Compaq Presario SR1313CL  PC Desktop
Problem for Compaq Presario SR1313CL PC Desktop
WHATS THE HARD DRIVE LIMIT OF A COMPAQ PRESARIO SR1315CL
By csj2085 on Apr 19, 2009
I'D LIKE TO REPLACE MY HARD DRIVE WITH A BIGGER ONE..
Comments:
Apr 19, 2009
- Thanks guys ..I'm on my way to get a 320 right now
Apr 19, 2009
- Many thanks for all the help.....
Clarification Request
Posted by Fritzelly on Apr 19, 2009
Whats the model number of the compaq and which OS are you using?
Best Solution
posted on Apr 19, 2009
Very Helpful)
timothy_farl
Rank: Wiz
Rating: 84%, 106 votes
Hi there. There is no limit to the size of the hard drive that you want to install. It just depends on your budget, and whether you want an internal drive or an external drive. I have a desktop which uses an internal 160GB as my main drive, and a 750GB external USB drive. The make of your pc doesn't make any difference.
The good thing about having an external drive, is that I can connect it to any desktop/laptop and still access the files.
Hope that helps.
Tim
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
Helpful)
dante777
Rank: Guru
Rating: 91%, 428 votes
The motherboard of your computer has two IDE and two SATA connections.
There is no upper limit of the drive size (at least nothing you have to worry about if you have WInXP, Vista or Linux installed)
Attention!!! - I heard from many people that HP (Compaq) has disabled the SATA connectors on your motherboard (ASUS A7V8X-LA)!!!
If you want to be on the safe side (and I would definitely recommend that) go and get an IDE drive. There are many good drives around with 500GB of storage.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Was this helpful?
Yes
No
5 people thought this was helpful
Solution #3
Helpful)
DickCanFixIt
Rank: Guru
Rating: 91%, 796 votes
There is no practical limit to the capacity of the hard drive on your system. Very old systems had trouble recognizing large capacity drives but your system does not have that problem. As long as you put a standard physical size 3.5" drive in there it will work. Even if some extreme misfortune happened and your computer would not recognize it right away the manufacturer includes software to overcome that problem.
Was this helpful?
Yes
No
Solution #4
Helpful)
mrninja
Rank: Wiz
Rating: 80%, 68 votes
to check your size now-- click "my computer" then alternate click on the drive, then properties you will see the amount of available space and other stuff
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Compaq Presario SR1313CL PC
Questions and Unsolved Problems for Compaq Presario SR1313CL PC
Do you recommend Compaq Presario SR1313CL PC Desktop?
Answer
Answer
I'm trying to find out id of usb ports (e,f,etc) for acer ax1700-u3700a. Manual wasn't provided with... (More)
Answer
Yesterday and today I can not access my yahoo mail (ctrl-alt-del shows ''not responding''). I have... (More)
Answer
have an older jiffy ice auger its starts, but does not stay running. when i start it, it runs and... (More)
Answer
don,t write DWD-R+R-RW disk SH-S222A WinXP3, CD-R,RW ok ... (More)
Answer
PC Model#Gateway mfatxnin das 300x ...I don't know what happened but now all i get is a black screen... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Desktop Experts
Top Computer & Laptop Repairmen
in , CA
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
