I'm trying to locate the check engine light and need to know how to replace the bulb. My car will not pass inspection until I get the bulb replaced, and I just purchased this car a week ago.
SOURCE: BMW 328I Check Engine Light Bulb replacement.
You will have to pull the dashboard display out and check to see if the bulb has blown or has been removed for some reason.
SOURCE: 97 Buick LeSabre failed emission test b/c Check Engine light out
change your lamda probes(seneor)!!!!!!!!
SOURCE: 2000 kia sportage mass air flow sensor
The mass air flow meter is fitted to the air intake pipe Its quite a simple task to change it on your own.Has for the catalytic converter all you will have to do is give the car a realy hard reving when going through the gears and drive it hard for a few miles.That will clear your cat for you.Dont listen to the shop they are out to rip you off.Good luck.Any problems you can contact me via [email protected].
SOURCE: How to get to bulbs behind instrument panel
SOURCE: 2007 Impala lt. Engine light came on today, tried the gas tanklid
These things happens sometimes. Disconnect your battery for 15 minutes then reconnect it. Just the ground cable is all needed to remove for this
