Question about Sony VAIO Digital Studio PCV-RZ14G PC Desktop
Computer crashing message at start up
My computer drive c: is running out of space and every time i turn my computer on i get a message asking me to back up my data there is a imminent crash. my mother board is a sis651-p4s533vx shall i buy anew hard drive, what size can i buy?
  • mrninja
    mrninja May 11, 2010
    what size HD do you have now? are ther any apps that you can delete or dont use anymore? what are your needs for this pc?(gaming?,home office?etc)
  • 123 Answers
If it's telling you that you're about to lose everything on the disk then you should probably buy a new HDD!
You can get a 500 GB HDD for about €50, which should last you a fair while.
Don't waste time or you may irreplaceably lose everything you have.
When installed get everything copied over to the new hdd straight away
Posted on Apr 19, 2009
Intel Rapid Technology off line hard drive?
Open the computer and check cables. 0 is the 1st drive and usually the primary. Then login into BIOS and verify the drive is listed there. It must be.
Crashing may be a sign of hardware failure, but fix the HD problem 1st. Then run chkdsk c: /f/r C being the drive letter from the command prompt.
Apr 26, 2013 | Western Digital WD2500BEVT-22A23T0 - 250GB...
Is this computer able to dual boot win 7 and xp
Which version of xp are you trying to install 32 or 64 bit ?
Your ability to install a second operating system on your Windows 7 system hinges on one thing: partitions. If your computer has only one partition, you can't dual-boot your system without erasing all information on your computer. Two hard drives, or two partitions, enables you to dual boot. Check this information first, before proceeding.
Click "Start" and type "disk management" into the search bar. Click on "Create and format hard disk partitions" in the list of programs to open "Disk Management." Look at the list of partitions and available drives. The information here will be different on every computer. "C" is your primary hard drive and active operating system partition, and this drive contains your Windows 7 installation. You can't install Windows XP here without formatting the system. Check for secondary drives and partitions in Disk Management. Your system may have a "D" or "E" drive. Some computer manufacturers create a hidden partition with recovery software: don't remove this partition. If you have a secondary partition called "D" with more than 2GB of free space, you can install Windows XP here. b> Installing XP b> Insert the Windows XP Setup disc into your CD or DVD drive and close any windows that appear. Shut down your computer with the disc in the drive. Turn the computer on and look for a message saying "press any key to book from CD." Press any key on your keyboard when this message appears. Most computers are configured to look to the CD or DVD drive first, before booting to the operating system. If your system doesn't recognize the disc, you will have to enter your BIOS and change the boot order. Look to your manual for information on changing the boot order. Press "Enter" on the "Welcome to Setup" screen to load the Windows XP setup program. Read the license agreement and press "F8" to accept. Windows will detect that an operating system is already installed on your primary partition and present a list of other partitions to install XP. Use the arrow keys to select your secondary partition ("D") and press "Enter" to confirm that you want to install XP here. Then choose what to do with the partition: leave the file system intact or format the partition using FAT32 or NTFS. Windows XP supports both file systems, but requires NTFS on partitions larger than 32GB. You don't need to format the drive to install XP. Follow the prompts on screen to enter your personal information, serial number, and date and time. The setup program copies files to your PC and reboots -- don't press a key to boot to the CD. When you have to operating systems installed, a DOS screen appears asking you to choose an OS; press the down arrow key to highlight Windows XP and press enter to complete the setup. You will have to choose this every time to boot into XP, otherwise your computer will boot to Windows 7 by default. Hope this helps.
b>
Jan 06, 2013 | HEWLETT-PACKARD Pavilion Desktop with AMD...
Not enough disk space to spool document error message when using Brother Ptouch QL-500. All other printers are working well.
I am assuming that your hard disk is not actually full. I am guessing that you are running Windows 7. Click through your start menu until you can see the entry to launch your P-touch Editor. Right click on the entry and click "Properties". Click the "Compatibility" tab. Under "Privilege Level" check the box labeled "Run this program as an administrator". (You can do the same for all users of this computer by clicking the button immediately below, labeled "Change settings for all users".) Click OK, and you're done. The next time you launch the editor, you will get a message asking: "Do you want to allow the following program from an unknown publisher to make changes to this computer?" Click yes, and you should be able to edit and print your labels. Of course, all this assumes that you have sufficient privileges to actually edit permissions and run something as an administrator. Hope this helps.
Jun 06, 2011 | Brother P-Touch 2420PC Label Printer
Every time I start my computer, a message pops up: "Low Memory." How do I fix this. Thanks.
Check for the hard drive space where the operating system is installed, normally this message comes when the space is low and windows is not able to create virtual memory required to run windows.
Aug 05, 2010 | Computers & Internet
Don't know how to use product, no directions
It should plug in as a Windows Storage device.This will appear as another drive on the computer.
Copy the file across the "new" drive.
Then ask windows to stop using the drive  by clicking on the USB device icon and selecting stop storage device.
Then you can disconnect it safely.
Mar 07, 2010 | Verbatim STORE-N-GO (95312) 8 GB Hard...
I repeatedly get Program not responding messages
Not much to go on here. Are you asking for condolences, or what to do about it? This message is caused generally by your machine having run out of resources. That could be swap file space, due to having run out of room on your hard drive, or swap file size set too small. Graphics card insufficient for what you are trying to do, especially if it is an on-board graphics card. Mostly due to not enough RAM installed. RAM chips are cheaper than they have ever been. See how much is in your machine, and then max it out by adding RAM up to the capacity of your motherboard. Temporary fix is try running less applications at one time, defrag your hard drive, add a program such as Advanced Windows Care (FREE on the net) and use it to maintain your registry, I would go for the RAM upgrade.
Jul 18, 2009 | Dell Computers & Internet
What happen if computer hard disk overload
your hard drive would eventualy crash and seeing that the drive is overloaded there wouldn't be sufficient space left for System Restore to run as it needs a fair amount of space to run. My advice is to always keep about 10% of your HDD size open for System Restore to run properly in case of a HDD crash or system crash.
Apr 21, 2009 | Microsoft Windows XP Professional
Abt crash dump
To recover your files you will need a 2.5" external sata usb hard drive case. Take the hard drive out of your lap top and install it in the case. Plug the USB drive into another computer with enough space to copy all the files you want to save. Once you have all the files backed up that you need format the drive and re install your operating system fresh. Then load all your rescued files back to your laptop with another external USB backup drive. This is the only way and I know it works because I have to do it every time I thrash my laptop running bad cracks. Please take the time to rate this fixya for sharing my secrets for free. If you need more help feel free to ask.
George
Apr 04, 2008 | HP Compaq Presario C500t Notebook
Toshiba Lap Top Model #PSAA2U-04E018
sounds really bad. hard drive crash scene most likely. You might want to boot from install disk to see if the rest of the machine is happy or not.
Feb 05, 2008 | Computers & Internet
Hard Drive Problem
Sounds like your hard drive is crashed. You will most likely need to replace it. Before it gets totally crashed try to backup your important data while it is running.
Hope this helps you
Oct 27, 2007 | Compaq Presario X1000 Notebook
Sony VAIO Digital Studio PCV-RZ14G PC Desktop Logo
82 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
