Question about HP OfficeJet 6110 All-In-One InkJet Printer
How do I fix an "error 442" on the fax part of my hp 6110 all-in-one
  • 25 Answers
Per HP:
Definition
An error occurred during transmission after one or more partial pages were sent. The sending machine was unable to restart the control channel connection(handshake) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page. It can also be caused if the receiving fax is using a fax format incompatible with the HP fax (usually during color faxing).
Solution
Try the fax at a different time when telephone line conditions have improved.
Posted on Apr 23, 2009
My officejet 4500 keeps giving me an error code 350 when trying to send a fax. how do i fix this?
try to disable Error Correction Mode (ECM).
to do so:
Press Menu . Press the Right Arrow (>) until Advanced Fax Setup appears. Press Enter . Press the Right Arrow (>) until Error Correction Mode appears. Press Enter . Press the Right Arrow (>) until Error Correction Mode ON or Error Correction Mode OFF appears. Press Enter . Send another fax to verify that the ECM is enabled or disabled.
Sep 19, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Wont send message. Error no 442
This error indicates that the receiving machine (receiver) cannot receive the fax you just sent. The reasons might be unexpected shutdown of the machine (Receiver's machine) just before it completely received [or partially printed] the file you had sent or power failure during the process.
Another reason is, when we send color fax from Hp machine to another Machine (non-hp), this happens due to incompatibility issue.
Solutions are;
1. Restart both the machine after deleting the recently sent/received fax.
2. Send black and white only, not color.
3. Try again after the phone line seems not much busy which means when there's better transmission capability.
Good luck.
Thanks for using FixYa.
Jul 06, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Hello! My fax will not answer on my HP OfficeJet
Please oress the button "auto awnser" on the printer which is on the left of the printer front panel under FAX. Once we press the button the libht should glow.
This will fix the issue.
May 17, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Black page printwhen I try to copy or fax from my hp 6110 printer
The printer isn't shot, but the scan assembly is, it sounds like either the scan lamp is dead or the sensors in the scan assy. You should also be getting a scanner error. I would try the reset, powering up with either the #3 or #6 buttons pushed, and see if a reset helps.
Jun 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp fax/scanner # 6110
Hi Judy,
The only document I found at HP.com that may seem to address your issue is the following:
A 'Paper Mismatch' or 'Paper too Narrow' Error Occurs While Receiving a Fax
Have a look at the suggestions on that web page and see if anything there helps. Post back you results and good luck.
Nov 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Laserjet 3330 is resulting in fax Comm Errors 327, 232, 442, 356, 421 Comm Error 327 is always with fax # 780.467.6516. i can not fax to this number and when i receive from it, it always prints a Fax...
232-A communication failure has occurred between the two machines.
327-*Reattempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
356-The remote user has pressed the Stop key, causing the session to be aborted.
442-An error occurred during transmission after one or more partial pages had been sent. The transmitting machine was unable to restart the control channel (handshaking) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page but can also occur if the receiving fax is using a fax format that is incompatible with the HP fax machine (usually during color faxing).
Aug 15, 2008 | HP Computers & Internet
How to control/suppress transmission(fax) report in HP office jet 6110
I assume that the fax report is printing on every fax and you don't wish to see it?
In your setup menu if you go to advanced fax setup and then the first option will be automatic reports setup. Hit the okay button and then you can choose when the report will print out. In your case you would scroll to the last option which is 'off'. The reports should no longer print. If you did want to see when there was an error you can set it to error only there as well.
Feb 27, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
311 people viewed this question
Seeker5211
Seeker5211
