or system setting button, push key operator programs on lcd, type in 00000 from number pad, hit fax settings, fax default settings, own name/number set. hit ok button at top when done then CA button to return to main menu.
Mar 04, 2009 | Sharp AR-275 Copier
Clearing message after "replace photoconductor kit" message came on
To reset the photoconductor page count:
  1. Turn off the printer.
  2. While the printer is off, press and hold the Select (pattlnk_1262005_1956-enus20772_selectbuttonicon_t64x_en_us.gif) and Return (pattlnk_1262005_1950-enus21096_returnbuttonicon_e340e342_en_us.gif) buttons on the operator panel.
  3. While keeping both buttons held down, turn the printer back on. Keep holding down both buttons until the printer screen displays Performing Self Test or CONFIG MENU.
  4. Release the buttons when you see either of these messages.
  5. If Reset PC Cnt does not then appear on the screen, press the left or right menu button until it does.
  6. Press the Select button once. The message Resetting PC Cnt Value should briefly appear on the screen, indicating that the photoconductor page count has been reset.
  7. When the display shows CONFIG MENU again, power off the printer.
  8. Wait five or more seconds and then power the printer back on. NOTE: Do not hold any buttons down when powering on the printer during this step.
    The photoconductor page count should now be reset. At this point, it is recommended that you print a menu settings page to confirm this. Do the following:
    1. With the printer at the Ready status, press the left or right Menu button until UTILITIES MENU appears on the screen.
    2. With UTILITIES MENU on the screen, press the Select button once. A new menu should appear.
    3. If Print Menus is not displayed on the second line of the screen, press the left or right menu button until Print Menus appears.
    4. Press the Select button once. The message Printing Menu Settings should appear on the screen and the printer will print out one to three pages of printer settings.
    5. Look for a heading labeled Cartridge Information on one of the menu settings pages.
    6. Under Cartridge Information, look for the word Photoconductor. Confirm that the level of the photoconductor says OK or is close to 100%.
    7. If the photoconductor is still reading low, try printing 10 - 20 more pages.
    8. Print the menu settings page(s) once more. Confirm that the photoconductor level is now at OK or close to 100%.
    9. If the photoconductor continues to give a low reading, repeat this entire procedure again from the beginning to reset the counter once more.
    10. If the photoconductor reading is still low after two attempts to reset the counter, the printer may require service.
Jul 28, 2008 | Lexmark E342n Laser Printer
Fuji FinePix F10 Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
KJ Soni
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Fuji Camera Expert? Answer questions, earn points and help others
