Question about Magic Chef MCBR440 Compact Refrigerator
Refrigerator stopped working
Magic Chef BR 3605 completely stopped working
    Problem Solver:
  • 7 Answers
Check if the in side light works and if it does then it is your thermostat.allso check the power supply to your frige
Posted on Apr 19, 2009
My magic chef small refrigerator stopped working. which part should I replace?
the entire unit . most small ones are not worth the price of parts to fix them
Oct 11, 2016 | Magic Chef Refrigerators
Magic Chef Refrigerator has stopped cooling adequately.
Check the compressor and the Relay, the relay is located on the compressor itself. you should have full voltage to both of those. If oyu have voltage to the relay and not the compressor then the relay is bad. If you have power to both and the compressor will not kick on then you have a bad compressor and it is best to just replace the fridge
Apr 26, 2009 | Magic Chef MCBR170 Compact Refrigerator
I have a magic chef French door refrigerator. Water under the freezer becomes ice and when this melts water seeps onto the floor. Sometimes enough water to completely soak a couple of towels
Lower the setting to your FREEZER this may be defrosting too often and the drip pan is over filling, or stop leaving the doors open too long .
Oct 04, 2014 | Magic Chef Refrigerators
My magic chef rb193p fridge wont stop running. I replaced the fan motor 4 months ago. The top of the fridge compartment is freezing. Is the defrost timer bad?
I had the same problem. When the evaporator heater stops working, frost will build up until there is no air flow to the refrigerator. This will cause the refrigerator to keep running. Remove everything from the freezer and remove the pan at the bottom and see if there is a frost buildup. .... Bruce
Jun 18, 2011 | Magic Chef CTB1922 Top Freezer...
My refrigerator first stop making ice, then, a few days later, it stopped dispensing water. Help anybody? Elena
Don't know much about magic chef but you might want to check the water filter,if it has been in there for more than 4 or 5 months it might be clogged depending on your water.If this does not help repost your ?
Mar 01, 2011 | Magic Chef (CSD2610KRW) Top Freezer...
Just bought magic chef ctf2124ar fridge. cannot
Not a bad refrigerator I work on them for a living they have put out decent products in the past. Magic chef was made by maytag in they past probably a wpl made product now. Its probably got a calrod defrost heater and an embraco compressor two good things to have. Stick with it.
Jan 22, 2010 | Magic Chef CTF2126AR Top Freezer...
Magic Chef refigerator/freezer stopped running
if you said stop running id assume that there is no power?? even with good electrical input..
for that instance, better check.charred cables.. if not there maybe a problem with timer itself..
Nov 05, 2009 | Magic Chef CTB1922 Top Freezer...
My Magic Chef refrigerator has stopped cooling. When I unplug it for a few days, and then plug it in, it will work for about a week, and then quit cooling again. The freezer is perfect, and continues to...
The most likely cause is that the defrost system is not working. After about a week it builds up with enough frost to stop the cold air from getting to the refrigerator section. The most common problem is the defrost timer, defrost heater or defrost thermostat.
Aug 26, 2009 | Magic Chef CTB1502AR Top Freezer...
Fridge stopped being cold and freezer not freezing
Switch off the refrigerator. Let all ice melt completely. it may take 4 hours. Switch it ON again. does it work better for 2-3 days. if yes,change bimetal and timer.
Aug 09, 2009 | Magic Chef CTB1821AR Top Freezer...
Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Aug 27, 2008 | Magic Chef Refrigerators
Magic Chef MCBR440 Compact Refrigerator Logo
532 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
