Toshiba 51H83 51 in. Rear Projection HDTV-Ready Television
Problem for Toshiba 51H83 51 in. Rear Projection HDTV-Ready Television
Hyper module
By bozztex on Sep 19, 2007
Where is the hyper module on the 51H83, I need to check it out to see if it needs to be reseated?
Best Solution
posted on Sep 20, 2007
Helpful)
techman
Rank: Guru  Toshiba Expert
Rating: 86%, 7642 votes
no it does not need to be reseated. Most likely there are bad capacitors inside of it. The Hyper, or whats really a scan converter, is located right behind the input board. It is a square silver box. Good Luck
Was this helpful?
Yes
No
Solution #2
posted on Sep 21, 2007
Not Rated)
docdave
Rank: Master
Rating: 91%, 13 votes
also i might add that the board does plug onto the signal board. the metal shield (or metal box
that is part of the board is soldered under neath) hense it cannot become (UNSEATED) don't know were you heard that as techman said there are 11 10uf@25volt small metal caps that need to be changed ( i always change all 11 with 10uf at 50volt) to repair all kinds of symtoms like jagged images around images,after a while or warmup image might go completly out of hor sync (pix goes sideways) I have been doing this
of 35 years and it's a chore (got my practice on mitz pip mod) i have the equipment (solder station) and i still have to be carefull. after you remove the plastic over the top ofthe hyper board as techman said it is a big metal box behind the imput board IE where you plug in you dvd,vidio game under the plastic over the top.DO NOT TRY TO PULL METAL BOX OUT WITHOUT UNSOLDERING THE METAL CASE UNDERNEATH don't know if your a tech or not but if i were a non tech i would not try this repair GOODLUCK DOC
Was this helpful?
Yes
No
Popular Solutions for Toshiba 51H83 51 in. Rear
Questions and Unsolved Problems for Toshiba 51H83 51 in. Rear
Do you recommend Toshiba 51H83 51 in. Rear Projection HDTV-Ready Television?
Answer
Answer
it seems my tv remote sensor is faulty as my remote cannot turn on the tv, but it can turn on other... (More)
Answer
no sound speeker not plug dont know where it goes. Model #51H83
Answer
When the tv is on part of the picture is blacked out in the top left hand corner of the screen,... (More)
Answer
I have a Toshiba 51H83 51-Inch HDTV-Ready TheaterWide Projection TV. The screen was broken and I... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
