Question about Goodmans GMP33005 MP3 Player
Stalls at the initial 'Goodmans' screen
After a couple months unimpaired use, suddenly this morning my mp3 stalls at the initial 'Goodmans' screen - where ordinarily it would go on to my playlists, etc. Turning it off again, the 'Goodmans' screen goes unlite and only then off. I do not know if this is significant. Any advice?
260,000km Car looses power and stalls. will restart then stalls again. Suddenly starts ok and runs ok. Usually when fuel is low but tank is not dry.Gas gauge doesn't work.Fill tank at 500 km on trip...
Did you do anything to repair the mas air flow sensor code or did it go out by itself?If you did not replace it or clean it you should get some mass air flow sensor cleaner and clean it out.You can get this at most part stores.If you are getting this code then you need to repair this problem.This will cause the car to loose power and it can be intermittent.Hope this helps.Good luck.Let me know if you have anymore questions.
Sep 21, 2010 | 2002 Pontiac Grand Prix
95 bonneville stalls then starts then in about 5 mins. Stops again. Replaced fuel pump a fue months back. Best luck was replacing relay for fuel pump. Now that doesn't help.
If your check engine light is on, find out the codes. I would have the fuel pressure checked again, first run the car until it stalls again and check it. I've installed pumps that went bad in as little as a couple days
Jun 16, 2010 | 1995 Pontiac Bonneville
I have a 1999 Audi A4 2.8L - Last month it was stalling at low RPM after initial start idle kicked down. I put in fuel injector cleaner and it fixed the problem. Yesterday it returned and is shaking before...
Crank shaft sensor or air mass meter, is this a v6? I had the 2,6 a4 same fault same miles funny enough. changed the air mass meter is was ok after that. thing is they have so many sensors, you need to get it on a diagnostic machine to be sure.
Jan 13, 2010 | 1999 Audi A4
Windstar 2001 had it since new. over 120,000 miles suddenly started stalling cuople months ago had alternator replaced, bearings anything on the serpentine belt incl oil and water pump checked or replaced....
The problem with your van is the CAM Sensor, I believe the noise you are hearing is kind of a chirping sound. I just had mine fixed (12/19/09) it was about $150 for parts and labor from a local Mech. not a dealer.
Dec 17, 2009 | 2001 Ford Windstar
My sony nwz-s615f keeps stalling
i installed sony program but i cant buffering it, can you tell me whats problem
Jul 10, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
2002 Lincoln LSE 3.9L 124,000 MI. stalls after a stop or hard braking.
Hi.
This may be a "sticky injector"
This would cause overfuelling - and a sudden rise in RPM. The ECU will see this and compensate - by shutting the injectors down lower - , which then stalls the vehicle.
Worth a try runnig cleaner through them.
Jul 10, 2008 | 2002 Lincoln LS
Curtis MPS1015
the only thing i see is that you have a defective mp3.....i'd return it for another one
Dec 29, 2007 | Curtis SMP228 MP3 Player
Screenwriter3 stalls at startup
I had a similar problem a couple weeks ago. We found that for some reason the printer was on "Pause" on our main network PC. This was of course effecting the whole network. Hope this helps!
Oct 05, 2007 | Xante ScreenWriter (Refurbished) Laser...
Goodmans GMP33005 MP3 Player Logo
27 people viewed this question
Top Goodmans Audio Players & Recorders Experts
Pavel Pranovich
Pavel Pranovich
Tom Chichester
Larry
Are you a Goodmans Audio Player and Recorder Expert? Answer questions, earn points and help others
