Question about Acer Aspire 1353XV Notebook
HOWE DO I REPLACE THE HARD DRIVE ON ACER 1353XV LAPTOP
    Problem Solver:
  • 9 Answers
There should be a place on the side of the laptop, I'm not sure which, that has the HD in it. I know on the Dells, there are a couple of screws holding it in from the bottom. It should just pop out.
Posted on Apr 19, 2009
Remove hard drive Acer aspire e1-472 laptop
In that case it is probably under the keyboard.
6 minutes into the video you can see the hdd
how to replace hard drive laptop acer Aspire E1 472 replace RAM
Mar 13, 2015 | Acer Aspire E1-472G-6648 Misty Silver 14"...
How do I replace the hard drive on a acer aspire 1362lc laptop
There is a little cover on the back of the laptop that houses the hard drive. Take the screws out, the hard drive will be exposed, there may be screws holding the HD in. Remove the HD and replace. Reinstall the operating system.
Mar 01, 2015 | Acer Computers & Internet
How do i take out the hard drive on a acer aspire 5552-5686
Follow the bellow link for appart the laptop,
http://www.insidemylaptop.com/taking-apart-acer-aspire-5100-laptop/
Removing hard drive:
1. Pull the hard drive to the right side until it's disconnected from the motherboard.
2. Lift up the hard drive.
If you are replacing the hard drive with a new one, you'll have to transfer the mounting bracket to a new drive. Hope this helps, .Reply me for another instruction. Thanks.
Feb 25, 2011 | Acer Computers & Internet
Ca i replace the hard drive in a acer aspire one 8'9 with one from a hp mini110? thankyou
Hi
most laptop hard drives are same size 2.5
but the hard drive from the hp may have a different face plate or holder but can easily be removed
also the os system on the hp will not load up and work on the acer
you will have to
either use windows easy transfer to copy your entire hard drive files and save onto spare hard drive
so that when you replace and format different hard drive you can then transfer it back onto new hard drive
or if pre windows 7 os you could use something like norton ghost to copy your existing operating system and files and make a system image and store on spare hard drive then when you replace the hard drive
you boot up with norton ghost and ask it to find the image and restore it to the new drive
Or if your lucky enough to have the operating installation disk or can get your hands on another retail installation disk you can reload a new operating system using the product code which should be on a sticker on the base of your laptop
Hope this was useful to you
Hard drive is no good cant connect
Re-seat the hard drive, this may correct the problem.
If the go to the BIOS setting and check if the BIOS can detect the hard disk, if not the the hard disk is faulty.
To get your laptop working, replace the hard drive and install Windows on the new hard disk, then install the Acer laptop's device drivers and your programs.
To install the laptop's device drivers then -
Download the drivers from the Acer WEB site.Make sure you select the model of your laptop and the XP or Vista version ofthe drivers you that require and it matches the Windows version that isinstalled on your laptop. Use this link to get to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
You may need to download the drivers using a computer that has Internet access, then copy these drivers to the Acer and install these drivers.
Feb 07, 2011 | Acer Aspire 5500 5570-2609 Laptop
What type of hdd do I have to get to upgrade my 1353xv is it a sata one
I just had a look in service manual for you. It isn't SATA drive It's a IDE hard drive. When you look to buy one just look for 2.5 inch IDE laptop drive. I hope I helped. Good Luck!
Apr 27, 2010 | Acer Aspire 1353XV Notebook
Replace hard drive acer netbook 8 gig
Back up all info
Insert CD / DVD Win OS into Cd / DVD drive
Shut down laptop / remove battery / depress strat button several times to de-energise system.
Remove tiny screws under the laptop to access HDD, Be very careful prizing off cover so as not to break it.
Remove HDD carefully, you may need to unscrew HDD
Replace with new HDD / replace cover
Start Laptop and depress F1 or F2 to get into bios, alter boot sequence to CD as first boot.
Follow on screen instructions to format HDD / load Windows.
You must have a legit copy of the Windows disc and CD key
Dec 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
Bios not find hard disk
If the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
May 24, 2009 | Acer TravelMate 2303LCi Notebook
I just wanna know how to replace an acer laptop hard drive with a bigger one
Usually you
1) purchase the new hard drive
2) look around the base of your laptop to find where the HDD is, if you look at the manual which im sure acer will have on its site it will show you
3) usually 1 or 2 screws are unscrewed and you slide out the hard drive, it will be in a special holder
4) unscrew the old hard drive and insert the new one and secure it in place like the old one.
5) insert, re-do screws up, turn on laptop.
this new hard drive wont have any information on it so you will need to reinstall windows on that drive.
Jun 06, 2008 | Acer Computers & Internet
Acer Aspire 1353XV Notebook Logo
130 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
