Not able to install the software, tells me mdm.exe has stopped working and won't go any farther
I am trying to install my netgear wireless router. i am not able to get past the first step which is to insert cd and follow instructions. it tell me that mdm.exe has stopped working?
  • 611 Answers
Manual Setup: This option is best if you cannot use the wizard on the CD, are replacing an
existing router, or are technically knowledgeable. Follow the instructions in this manual to set
up your router.
Connecting Your Router
1. Connect the router, the computer, and the modem.
a. Turn off your computer.
b. Turn off and unplug the cable or ADSL broadband modem.
c. Locate the Ethernet cable (1) that connects your computer to the modem.
d. Disconnect the cable at the modem end only (2).
e. Securely insert the free end of the cable (1) into a LAN port on the router, such as LAN
port 4 (3).
f. Securely insert the yellow cable (5) that came with your router into the yellow Internet
port of the router (4) and the other end into the modem (2).
Setting Up Your Router for Internet Access
To access the router using its login name and password, follow these instructions.
1. Connect to the router by typing http://www.routerlogin.net in the address field of your
browser, then click Enter.
For security reasons, the router has its own user name and password. When prompted, enter
admin for the router user name and password for the router password, both in lower case
letters.
Enter the user name and password. The router will display its home page.
When the router is connected to the Internet, click the Knowledge Base or the Documentation link
under the Web Support menu to view support information or the documentation for the router.
If you do not click Logout, the router will wait 5 minutes after there is no activity before it
automatically logs you out.
Set Up and Test Basic Wireless Connectivity
Follow the instructions below to set up and test basic wireless connectivity. Once you have
established basic wireless connectivity, you can enable security settings appropriate to your needs.
1. Log in to the router at its default LAN address of http://www.routerlogin.net with its default
user name of admin and default password of password, or using whatever LAN address and
password you have set up.
2. Click the Wireless Settings link in the main menu of the router.
3. Note that the default SSID is NETGEAR.
4. Set the Region. Select the region in which the wireless interface will operate.
5. Click Apply to save your changes.
6. Configure and test your computers for wireless connectivity.
Program the wireless adapter of your computers to have the same wireless network name
(SSID) as the router. Check that they have a wireless link and are able to obtain an IP address
by DHCP from the router.
Note:
Posted on May 02, 2009
Expand range extender
You can install a wireless range extender. Try a Netgear Dual Band WiFi Range Extender, this device extends the wireless range of your existing wireless router, it connects to your wireless router using a wireless connection without the need of a LAN cable.
May 19, 2013 | TP-LINK TL-WR1043ND Router
I have a netgear wireless USB 2.0 and i am trying to get it connected. When I try to install the software for it, it says my computer is not compatable with the software? How do I fix this? I am running...
My advice is install this netgear software in Windows XP Operating System . so you try to convert your PC to win XP, then install this software. You will able to access the wireless connection
Thanks
Aug 13, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
What hould be done to the software dwnloaded from netgear 4 route
You don't need a CD to configure your Netgear wireless router.
Just connect a network cable to your computer's 10baseT port and the plug the other end of the cable into the Netgear's 10baseT port.
Assuming your network card driver has been installed, configured and working, boot up your computer, and start your browser and enter this address http://192.168.0.1 Then enter the
user login = admin
password = admin
This enters you into the various configuration pages.
If you have changed the login and password and don't remember them, then you can reset the router to the factory defaults by the following steps.
Power off the Netgear, press and hold the reset button (you need a sharp pointer) on the back of the router, then power up the Netgear router, wait seveal seconds until the LEDs stop flashing, then release the reset button.
Dec 30, 2008 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
CONFIG. NETGEAR ROUTER
did you install the modem software and the router software? you may also want to use the network wizard to see what it tells you. are you wired or wireless at the pc? if a laptop, did you install the wireless connection (either a usb or internal)?
here is how to set up the network. netgear is the same way.
http://lifehacker.com/software/wifi/geek-to-live-set-up-a-home-wireless-network-162754.php
Oct 20, 2008 | NetGear WGT624 Wireless Router
Netgear router DG834GT
To do this you do not need the installation disk.
1. Click Start, Run, CMD, enter. Type 'ipconfig /all' and write down or remember the ip address for your default gateway.
2. open your browser and type http://192.168.1.1 (or whatever the ip address is for your default gateway.) hit enter.
3. In the username and password login screen type admin for both. If this doesn't work, try using admin for just the password, if no luck try again for just the username, until you are logged in.
4. Go to wireless settings, security, and find the part where you can set your wireless password. It is also a good idea to use wpa personal instead of wep, because it is a stronger encryption method.
Apr 15, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
301 people viewed this question
David Payne
David Payne
