FixYa.com
Tags:
Scanners
Generic problem for all Scanners
My CanoScan D1230U has stopped working (by 5 users)
posted by jacob1230u on Sep 19, 2007
Resentley fter years of use my CanoScan D1230U has stopped working. Everyting was connected properley but it still didn't work.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by Guest, posted on Jun 25, 2008
All of a sudden all power gone, Tried unplugging and replugging. NG.
Comment by Guest, posted on Jan 07, 2008
scanner stopped working
Comment by Guest, posted on Dec 13, 2007
Yep, just the same with my Canoscan LIDE 500F. Tried all I can think and no solution.
Comment by Guest, posted on Nov 15, 2007
the following error appears on screen; can't connect, error 10065 not connect, napping.
Solution #1
posted on Jul 03, 2008
Not Rated (0)
dalefty1
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
What kind of oil should be used?
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Feb 22, 2008
Not Rated (0)
batman4oz
Rating: 0%, 0 votes
I had this same problem with my N1240U...just stopped working for no reason. After trying several 'fixes' I discovered that all I needed to do was download the current update for the scanning software, Scan Gear Toolbox!!
Now it works fine...but for all the pressure I have put on the glass, trying to get magazines down flat, that now causes the scanner to drag on the inside of the glass!
But, that is another problem....that needs a solution!
^^X^^
Solution #3
posted on Sep 21, 2007
Not Rated (0)
DANIYAL
Rank:Wiz Wiz
Rating: 78%, 207 votes
the scanning lamp is not moving oil it
This Problem Also Relates To: HP ScanJet 3500C Flatbed Scanner HP ScanJet 6200C Flatbed Scanner HP Scanjet 8250 Flatbed Scanner Memorex MEM48U Flatbed Scanner Panasonic Mdwd with Expansion Base Finger Print Scanner & Mag Stripe Reader Acer AcerScan 640BU Flatbed Scanner Acer ScanPrisa 640P Flatbed Scanner
Can you Help with these Scanners problems?
HP Scanjet 5500c Flatbed Scanner
can't fax
Help! Everytime I try to fax a... Answer This...
Mustek Be@rPaw 1200CS Flatbed Scanner
bear paw scanner
How do I know if my bear paw... Answer This...
Canon CanoScan LiDE 30 Flatbed Scanner
CanonScan Lide 30 flatbed
Installed with help of Canon... Answer This...
Scanners
help
do you have scanner codes Answer This...
Scanners
canon Scanner canon F914900
i need driver of canon Scanner... Answer This...
Repair Service
Find Scanner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
