Question about Dryers
Coins inside panel inside
How do I remove coins from one of the panels in my front loading gas Kitchenaid dryer
The screws on the drum will take care of that. looen the screws and turn the drum. try each paddle till you dont hear them anymore.
Posted on Dec 11, 2010
We have a bosch front load stackable dryer that has coins stuck in the things that go around in the dryer, can we get them out?
You'll have to remove the top panel so you can loosen the baffles and get your coins out. Either that or take the back panel off and remove the drum altogether, which ever you find easier.
Jul 08, 2011 | Bosch Nexxt 500 Dryer
It sounds like Coins have found their way inside and tumble loud. Any way to get them out?
Yea ... but is it probably better to let them tumble until they work their way out of the drum.
You will have to take the machine apart and remove the drum to find the coins. Remove the bottom panel to get access to the screws that hold the upper front panel on. Remove it ... remove the drum. Take lots of pictures as you take it apart.
Like I said, it may be better to let them go.
Thanks for visiting today.
Jan 27, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a Maytag Neptune TL washer that won't drain. I took the front panel off and detached the hose from the pump and there were several coins in there. I removed the coins, reattached everything and...
For the FAV6800A or FAV9800A tumbler removal.
The Service manual has the procedure starting on page 37 for the tumbler removal.
It’s not difficult to remove the manual doesn’t call out the Torx driver size required for tumbler removal. You will need a number 20 Torx driver to remove the Torx screw for tumbler removal. I would get a long Number 20 Torx driver for this. See page 37 of the Service Manual for tumbler removal. Looks worse than it is.
The Service Manual for reference. Sears Parts Direct for reference.
When I did a recent Outer Tub Bearing replacement I found $1.78 in coins after removing the wash basket. Gotta check those pockets....:)
I have a post around somewhere of my diy Sump Screen I put in my FAV6800AW to protect the drain pump impeller from coins and other stuff from breaking the impeller or causing clogs. I'll look for the post or repost the pic's.........D*ick
Sep 11, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Coins stuck in Maytag Atlantis dryer. Could
. U1. Unplug the washer.
2. Using a stiff putty knife, press the locking clip in the seam between the “hood” and front panel, as shown below. There’s a clip on each side. Raise the top panel up and out of the way. You may want to tape the the lid to the top panel so it doesn’t slam into the wall, thus evoking explicit language.
4353551224_4d366b181c_o.png Now you’ll see two screws, one on each side. Remove ‘em and pull the top of the front panel out toward you. Then just lift the panel off the bottom hinges and there you be.
4353556628_0370cd3f5a_o.png Ain’t nuttin’ to it. Now whup up on that bad boy! fouetaa.gif
Apr 18, 2010 | Kenmore 74602 Gas Dryer
My kenmore elite HE3 elec dryer, model # 11082826101,has a loose piece in the dryer drum, how do I take the top off to fix it?
There are three screws that hold the top panel in place in the rear of the dryer. Remove these screws and the panel will slide back, then lift off. You should have access the outer perimeter of the drum, control board and control panel.
If you need to access the dryer bottom cabinet, remove the lower toe panel directly below the door. The panel comes off by removing the screws under the bottom front edge. With the screws removed, the panel will drop down and then come off.
NOTE: Propping the two front feet of the dryer up can offer better access to the toe panel screws ( a section of 2x4 works well for this).
There are some helpful exploded view diagrams you can use for reference at these following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
Small items (like coins) can often get caught in the dryer drum baffles. They come off easily by removing the screws that hold them on place around the drum perimeter.
CAUTION: Make sure you UNPLUG the dryer before servicing anything inside the cabinet. Dangerous voltage is still present even with the dryer turned off.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Oct 14, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Noisy gas dryer, sounds like change in it. coins raddle arround
SOMETIMES COINS DO GET INSIDE THE BAFFLES. I HAD FOUND COINS IN THEM BEFORE
Apr 09, 2009 | Kenmore 73952 Gas Dryer
How to remove lower front panel on kenmore 90 series dryer dryer runs a few minuites heats up then shuts off i think it needs lint cleaned from inside unit i'm trying to get inside to do this
On my 7 year old Series 90 Dryer, I
- unplug the dryer
- use a flash light to locate the two black metal spring clips (located about 3 inches from each end of the lower panel along its top edge). They can be seen in the crack between the upper and lower panels.
- use a putty knife, or similar tool, to press down each clip while pulling out that edge of the panel.
- The panel slips off the lower clips easily.
- on some models there is a lone yellow wire with a connector on the end. If it is unconnected to anything, don't go nuts thinking that you have disconnected a wire by accident. Its one of those unused wires on some models.
- collect as many coins as possible before you vacuum the inside of the machine. Leaning the machine forward can often slide hidden coins to the front. BE SURE YOU CAN LEAN THE MACHINE WITHOUT HAVING IT FALL ON YOU. Otherwise, plan on collecting the coins from the vacuum cleaner when you finish.
- replace the panel by first threading the panel on to the lower clips, then closing the panel. CLICK, CLICK. FINISHED.
Congrats you have cleaned it, possibly avoided a house fire and added to the mad money collection. Hope this helped.
Mar 16, 2009 | Kenmore 73952 Gas Dryer
My kenmore series dryer is making noise as it runs. It heats but makes a noise as if coins are in the dryer. I cannot see anything from inside the dryer, is there a way to remove the front face of the...
there's 2 basic ways to removing the front panel. First is 2 screws at the very bottom of the front panel, when removed the panel can be lifted and un-hinged from the top. The other is by using a flat screw driver and prying the top up at the edges on the front side the removing 2 screws or hex screws located inside the front panel toward the top. make sure you undo door swich wires before completely removing the front panel. then in the middle of the drum on the inside of it either 1-3 screws hold the drum to the back. Remove belt first then screws then pull drum straight out. The noise may be from your rear drum bearing or coins have gotten in the paddles of the drum(inside) paddles can be removed. I had coins in one of my paddles, made 60some cents lol at same time found perfctly round lint balls. Good Luck
Mar 02, 2009 | Kenmore 63942 Dryer
Coin Stuck In My Dryer
well, i can get into the machine, not aproblem.. is the coin perhaps trapped inside one or more of the innerr drum viens perhaps??? anyway, ifyou removet he2 screws securing the door, and the 2 screws opposite the hinge, the front "u" shaped front panel will tilt off fowards.. from there theres a few 5/16 screws holding the main top assy to the froma of machine, you can remove them and tilt the top back, giving you acess to the outer drum assembly( and you can removethe drum viens and retreive te hoffending "coins" in htat fasion.. hope this helps.. TURN OFF POWER TO UNIT<< LIVE WIRES!!!!!!!
Feb 12, 2009 | Maytag LSE7806A Top Load Stacked...
How do i remove panel from front load washer
You can download a basic but somewhat helpful service manual here http://136.166.4.200/contents/Laundry/WM2277.htm that has some disassembly instructions and exploded view diagrams, explains the troubleshooting mode.
Nov 25, 2007 | LG WM-2277HW Front Load Washer
Dryers Logo
73 people viewed this question
Top Dryers Experts
