Question about Gateway M675 Notebook
My gateway laptop will not go to the internet or control panel. just stops responding.
  • 4 Answers
Have you tried restoring? use the gateway restore CD to install a fresh system
Posted on Jun 20, 2009
  • 123 Answers
Run a full virus and malware check
Posted on Apr 19, 2009
My gateway laptop cant connect to the internet. _When I plug a cable, the red light in the port does not respond _ The WIFI does not respond
Hello John,
It seems that: 1. Your LAN controller and the WiFi controller could be disabled in your BIOS setup.To re-enable them, if applicable,
  • Press the F1(or F2 ) key repeatedly after restarting the computer to enter the BIOS setup.
  • Navigate through your BIOS and locate the settings for LAN conroller and wireless, and select Enabled to enable them.
2. You may not have the appropriate drivers installed on your laptop for your network controllers. Upon further investigation, your laptop runs on the following network hardware:
  • ActionTec IEEE 802.11b network card installed in Mini PCI expansion slot
  • Broadcom BCM94306 IEEE802.11g network card installed in Mini PCI expansion slot
  • Broadcom BCM94300 IEEE802.11a/g network card installed in Mini PCI expansion slot
Download and install your drivers for the hardware above from: Wireless Drivers(Broadcom BCM94306) from http://www.soft32.com/download_175098.html Broadcom BCM94306 10/100Mbps LAN drivers from http://www.broadcom.com/support/ethernet_nic/downloaddrivers.php
Hope this solution helps.Good day.
Jan 14, 2011 | Gateway M305CRV Notebook
My display is very dark - can barely see pictures on the display. The fn brightness button doesn't respond. Gateway laptop model M305CRV. Please help
control panel,display,settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general
dpi normal size,larger size or custom settings
hope this helps
Nov 11, 2010 | Gateway M305CRV Notebook
System recovery on gateway laptop now no internet
do u have a switch enabling/disabling wifi?
if yes, turn wifi on!
Feb 05, 2010 | Gateway NX860X Notebook
Billionton USB : Class 1 USB Bluetooth adapter
before you try any step i tell you please disable your antivirus and firewall.
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 01, 2009 | Billionton Long Range Bluetooth USB...
Gateway laptop, can't connect to internet
Network controller in SouthBridge chip on motherboard needs REFLOW or replacement.
Basically board needs service.
Apr 02, 2009 | Computers & Internet
Can't connect to internet with laptop
CHECK THE ANTIVIRUS AND THE FIREWALL IN THE WINDOWS AND IT IS IN THE CONTROL PANEL.
WHILE IN THE CONTROL PANEL LOOKING IN THE FOLLOWING FOLDERS:
DEVICE MANAGER
PROBLEMS REPORTS
NETWORKING AND SHARING
SECURITY CENTER
SYNC CENTER
WINDOWS DEFENDER
WINDOWS FIREWALL
MOBILE ME
ROD
Mar 13, 2009 | Computers & Internet
My computer audio gateway speaker stop responding
First Insure that the plugs are in the proper ports of the computer. Second, go to Control Panel>System>Hardware>Device Manager, Look up to see that the Audio Drivers are functioning Properly. If not, then you will need to search and download the proper drivers for the Audio Device you have, Whether its on board audio, or a PCI Card, you will need to insure that you have the right drivers for it. If you have more information about the type of Audio Device for your computer, please respond with that information and I can troubleshoot with more detail.
Jan 20, 2009 | Gateway Edison Computer Speakers
GatewayW323-UI1
Was the program and modem working before ?
If so then they may have been a change in your program environment. If you do not remember what changes were made or what other programs/changes caused since it last worked -then try reverting to the earlier environment by doing a Restore to a date when you last rembember it worked.
May 23, 2008 | Gateway MX3228 Notebook
No internet connections found
First, you need to be sure that the wireless networking adapter is enabled.
  1. From the Start menu, click Control Panel.
  2. In Control Panel, click Network Connections.
  3. Check the status of Internet Connection and Local Area Connection that indicates WIRELESS (it's most likely a Broadcom product).
  4. If either item says disabled or not connected, right click and select ENABLE from the menu.
  5. Close all open dialog boxes and windows.
  6. Use the Windows XP Wireless Zero Configuration, located in the system tray at the bottom of your screen, to test the adapter.
  7. Double-click the icon with one monitor and 3 wave lines on the right side. Your network should be detected.
If that doesn't pan out, post back and I'll give you Plan B.
May 19, 2008 | Gateway 4530GZ Notebook
Gateway M675 Notebook Logo
73 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
