This may sound a little trivial but if its an inkjet have ou taken the protective tape off the bottome of the cartridge? if its a laser make sure you have taken all the transportation pins/plugs/caps out/off as these physicaly stop the toner coming into contact with the drum.
if you have done the above check to see if its an original: some compatable/reman toners needs chips which tell the printer its there, if this is dislodged or faulty (ie wrong chip for the cartridge) then again it will not work.
if all else fails just try the normal screaming at it!
Was this helpful?
Yes
No
Solution #2
posted on Feb 25, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
HP laserjet 4101mfp error 30.1.19 copy\send disabled
Is a DELL 1700 LASER PRINTER a decent printer, and how much should I be willing to pay, is this a...
(More)
Is a DELL 1700 LASER PRINTER a decent printer, and how much should I be willing to pay, is this a very old printer ?
Thanks
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not...
(More)
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not necessary)for my home that at least does decent photos for my personal use. Any suggestions?
