Question about Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
Fisher paykel drain tube sliced
Found a small 1/2" slice in drain tube. Wondering if a small repair job to the tube would be sufficient, or removing drain tube which requires drawer removal.
I just took out the drawer for the first time on my 603 and it is a pleasure! However, you may not have to remove the drawer if it is the top one as the drain tube is accessible without removing the drawer. You will have to remove the plastic shield on the bottom...it has 7 plastic clips ... two pairs of two in the very front of the drawer, 3 big ones on the big circular plastic part. It also has two plastic spade 'aligners' in the back of the single plastic shield... those need to go in first before clicking in the others. I had to fuss with this a little until I understood how it was attached, but everything snaps in place.
Once you get the plastic shield off (it looks a little like the Starship Enterprise and is almost 20" or so long) you have access to the drain hose. It also clips into the drain housing with two plastic clips... be careful with these, they take some gentle persuading to come off and release the drain hose. Once you disconnect the drainhose, you can replace it (if that is what you have chosen to do). THe adapter at the end of the hose that plugs into the pump housing looks pretty unique to Fisher-Paykel so I suspect that you will need to order that. The alternative would be to get some kind of adapter for the hose and cut off the part with the split. Insert the adapter (adapts between the now two open ends of the hose) or adapt to some other hose which you can run to the sink drain... that may be the easiest approach, come to think of it.
good luck
Posted on May 02, 2009
Fisher Paykel washer won't spin and drain. Any solution? Error looks like no E AP
possible answer for you see the link after reading Error/Fault code 00000101. (The value is 5.) It wasnt draining the water out at the rince cycle. I saw comments on fixya.com that others with the same problem found clothing between the outer bowel & the inner bowel or an item such as a necklace chain or hairclip jamming up the propeller..... (Two days later, see part 2....) I just fixed this F&P GW612. There was a darning needle stuck in the drain motor pump stopping the propeller from spinning around. I fixed it for my mum by watching a couple of You Tube videos. Easy job to do. Took me about 1.5 hours including drawing out the water from the drum with a bucket & jug first. Lay the machine on a soft mat, remove the motor pump from underneath, clean it out. (You could find a foreign object such as a coin, cloth, rubber band etc.) Put it back together & test if it's pumping out water at the rince cycle by doing a low water wash cycle. So happy, job done & I saved my mum some money!! Fisher Paykel GW612 Not rincing spinning part 1
Mar 15, 2018 | Fisher Washing Machines
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
How do I get the bottom drawer of the fisher paykel dishwasher to drain
Not Draining - Most common Fault is the rota motor.
look on u-tube for easy removal.
clean and retry, might work now but be noisey.
Best place I have found for replacement part is Paykel £50.00 ish
Oct 30, 2014 | Fisher and Paykel Dishwashers
Why wont it drain?
most likely the rota motor is stuck.
check u-tube for easy removal, clean tips
on checking for best deal for replacement part, I found Fisher & Paykel the best price, £50.00 ish
Jun 29, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel GW612 gets to rinse stage and doesn't drain properly. The drain pump gets rid of some water then cuts out for a couple of mins, then starts again. It does this 3 times before...
I recently had a similar problem and here is how I fixed it: Locate the drain pump. Connected to the outlet of the pump is a black rubber tube approximately 6" to 10" long and 1/2" in diameter. This tube is connected to a valve. The clamps holding the tube in place can be removed by hand. Take the clamps off and remove the tube. I found a penny stuck in mine near the valve end. How a penny made it through the pump and most of the way through the tube, I don't know, but I removed it, and the washer works as good as new. You might as well put a few drops of oil on each of the pump bearings while you are working on it.
May 14, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
We are getting a strong odor from our two compartment dishwasher, would welcome any suggestions
Get rid of any odor that may be coming from the plumbing pipes your dishwasher shares with the sink. Pour a half a cup of baking soda down each sink drain. Pour cups of vinegar down each drain until all the baking soda is washed away. After 5 minutes, run very, very hot water down each of the drains.
Clean out your garbage disposal. Slice a lemon and put the slices down your disposal drain. Run your disposal with the cold water running. You can use just the lemon or an orange rind if you don't have a whole lemon.
Pour two cups of vinegar into the dishwasher and let it sit for an hour and then let the dishwasher run through a cycle with the hottest water possible. Repeat the process if that does not help. You can use baking soda instead of vinegar - just sprinkle it in the bottom of the dishwasher.
Between washes, pour ¼ cup lemon juice into the dishwasher cup, and run a short but complete wash cycle. Is will not only deodorize the dishwasher, but will also help get rid of any metal build-up
Nov 03, 2010 | Fisher and Paykel Dishwashers
Fisher and paykel dd603
Flood switch is at the very bottom underneath the bottom draw in the base floor.Unplug cord.Open bottom draw all the way & squeeze a towel or sponge under the draw & soak up the water..The washer should work now..Why did it flood in first place?
Check that dishes are not stacked higher than top edge of the draw otherwise it can't seal.this can happen when children are asked to stack the dishwasher.Another cause is some models the seal is an inflatable tube that seals the top edge of the draws,it gets cut or sliced buy a plate that was stacked to high when you closed the draw.there should be no clunk of dished hitting when the draw is closed.
May 30, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Plugged in not charging
you have a messed up power supplybuy a new one. or try one of a relatives
if its not the supply it's your MOBO -motherboard.
If it doesnt work open your laptop and check your dc input connectors
Nov 30, 2008 | HP Pavilion dv6000z Notebook
Fisher & paykel (mw511)
check out the DRAIN MOTOR PUMP , its a small motor with 2 hoses connected to it , it could be clogged , need to remove it , inspect inside the impellers for any debri , clean it , re install and try again , hope this helpful AJ
May 20, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher paykel won't finish spin cycle
To remove the tub you need to remove the spin motor magnets and stator, then using a tube soket undo the tub nut and it will come out. (not EASY JOB)
Sep 17, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel 23 in. DD-603 Built-in Dishwasher Logo
643 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
