Power coming in but nothing turns on
SOURCE: My new maytag centennial electric keeps tripping
Hi Matt
I'm not sure that swapping out the breakers to higher rated ones will give you a solution so I'll throw in 2 cents to see if my advice holds true. Let's start by asking this. Is the appliance "rated" at 220 volts at 30 amps per leg. I assume this from your post as to what it has been rated. Next - How long is the "run" of wire from the junction box to the outlet where the appliance plugs in? This usually does not matter in most households but if the run is of significant length it may need a larger gage wire to support the current draw of the appliance. Lastly, and perhaps most importantly, are the lugs and wire connectors tight at the outlet, the plug, and the breaker box. A loose connection will ramp up the current fast. This is assuming the first two items were met. Tell me if any of this helps and we'll work it out from there.
Thanks.
Len
SOURCE: My maytag centennial dryer is getting too hot and
Exhaust problems are the only thing that will cause this. Check to make sure the exhaust behind the dryer is going straight out without alot of bends. Also no exhaust should be over 20 ft to the outside. Ther is a tip on how to clear house exhaust in the tips section. Just type dryer to long to dry and should take you there.
SOURCE: I have a Maytag Centennial
door switch is correct you will need to unplug the dryer and open the cabinet open and replace switch, this website will assist you, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
SOURCE: no heat in my Maytag Dryer Centennial Model bought
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing.Please get back to me if you have any other questions.
Kevin
SOURCE: maytag centennial dryer - timer
You most likely have to replace the POS timer, my girlfriend\'s failed out of the box, a month later and again two years later. I dissected the timer and found the cheapest set of plastic reduction gears between the timer motor and the gear that drives the knob, and one of them had the teeth stripped off.
You can find them on ebay for less than $50 shipped rather than pay $100+ for one from a parts store.
