Question about Epson Stylus DX4450 All-In-One InkJet Printer
Epsonstylus DX4800 taking paper in at an angle and messing up
I would really appreciate some help. My Epsonstylus DX4800 is constantly taking the blank paper in wonky and so every time I print something the writing is always at an annoying and unusable angle. I haven't been able to figure out what I can do to remedy this or whether it means the printer needs repairing.
Thank you
  • Anonymous May 24, 2009
    DX4450 printer takes first sheet paper straight through without printing and then 2nd sheet goes half way and it says it is jammed. it doen't print anything. It is taking the paper through wonky. Anyone any ideas?
    New Friend:
  • 37 Answers
Either you have some foreign object inside the printer which prevents the paper from feeding straight ahead(Try to inspect closely and remove the foreign objects if any), or else you have a broken part in the paper feed mechanism(which is very unusual for Epson but happens) and you have to take it to a repair.
Posted on Jun 23, 2009
    Scholar:
  • 134 Answers
Possible printhead issue.
Please do head alignment using the driver.
Posted on May 03, 2009
I have a IR2200I copier and paper keeps getting jammed when feeding through the machine where it should circulate at the side and come out onto the feeding tray. The paper just folds back inside the...
it sounds to me like the registration clutch is faulty. The symptoms of faulty clutch are: "Z" or "S" folded paper in section before drum ( in right side way door ) and image goes out out of center or in very big angle.
Its hard to say without seeing the machine.
You can also try to clean the paper path rollers in right side way of copier, but I don't think that will help!
I can only give you the service manual, write me on emma.servis@gmail.com.
Apr 29, 2011 | Canon iR 2016i Black and White Copier
Have an epson printer dx4800 with no software to install
HELLO, YOU CAN GET THE SOFTWARE BY USING GOOGLE SEARCH AND TYPE IN EPSON PRINTER DX4800 AND DOWNLOAD THE DRIVER
Nov 18, 2010 | Epson Stylus® DX4800 AllInOne InkJet...
Service manual for EPSON DX4800 inkjet printer
Sir,
There is no such manual for Epson Dx4800 only there is a rule that when ever get the cartridges refiled or change get your printer serviced with it ..
Aug 30, 2009 | Epson Stylus DX8400 All-In-One InkJet...
COPIER WONT COPY AS LITE INDICATES PAPER JAM DON'T SEE ANY PAPER AT ALL
Hello sir; Go back to wherever you pull out the paper, because you pull the paper in opposite direction therefor pull off the senser,go back where the paper jam put the senser back in right position.
May 30, 2009 | Sharp AL-1655CS Copier
Paper getting stuck
the reason the paper is going in sideways is because one feed roller has more pressure than the other
try cleaning the rollers with alcohol and cotton cloth
If that does not work remove the paper tray t
take your fingers and see if the feed rollers turn freely or turn in only one direction( some rollers are half moon and only turn a half turn)
Just try to make sure that the roller that is not working is in the same position and turns the same as the one that does feed properly
Jan 04, 2009 | Office Equipment & Supplies
Paper not feeding thru
If you do a lot of printing and have had your printer for a awhile more than likely you will need to replace the roller assembly (which is not as hard as you might think). Try making some adjustments and such first to see if you can get it to print properly without messing up the paper and printing some target pages. The best place to purchase a new roller assembly is through the manufacturer of your product because they should have exactly what you need. You can find what you need by typing in your make and the model number. Their website should also give you information about things to try first and also some good tips and suggestions about how to keep your machine running at optimal performance. The following link will take you to dell's official website . Let me know if you need further assistance.
If you do not mind please rate my help, I would greatly appreciate it. Thanks
Aug 23, 2008 | Dell A940 All-In-One InkJet Printer
The paper light is flashing
My printer is constantly getting jammed, spitting out blank sheets of paper in between every printed sheet, clicking and snapping, etc.
There are a few places to check for a jam - pull the paper drawer out and check there, take the toner cartridge out and you'll often find a sheet there that you cannot see from any other angle, open the little compartment at the back and check there and the usual paper sticking out of the output just enough to pull it out the rest of the way.
I'll be looking for a new printer this week though. I can't take the constant paper jams and sifting out the blank sheets when I'm printing 500+ statements a month.
Definitely NOT an office friendly machine!
Aug 20, 2008 | Lexmark E250dn Laser Printer
Epson Stylus DX4450 All-In-One InkJet Printer Logo
405 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
