Question about Acer Aspire One Netbook 8.9" Notebook
I'm trying to usse my acer aspire one with an Hp sb21 lcd projector and it won't work. Any ideas? As the computer boots the projector shows the windows screen, but when it goes to the desktop, the projector starts 'searching' again for input.
You might have not enabled your computers second display.
This is actually a very nice feature, because you could run your powerpoint slide on the monitor while still running your normal applications on the laptop screen.
Go into control panel, display properties and then click on the "second" monitor (you could click on "Identify" to see which is which) and then select the "expand my desktop onto this screen.
The LCD display will be just a normal background, but you can drag windows from your laptop screen onto the LCD and back.
Hope this helps
Posted on Apr 20, 2009
    Problem Solver:
  • 5 Answers
Hook up computer to projector AFTER projector is turned on. Power on.
Right click on your desktop.
Click on Graphics Options.
Click on Output To.
Click on Intel (R) Dual Display Clone.
Click on Notebook + Monitor.
Posted on Oct 31, 2010
Hp sb21 out of sync
Are you simply feeding the projector with a video signal outside the range the projector can accept? For instance, trying to feed HD video to a projector that is not capable of high resolution can produce an out of sync image - or nothing at all.
I assume you've tried using a different video cable to connect to the projector, just in case there is a broken core in the original one that carried the sync signal?
Apr 05, 2014 | HP SB21 Multimedia Projector
Why my acer projector wont flash and shows just blue blink on its power botton
I'm not understanding what it is you are trying to say,it sounds like you are trying to describe two problems.
Projector won't flash? Are you saying nothing displays on the Screen?
And what just shows blue blink on it's power button the computer?
Blinks and Beeps tell the technician what is wrong with your system. Notice how many times it blinks and where the blinks are long or short. There is a pattern to to blinks for example (3 short blinks or 1 long blink followed by 2 short blinks).
I'm going to assume your system has a memory chip problem and when you press the power button it just blinks and nothing ever happens, not posting on the lcd screen at all.
Remove the Power Cord, Remove the Battery, Turn the laptop over and Remove the screw that secures the Memory Cover and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 08, 2012 | Acer Aspire 1710 Notebook
Grandson dropped his Acer Aspire One. Now has double screen with blank white screen in center. (Left half of a normal screen shows on left side of screen and on right side of screen, with white screen in...
My suggestion is to replace the LCD with new one. Let the certified technician to work on that. You cannot perform the DIY on that. Its too complicated.
Aug 18, 2010 | Acer Aspire One PC Notebook
No LCD connectivity
Hello, I am using a Viewsonic lcd projector with my new Acer Aspire One. I did not have connectivity off the bat. Here's what I did: 1. Downloaded driver (unsigned, not the signed version worked - ie not os-specific) for the lcd projector to the Acer. Restart Acer. 2. With lcd projector connected to Acer, toggle function key & F5. But then, continue holding down the function key. A screen pops up with icons for laptop, laptop/monitor, dual monitor, and lcd projector. You continue to hold down the function key and then press the F5 key to move to the desired device. I had to repeat the same process to restore my Acer screen to the original proportion when not using lcd projector. I'm not sure if both steps 1 and 2 are necessary, but I did it simultaneously, so I'm not sure of the origin of success.
May 22, 2009 | Acer Aspire One PC Notebook
I'm using acer aspire one. My SD port is not working. It can not recognize the memory card. Also when I connected my laptop with LCD multimedia projector, it did not work too. Oh my God, anybody there who...
ok ... try this, switch on your aspire laptop, then u switch on your LCD multimedia projector... then u press the F5 key on your keypad(on your aspire) , HP, and many other manufacturers uses that key for the LCD,CRT,projector extension slot while other laptop manufacturers like Gateway e.t.c uses the F4 key for the extension... after you have done that... your aspire screen goes dim then it should show on your LCD...but if not then switch off your laptop with your LCD multimedia projector ON then swicth on your laptop it will automatically work with it ok.....
this applies to other laptops and projectors or LCD s ...
Mar 27, 2009 | Acer Aspire One PC Notebook
Acer Aspire 1642 WLM not showing with projector
Try other F keys..other wise try Ctrl+alt+function key
Dec 08, 2008 | Computers & Internet
Can't use my hp sb21 with my Macbook
it works if you do it in bootcamp. but have to select external monitor instead of digital display under the intel graphics control panel. does anyone know of such an option under OSX?
Jun 13, 2008 | HP Digital Projector sb21 Multimedia...
HP sb21 lamp
There is a very picky sensor on the lamp cover. When the lamp and cover are seated perfectly, your lamp will start.
Apr 07, 2008 | HP Digital Projector sb21 Multimedia...
Acer Aspire One Netbook 8.9" Notebook Logo
371 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
