Question about Steam Fast SP-660 Iron with Auto Shut-off
Worn out pad
I have had this for so long that I have worn holes in the cover and pad--where can I buy new ones- the steamer works just fine on ANY water.
I order my replacement press cover pads online at "Sew4Less" - silicone covered pad - they sell for $12.95 /ea plus $5.00 shipping (measures 24"X9") and fits my Steam Press SP660 perfectly.
Posted on Mar 13, 2010
My rowenta steamer is not producing steam but tubing getting hot when I turn on steamer. Suggestions?
see this causes and fix it. God bless you
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Feb 03, 2013 | Rowenta Commercial Garment Steamer - White
How to open is 9050 rowenta precision valet to descale
Well this was helpful but also HELLfull! I guess because I have a 9050 !! I took out the screws & could not remove the hose it was attached with 2 clamps & a washer! I put the whole darn thing in my tub ( I have a sprayer in there) and yes tons of sand, black stuff and cloudy water came out. I had to do this 8 times with the hose attached! Awkward & a mess but it did finally come out clear. BTW I did it through the hose & the bottom hole. On the last run through, after my whole bathroom is soaked including me, the hose popped out! I was cracking up! turns out on the 9050 you simply push down on the ribbed hose covering and it releases. This IS NOT in the manual either. But I'm happy my steamer's like new again & live & learn ;o)
Oct 09, 2012 | Rowenta Commercial Garment Steamer - White
PS-200 Iron with Auto Shut-off: Can you really fix problems with a steamer? Is ...
The thermostat is the problem, I used aew3656's solution posted elsewhere in FixYa, and took care of the same problem on my steamer, just take out the damaged thermostat and use it as a sample to get a new one from any electronics supply store, BTW don't forget to buy thermal grease, it helps dissipate the heat so your steamer won't overheat, and the thermostat wont't go off every 2mins.
May 16, 2010 | Homedics PS-200 Iron with Auto Shut-off
How to use a steamer.
  1. Plug in the steamer.
    • The steamer usually comes with a smallish padded square with a strap that slips over your hand. (If you so not have one of these, cut out a square from some stiff cardboard, pad it using cotton batting, and cover it with a heavy, smooth, waterproof or water-resistant material.)
  2. Make sure it is steaming nicely before you use it. You check by pulling the little trigger on the handle, and seeing how much steam issues when you release it. You actually want to use this while steaming as well, in order to release more steam when needed.
  3. Hang the garment, and slip the padded square over one hand.
  4. Place the hand with the square on the underside of the garment, and use it to keep the fabric smooth while you steam it.
  5. Use the steamer by holding the nozzle close to the garment, and pulling both it and the padded square in downwards strokes.
Sep 18, 2009 | Rowenta Commercial Garment Steamer - White
Rowenta Professional Iron - steam button suddenly stopped working
Have you tried descaling it? It may well be blocked up with limescale. Personally I only ever buy cheap irons and bin them when they go wrong! As you say-they are generally too expensive to repair.
Jun 11, 2009 | Rowenta Professional DX8900 Iron
Plugged in, reset button is lit, won't go off
The problem is the thermostat (NC 150 C). A replacement is available at Digikey.com, item R2015025 (part no. 317-1468-ND) It's a simple replacement with the bottom removed.
Apr 20, 2009 | Homedics PS-200 Iron with Auto Shut-off
Steam Fast SP-660 Iron with Auto Shut-off Logo
165 people viewed this question
Top Steam Fast Irons Experts
Are you a Steam Fast Iron Expert? Answer questions, earn points and help others
