Question about Kenmore Dishwashers
On my kenmore elite dishwasher when I hit start buton it doesn,t start and I get --- across the display-
  • tomn108 Apr 20, 2009
    I need more information than just check voltages since I'm not sure what voltages I'm looking for .There is power to the dishwasher. As I stated before I get video on the panel such as numbers when I press different modes but just get - - when I press the start button
    Brigadier General:
  • 3,614 Answers
Like most anything that requires a power source to function, the first place to look when it is no longer working is the electrical connection or power plug. Once you know it has power, it is a simple process of following the circuit until we find the point the electricity stops. But it isn't always that easy because we must remember, for electrical components to function, there must be a complete circuit for electrons to flow. Which means, just because we have power, doesn't mean we have an electrical circuit. For this reason, it is important when taking electrical voltage measurements to always check for voltage in reference to a neutral wire and not the frame of the unit.
Posted on Apr 19, 2009
  • micromaster
    micromaster Apr 20, 2009
    Step 1:
    Check to make sure it's receiving power. If the unit plugs into a wall
    outlet, check the cord, the plug, and the outlet to make sure they're
    functioning properly. Also check the switch that controls the outlet to
    make sure it's turned on. Most built-in dishwashers are wired directly
    into a circuit. Check the main entrance panel for a blown fuse or
    tripped circuit breaker, and restore the circuit. If your home is an
    older one, the dishwasher may be wired to a separate entrance panel;
    look for a blown fuse or breaker at this panel, and restore the circuit.
    Step 2:
    If the circuit is receiving power, and the wall outlet is controlled by
    a switch, the switch may be faulty. Test the switch with a voltage
    tester. Take off the switch cover plate and place one probe of the
    tester on one terminal and the other probe on the other terminal. If
    the tester bulb lights, the switch is functioning. If it doesn't light,
    the switch is faulty. Replace the switch with a new one of the same
    type.
    Step 3:
    Make sure the door is tightly closed and latched. The dishwasher will
    not operate until the latch is properly engaged. To check the latch,
    close and latch the door, holding the latch tightly in place. Then,
    still pressing the latch closed, turn the control knob to the ON
    position. If the dishwasher works, the latch is faulty and should be
    cleaned, tightened, or replaced.
    Step 4:
    Make sure the water is turned on and the water temperature is high
    enough. A breakdown in the water heater could stop flow of water to the
    dishwasher. Test the hot water in the kitchen sink or bathroom. If you
    can draw hot water, the water heater may not be at fault.
    Step 5:
    Make sure the controls on the control panel are properly set. The newer
    push-button controls can be very sensitive; make sure the buttons are
    firmly pressed into position.
Kenmore Elite Dishwasher will not start
Consider examine inside there is maybe fuse busted on the panel or in the circuit through the control panel of the machine.
Feb 05, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Unlock dishwasher if locked by holding heated dry button for about 4-5 seconds next quickly hit the following buttons in successive order heated dry, normal wash heated dry then normal wash this should run diagnosis of the unit. Wait about2 minutes then press the cancel/drain button this should reset it and restore operation be sure to check that water supply is on and the drain is clear or you may get the code again.
Dec 07, 2013 | Kenmore 24" Built-In Dishwasher with...
My Kenmore Elite Ultra Wash Dishwasher keeps shutting off before entering the cycle. I have repositioned dishes, even emptied it, changed cycle and tried everything. When I press the start light flashes...
I too had problems with the Kenmore Elite (aka Bosch). The issue was solved by replacing the Lock Sensor on the door. After replacing the sensor the dishwasher has been working. Hope this helps.
Oct 08, 2013 | Kenmore Elite 24" Built-In Dishwasher with...
Manual for Kenmore Elite dishwasher
Kenmore Elite DIshwasher will not start. Model # 630.16302406
Display shows h:08 with the quick setting illumintated
Jul 17, 2012 | Kenmore Dishwashers
Gene, I have a Kenmore Elite model # 665
Hey Steve,Sorry it took me so long to answer i was offline and my add is not supposed to displayed when i am off line so sorry about that.
Now then on that dishwasher with the hum and no water circulation it sounds as if the main wash motor is jammed up for some reason it could be that the motor itself is defective or as simple as something such a piece of debris such as broken glass or almost anything caught in the motor causing it to not turn on,by disassembling the wash motor you can see if something is caught in,if nothing is caught in its a (sorry to say) the motor itself thats bad and would need to replaced.The reason the water drains even though it will not circulate is because of the separate drain pump that is working Please reply back after disassembling the pump to check for debris if ya need further assistance.
Thanks for using Fixya.Com,GENE
Oct 18, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore elite not washing dishes
Sounds like the motor is stuck. If your careful you can unplug the dishwasher or turn the breaker off, take the bottom panel off and reach in with your finger and spin the motor assembly.
Nov 12, 2009 | Dishwashers
Kenmore Elite 15962990 will not start
So far, I'm not very impressed with this website. I posted a problem with a Kenmore Elite 15962990. FixYa emailed me back, saying: "We wanted to find out if you still need a solution for the Kenmore 24 in. 15932 Built-in Dishwasher Problem". So now I'm confused. I'm supposed to trust advice from somebody who can't even get the model number right? And FixYa keeps telling me I'm dealing with a top load clothes washer instead of a dishwasher.
Anyway, the problem still exists. I know there must be some way to reset it or put it in "maintenance mode". But none of the button sequences I saw online will work because my specific model does not have the buttons mentioned.
Feb 10, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
35 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
