Question about Indesit W 123 Front Load Washer
My Indesit WE165 fills up with water
During any wash cycle my washing machine fills with water. It drains ok but it makes the drum extremely heavy. I have tried cleaning the hose and i have checked tha the outside pipe is running free of obstruction. Can you help?.
There is a little hose that runs from the back of the pump
up to a pressure switch that contols water level in drum
I had a problem similar to this and found hose had split making
the drum overfill, replaced hose cured problem
Posted on Apr 29, 2009
My Indesit washer model no IWC61651 ECO fills with water but does not do the wash cycle will run for hrs keep filling water but programme never moving
Lynne,
The drain hose for the washing machine is pushed too far down the standpipe causing the water to siphon out of the machine. Look at the diagram below:
-make sure standpipe is at least 18-30inches high
-only push drain hose in 4-6inches
Aug 16, 2016 | Indesit Washing Machines
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
Indesit WDG1295W. Why doesn't it drain?
The pump and connecting lines could be choked with debris the filter didn't catch.
Dec 26, 2015 | Washing Machines
Water drains during wash cycle. I have used this washer for many years without a problem. About two months ago I noticed that the water level in the drum was going down during the wash cycle. Last week I...
Take the drain hose out of the drain pipe and put it into a sink to test the machine
If that works make sure that the drain hose is being allowed to breath (ie let air into the main drain pipe so that the machine does not set up a syphon).
Jul 16, 2009 | Whirlpool Washing Machines
No drum movement during wash/spin cycle, although it fills/drains
brushes need replacing in motor. Usually cheap enough to buy and do yourself.
Jun 02, 2009 | Hotpoint WMA46 Front Load Washer
Indesit wd125 drum wont turn
check your pump it may not be working
Dec 18, 2008 | Indesit W 123 Front Load Washer
Washing machine fills with water when not in use.
You have an open solenoid on your water valve where the fill hoses connect. Change the water valve and you should be good.
Jul 25, 2008 | Washing Machines
Indesit 1600 WE165 washing machine - filling with water after wash
Doesn't sound like a filter problem to be honest. If the water that's coming in is clean, you're probably looking at a leaky inlet valve. With the machine unplugged from the mains, remove the top, then look for the valves (which are the items that the inlet hoses screw into). One at a time, remove the rubber hoses that connect them to the various bits of the insides of the machine to identify which valve is leaking. New valves are available quite cheaply on the net, and are easy to install. If the machine is filling up with dirty water, it's probably being siphoned back in from the drain. The drain hose mustn't be a tight fit in the standpipe it hooks into and mustn't poke in too far. Also, the standpipe needs to be reasonably tall. Have a look at page 7 of http://imagebank.indesitcompany.co.uk/pdf/service/HBWM81.pdf - it's a manual for a different model, but the drainage requirements will be the same. A.
May 13, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
147 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
