Question about Sony Cyber-shot DSC-W30 Digital Camera
My camera fall and it doen't open
I'm willing to open the camera but I need to know if there is an manual of the inside of this camera so I wont damage any parts of the inside
  • 69 Answers
You can buy thenm on E-Bay
Posted on Sep 21, 2007
So my nikon coolpix S3000 will not turn on. It got dropped while we were taking a picture and now it wont turn on and when i plug the charger in the green light does not turn on. I have taked the memory...
Possible failure within the camera, possible that the circuit board or connection has been damaged in the fall. If you notice any of these on close examination then it is important to open the camera to get an inside view , to test the circuit board, check if the main battery power comes to the main board- if there is any break of the battery line from the battery enclosure.
Is is most possible that the +B from the battery terminals is open due to the fall and must be checked.
Mar 28, 2011 | Fuji Cameras
I dropped my camera and now the lense wont retract all the way. a red screen pops up and says "Lens error, try turning the camera off then on again' the lense wont come out, what do i do?
There can be a mechanical break or a lens mounting break due to the fall and so the camera must be opened out to reset the lens hood.
You will need some experience to remove carefully and checck the drive for the dislocation of the motor control.
It can be a visual indicatiion to the fault if looked in and can be removed ,reset or the brokedn part glued into the mount.
Oct 01, 2010 | HP PhotoSmart M437 Digital Camera
Pentex k1000 rewind knob unscrewed, shaft fell inside camera
first make a small hook on the end of a straightened paper clip. insert the hook and pull up rotating the hook as you pull up. being careful not to bend the spring near the hole. once the back door is opened check the rewind shaft, there should be a beveled edge on the collar of the shaft. rotate the shaft while pushing up. if no beveled edge on the shaft use the paper clip to push the spring out of the way while inserting the shaft. if it still will not return file a bevel on the collar of the shaft. I am assuming there is no film in the camera as the canister will prevent the shaft from falling in.
Jan 29, 2010 | Pentax K1000 35mm SLR Camera
The power on sometimes just wont work? If I take the battery out and put it right back in, then it will come on, but sometimes it just wont turn on??
use a pebcil eraser and rub the terminals of the battery and the camera ensuring that you do not leave any runner debris inside camera invert it when you rub the terminals so the rubbush falls out
Please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
My lense wont open after a fall i want to replace the entire lense module when can i get it
1.) GO to the place where you purchased your Fuji FinePix. They will probably sell you a new lense (or camera). I dought that they wont.
2) if that doesnt work, then you can go to a repair shop and get it fixed.
#) Thank you, and have a nice day
Oct 13, 2009 | Fuji FinePix F20 Digital Camera
Lens mechanism is broken due to dropped. You need to replace lens assembly. If you know how to apart camera and replace lens assembly then let me know to guide you. Or take camera to local repair shop for fix.
Jan 09, 2009 | Sony Cyber-Shot DSC-S90 Digital Camera
SD Card
did you ever find a solution?
Dec 11, 2008 | Nikon D40x Digital Camera
Blackberry Pearl camera will not start
do a reset on the phone take out the batery and put it back in, if you have already doen that and it doesnt work still i would reset the settings byy goign into security options in your settigns tab and to reset settings to factory settings. but put all your pics, rigntones and contacts saved on your computer first. do you have a memory card? if you get one this could fix the issue as well
May 30, 2008 | RIM BlackBerry Pearl 8100
Dsc60 batterries run out quiclky
Test a different battery (one you know is good) on the camera and see if you still have the problem. If with you still have the problem then probably it is a short. Check first in battery contacts, if you can see a short there than it is an easy fix, otherwise you need to open the camera and test contact inside.
Mar 14, 2008 | Cameras
Sony Cyber-shot DSC-W30 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
