Question about HP C5726-69202 SureStore Tape Drive
Can you fix it?
I have two HP SureStore DLT 80 tape drives. When you plug-in (power) the first one, nothing happens (not even lights up). The second one spins the tape, grunts, and flashes all lights on the right, then repeats. Oh, it won't give back the cleaning tape either (can't eject). Can these be fixed? And what would it cost? Thanks, Lance
    New Friend:
    Problem Solver:
  • 6 Answers
The first one is not completely shot, it sounds like something in your main board has gone. this can be replaced just needs to be takes to a pro fix company. the second drive sounds like the taco wheel is faulty, meaning the drive can not sense itself spinning the tape so it spins out of control, this can also be fixed but will need to be sent to a pro fix shop.
Posted on Nov 13, 2012
    Scholar:
  • 116 Answers
It sounds like your first drive is defiantly shot. The second one suggests the drive has failed as well. You should be able to eject the tape manually using a long piece of steel. Such as a paper clip.
Taken from the manual
If all the right side or left side lights flash on the front panel:
There is a fault with the drive.
1 Try turning the power switch on the drive off and then on again.
2 If the problem persists, call for service.
So your sorda up a creek. Can i suggest moving to HDD backup system? They are ultra cheap, reliable, and much faster than Tape backup systems.
Alternativly if you have data you need to recover, you can purchase new (used) drives off ebay for about $200
Posted on Oct 10, 2007
SOURCE:
Superloader3 , don't recognize real capacity of tape
this may be a limitation on your motherboard. please check if your motherboard supports this much capacity. If you have another pc or laptop that is about a year or two, check if they would recognize the the capacity of the drive correctly. if not you may want check with quantum about their drives.
Jun 19, 2010 | Quantum DLT-V4 DLT Tape Drive
Tape in use light is flashing and no tape in the drive
Tape in use light is flashing and no tape in the Problem with the Compaq DLT8000 40/80GB DLT Tape Drive tape in use light is flashing and no tape in the drive
Jun 03, 2010 | Compaq DLT8000 40/80GB (154874-002) DLT...
I have hp surestore DLT1e drive. Tape cartridge stuck!
For that you can try to press and hold the eject buttonfor 30 seconds if the tape doesn't came out then reflash the drive firmware revision.
After all that is the issue persists you can try to:
manually remove the tape by removing the top cover
Locate recessed thumb wheel
Rotate thumb wheel counter-clockwise until you feel resistance. Wheel may spring back when you release it. This is OK.
Locate hole in bottom of drive. Insert #10 Torx driver and rotate clockwise until tape ejects. If there is a lot of tape on the take up reel, this could take some time.
Rotate thumb wheel clockwise to eject the tape.
Apr 08, 2010 | HP Computers & Internet
How to turn on a hp surestore dlt 80?
You have to plug power cord to back enclosure and SCSI external cable 68 pin to your PC. Your PC have Adaptec card
Good luck
Mar 21, 2010 | HP SureStore DLT 8000 DLT Tape Drive
Forgot service password for HP Surestore Tape Autoloader 1/9 DLT 1 Tape Drive
This legacy devices service password can be reseated by following this steps:
The following is required before resetting the password:
  1. Access to the front panel of the HP Surestore DLT library.
  2. From the Home screen, press Main.
  3. From Main, press Information.
  4. From Information, press More.
  5. From this menu, press Date and Time.
  6. Write down the date (including year) and time.
The display shows a valid date and time
Do the following:
  1. Press the left-most button (button 1). This button is not labeled. A warning message to call service will appear.
  2. Press OK.
  3. The Call Center must then calculate a special password based on the date and time, using the following formula:
    1. (Hours * 1001) + (Days * 101) + Month + Year (all 4 digits) = subtotal
    2. Multiply the subtotal by 123. If this multiplication results in a number greater than 99,999,999 (this should never happen), use the special password of 44122333.
    3. Since the only valid choices are 1-4 for each digit, follow these rules:
      • If the digit=0 (zero), make the digit=1
      • If the digit=9, then make digit=1
      • If the digit>4, subtract 4 from the digit
      • If the digit does not meet any of the above, leave the digit unchanged. If the result is less than 8 digits, add leading 1s to make it eight digits in length.
        NOTE: As an example, 2000 02/07 2:30 is displayed (February 7, 2000 at 2:30). Plugging in the numbers: (2 * 1001) + (7 * 101) + 2 + 2000 = 4711
        4711 * 123 = 59453
        Convert all digits to be between 1 and 4 = 131413
        Add the leading 1s to make it eight digits long - 11131413
  4. Enter this special code to the front panel.
  5. Press OK. The screen will confirm that the password has been reset.
  6. Set a new password.
Mar 08, 2010 | HP Surestore Tape Autoloader 1/9 (C7147A)...
Dlt-v4, the drive accepts the tape only to spit it out
You have to try the other tape if the same problem you have to replace the head.
Feb 05, 2010 | Quantum DLT-V4 DLT Tape Drive
I dont know how to install external tape drive compaq DLT VS 80 in Red hat 4
Hello,.
Please reboot your server and attach tape drive... if it is still not detecting please check the
#dmesg
command to check the error...
and get back ............
Dec 02, 2008 | HP (154872-003) (154872003) DLT Tape Drive
Open Questions:
AOL DESKTOP GOLD isntallation error #@ {1844641-OO35} pHoNe nUmBeR SAKTE USA AOL DESKTOP GOLD can't open linkAOL DESKTOP GOLD not working pHoNe nUmBeR {+184464I-OO35} to resolve all AOL DESKTOP GOLD email products. JCG is an American multinational company which was founded by Michael AOL DESKTOP GOLD email using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, AOL DESKTOP GOLD email support number, and selling of computer-related services and products. AOL DESKTOP GOLD email Tech Support Phone Number Recently, AOL DESKTOP GOLD email has been named the number AOL DESKTOP GOLD email technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, AOL DESKTOP GOLD email customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a AOL DESKTOP GOLD email Service Tag or a AOL DESKTOP GOLD email Get AOL DESKTOP GOLD email Technical Support Phone Number and Customer Services. AOL DESKTOP GOLD email is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services
Aug 17, 2019 | AOL Computers & Internet
See all HP C5726-69202 SureStore Tape Drive Questions
Computers & Internet Logo
191 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
