Question about Dryers
The heat just stopped working on my Estate Mod #TEDS840PQ
Estate Whirlpool Dryer, 2 years old, turns but is not heating.
SOURCE: Clothes dryer not heating
Hi I have a top vent Kenmore dryer. That seems to be heating up on and off. I can see the glow plus trying to ignite the gas I think what do you think is wrong..kj
Posted on Aug 28, 2008
SOURCE: whirlpool dryer won't heat how can I fix?
Hey, I just read an article online titled, Testing for 240 Volts to Your Dryer - Without a Voltmeter, here's the link http://www.davesrepair.com/DIYhelp/DIY240Vtester.htm
I am not sure how you could test anything else though, such as the thermal fuse or thermostat, without the Volt/Ohm Meter. They are about $10 at any big box home store--we just went ahead and bought one.
Posted on May 31, 2009
dniro592006
  • 121 Answers
SOURCE: Whirlpool Estate Dryer TGDS840JQ1 dryer runs but
when you say heat up is it at least getting warm...
you may have a igniter gone bad or your thermostat may have failed... your igniter is what has to ignite the gas to burn to make it hot. If its electric then your heating coil has failed and needs to be replaced
Posted on Jun 09, 2009
canbruce75
  • 1776 Answers
SOURCE: Dryer Stopped Heating
Use a multimeter to check the heating element. You can't always go by looks. Check continuity and if there is none, the element is defective. Another thing to check is the thermal fuse. It is about an inch long and is usually attached to the exhaust duct. Use the meter to check it as well and if defective, replace it. Sure hope this helped and best wishes.
Posted on Jul 28, 2009
jsrock516
  • 5911 Answers
SOURCE: My Whirlpool Imperial Series Dryer is 4 years old. NO Heat.
It may not be the heating element causing your problem. There are other components that can fail that will cause the same symptoms. The following link explains how to troubleshoot a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer will exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the washer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum. All dryers are not constructed the the same. Regardles of location, the Heating Element is located inside the heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals. If either the TCO or Hi-Limit Thermostat are determined to be bad, replace both components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace. All these parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop around for the best price.
If you have any questions, please let me know. Please inlcude your complete model number (located on a nameplate around the door opening) when asking questions. I hope you find this information helpful.
Posted on Sep 07, 2009
My dryer has heat but does not dry
is the drum turning? if not you must replace the strap that turns the drum. if it is heating and the drum is not turning , that could cause a fire.
Sep 30, 2014 | Estate by Whirlpool EED4100XQ Estate...
Dryer will not fire. Fuse is good and door swithch seems to be good. When you push the button in to turn on nothing happens. Dryer is just over a year old. Any suggestions.
then it must be either in the switch or the motor has burned out is the heating coil heating though the barrel isnt turning ??
Feb 15, 2011 | Estate EED4400WQ Dryer
No heat in dryer. Vents are clear and clean. Just purchased this dryer 2nd hand. Unti is 3 years old. Could I have wired the plug wrong?
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpgCheck the continutity on the thermal fuses and replace the one that has no contiunity.
Feb 12, 2011 | Whirlpool Dryers
The dryer runs but there is no heat coming out of it
lllThis is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpgseth765_0.jpg
Jan 18, 2011 | Maytag Atlantis MDG6400AW Gas Dryer
Estate by Whirlpool. TGDS680EQ3. Dryer turns on but air blows cold. Any insights?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 04, 2010 | Estate TGDS680EQ Dryer
No heat to dry clothes. Dryer is 4.5 years old. The dryer is made by Estate (by Whirlpool). Model # TEDS740PQ0
By far, on that machine the "thermal fuse" accounts for more than 50% of all heating problems.
Unplug machine and remove back cover. On the air chute in the middle back of the dryer you will see a small narrow bakelite device with 2 wires connected to it. It is held in with 1 screw.
You will need an ohm meter to test it, or remove it and have an
appliance parts house test it for you. If bad replace.
Whirlpool part #3392519.
The second common problem on that dryer is the heating element and can be checked with an ohm meter as well.
On rare occasions one side of the 230 volt supply is out.
The side running the motor is o.k. but the heater side has lost power.
Caution: your dealing with 230 volts here. remove plug receptacle cover and check with a volt meter for power.
Nov 03, 2009 | Estate Dryers
Whirlpool Estate Dryer barely heating
Four wires on the new cord.
Red and Black go to outside screws on the terminal.
White goes to the middle terminal.
Green goes to the cabinet ground screw near the terminal plate cover.
Mar 11, 2009 | Whirlpool GEW9250 Electric Dryer
ESTATE DRYER BY WHIRLPOOL
you might have a high limit or thermal fuse that has failed due to overheating. these will go bad when there is a lack of air flow, probably from a pinched off or plugged vent. it could be a bad element but not as likely as the thermostats. if you can get the element housing out and check all of them with a VOM meter, it will show you which one has an "open" circuit.
Dec 29, 2008 | Estate TGDS840JQ Gas Dryer
Dryers Logo
236 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
