Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
I have my 42inch AVOL HDTV hooked up to my computer and my PS3. When I watch blueray or play PS3 the TV works great. no problems. WHen I hook it to the PC and look on the web, or play World of Warcraft I have a bright green line down the right side of my screen. I have it hook up with DVI to HDMI, so the signal stays all digital.
  • 53 Answers
SOURCE: Sharp 46D62U incompatability
Most likely a defective Main Board. I suggest calling Sharp 1-800-237-4277 to locate your local Sharp Authorized Service Center.
Posted on Mar 14, 2008
SOURCE: hdtv stb issues hdmi - dvi for Acer AL2416W
Buy a name brand STB !
Posted on Apr 15, 2008
SOURCE: Hooking up a PS3 through HDMI
what you have to to is hold the start button till the TV shows 480i then you will have what you need, it will set up for your tv
Posted on May 03, 2008
  • 117 Answers
SOURCE: My lc-37p50e aquos is a great tv, but when playing
1080p is full hd
Posted on Apr 20, 2010
SOURCE: Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Posted on Apr 25, 2011
What channel do I put my LG TV on to connect my Sony blueray player to watch netflix
channel is not the correct path
you need to be thinking What input source do I need on the tv
atv dtv - THIS IS FOR AN ANTENNA CABLE
hdmi1 hdmi2 hdmi3 av1 av2 these are input sources
look on remote for input or source button .
HDMI 1
Apr 18, 2016 | LG 42LC2D 42 in. LCD HDTV
HOW TO HOOK UP HDTV CONVERTER TO PLAY VIDEO ON TV
Need more specifics. What TV do you have? If you just want to hook up the blueray, you can use an HDMI cable from DVD to TV, or red-blue-green component video cables, or red-white-yellow cables.
Feb 25, 2011 | Samsung BD-P1500 Blu-Ray Player
No sound from my AVOL tv
U have to use the Connector labeled RF-1 U have to screw the connector on. I had the same problem
Jul 11, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Samsung DLP TV and PS3 Problem
Would you please read the manual of TV & PS3 for HDMI cable's
version.
If you match that version, can play.
Dec 27, 2008 | Samsung DLP HL-P5663W 56" TV
Audio Trouble hooking PS3 up to HD
Hi there, Have you checked that the HDMI Cable is inserted into both your PS3 and HDTV correctly ? if the cable moves about in the HDMI port that causes static sometimes ! Also check that your cable isn't damaged.
If the problem persists. i would just Use your Composite (Red,Green,Blue) connection from your TV to your PS3. you said it doesnt have static problems. and Using the composite cable you can still get the Full 1080p Resolution on your TV that the PS3 can Up-Scale to!
Hope this Helps ?!
Oct 27, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3
Have both the AV cables and hdmi cables hooked up from the tv to the ps3. On the TV Menu goto the av station which is different from the HDMi station...From the ps3 menu screen gotot settings then to video and audio and select hdmi then back to the tv menu and select the hdmi station and the ps3 main menu should be seen and you are all set
Jul 11, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Invalid format
my xbox 360 when hooked up to my 42inch Lc7d get sound but displays invalid format error,  how can this be fixed?
Jul 07, 2008 | LG 42LC2D 42 in. LCD HDTV
Hook up surround sound system to entire system
Is the 42 inch a lcd tv. is the blueray player & ps3 hooked up in the hdmi inputs?
Jun 01, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
376 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
