SOURCE: GE dryer starts but..... stops
The motor switch is not working properly. You can try removing lint from motor area around the end where the wires attach. This may free switch. If it still won't work you need a motor.
SOURCE: Ge Cloths dryer will not stay running or turn drum
probably broken belt some dryers have broken belt switch that shut dryer off if belt broke
SOURCE: Dryer won't stay running
I had the same problem with my kemore. Thank goodness I still had it under warranty.
The tech said the door latch was just slightly ajar. This is common he said that when we take clothes out we let the door close to hard or gets ajar for leaning in to take clothes out.
He readjusted it and I have never had a problem with it again.
Hope this helps
SOURCE: starter knob on GE dryer came off. Dryer won't turn on.
If it turns hard, the timer may need replaced. But if you can turn the shaft with a pair of pliers and the dryer works, just get a new knob.
SOURCE: GE Dryer will not stay
Does the drum turn? when you press the button? Some of these have a broken belt switch. If the belt is broken the motor will run but then shut down as soon as you let off the start switch. I looked up your model and yours does have this interlock switch (broken belt switch) It might be the switch or a broken belt.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
