Question about IBM ThinkPad T23 2647 Notebook
When booting up get Fan Error. If I hit Esc then computer will then boot up, although very slowly.
  • 2 more comments
  • jsercerchi Apr 19, 2009
    Error is the computer simply says Fan Error. Immediately below this error message it says Press to setup which when I press it,it goes to IBM BIOS Setup Utility.
    I can get the computer to boot but it is extremely slow.
    I do this by pressing Esc.
    What are your thoughts?
    Thanks
  • jsercerchi Apr 27, 2009
    Thanks for the help. I will take it to a local repair guy and give him your suggestion as it makes perfect sense. My wife stores a lot of pictures on her computer and that may be the problem with speed.
    Thanks again and I will e-mail you once repaired to let you know how helpful you were.
    Thanks
  • Frank  Fernandez
    Frank Fernandez May 11, 2010
    Check your processor fan and case fans to make sure they are connected and spinning.
  • Frank  Fernandez
    What is the error?
  • 846 Answers
The fan needs to be replaced but if you can get away with just pressing escape that may work for a while. it is probably not slow because of the fan. Try to reduce programs that run and startup and (use autoruns utility) and run virus scans. Fan replacement is a difficult repair but it can be done, if you look for free repair guides online you will find something. I work for company that does Laptop repairs in NYC and we do this repair frequently.
Posted on Apr 24, 2009
Boot menu cant working
Press DEL to get to your bios options then disable fast boot. This will allow you to hit the appropriate key to enter the boot menu.
Mar 30, 2014 | Lenovo Computers & Internet
My lenovo thinkcentre desktop computer never shows "press any key" while I try to format. Unable format my C drive and recently 500 GB HDD was installed in my computer. pl.advise how to format...
Hi! Welcome to www.fixya.com.
Removed your power cable and drain power without any power. restart and keep on hitting f12 to get to the boot menu choose ODD then put the OS CD then press enter until its say press any key. If it did not work your other option is reboot and hit f1 or f2 to change the boot sequence on boot option. Restart pc then hit f2 go to boot option and choose DVD/CD to be your first boot option then press f10 restart and it should load automatically.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 20, 2011 | Computers & Internet
This machine has a G31MX board. It will not boot no matter what order I put the boot order in. I tjust restarts. Pressing tab for post screen or delete for bios it functions normally, but when I try the...
Unplug all drives and USB connections from the board. See if it goes far enough to error out on finding a boot disk. If it does, add items back in one at a time. When you hit the magic one, the problem will return.
If it happens even with nothing connected, you've either got a bad power supply, or the motherboard's shot.
Jul 06, 2011 | Foxconn G31MX-K socket LGA775 motherboard
Toshiba satellite 5105,only gets a sfar as "toshiba" screen with red lettering.Cant get to bios, hitting esc. worked once and said media failure. What can I do to fix it,or get it to at least do...
First, make sure the ESC key is the proper key to get to the BIOS. You should see a prompt right after you get the Toshiba splash screen to hit a function key to change settings.
I'm thinking because you got a media failure error, your hard drive may be bad and the boot order says to boot to the HD.
Apr 30, 2011 | Toshiba Satellite 5105-S501 Notebook
My computer will not boot up. How do you make it boot from disk.
Go into the bios by hitting f1/or esc when at the first screen then change the boot order and made the cd rom first above the hard drive
Mar 05, 2011 | Compaq Presario 5630 (334560-003) PC...
WHEN BOARD BOOTS ERROR 512 - CHASIS FAN NOT DETECTED APPEAR LET ME KNOW HOW TO DISABLE THIS ERROR it does it every time i start, or restart the computer, and i have to hit F1 to get it to boot, what...
hi this is a setting in the cmos or bios you have to hit delete key or F2 depending on make of system to get into the menu, locate the setting for the chassis fan speed then disable that and you should not see the error on boot again...hope this helps
Jan 14, 2011 | Computers & Internet
Hi my hp g6000 wont boot it comes on fan runs hard drive and cd kick in but no screen then the laptop reboots and just does this loop
When your system begins to come alive, press Esc or F8 to get to a BIOS Menuscreen. In there, look for Boot. Move the CD/DVD option to the top so that your computer will look for a cd to boot from. Hit F10 to save and exit. Put a bootable CD in the drive and let your computer boot from it. Once it's up, look to see if you see your harrdrive C:. If not, the problem is probably the boot sector on your hardrive has gone bad. Look at this site (it's legit) for bootable CDs and other help.
Aug 12, 2009 | Computers & Internet
I can use the recovery cd
Hello
First you need to make the computer to boot from the CD ,when the computer starts first time look for something that says to change boot order press F8 or similar.
If it's not there then look for another message that says to enter Setup press Del (or F2 etc) ,then scroll to Boot sequence or settings and change CD drive to first device then save settings and exit.
May 07, 2009 | Computers & Internet
Pavilion EZ4125 will not boot past the HP boot seletion screen.
Did it give you any blue screen error. Did you try booting from the CD. Its definitely something to do with the OS. Load the CD and run the setup and try to repair the OS.
Feb 12, 2009 | HP Pavilion ze4125 Notebook
Bios correpted
hi saeedkhan you need to go into the bios by pressing example f2 or esc as the computer boots, but it should tell you on the screen how to enter the bios.
once you have done this go to the boot devices, then make sure your cd/rom is first boot then the hard disk the second device, it will tell you how to change them if you have to, then hit f10 to save the configuration and reboot the computer make sure disk is the cd rom and try that.
let me know how you get on.
hope this helped
Oct 21, 2008 | Intel Motherboard
IBM ThinkPad T23 2647 Notebook Logo
399 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
