Question about Jeep 2003 Liberty RBQ AM/FM Radio w/ 6-Disc Integral CD Changer
Jammed CD I have a 2003 Jeep Liberty Limited. The problem started whenI pulled the battery cables to reset a trouble code. When I started the Liberty back up the radio was fine, but the CD sounded as if it was trying to start/load a CD. The CD does not show when pushing the Mode button. it goes from AM to FM.
  • Anonymous May 16, 2009
    I have a '05 Libby Sport that had the same problem. I was able to disassemble CD changer and remove the 6 CDs. There are six small metal spacers that go between the CDs, on the center hubs of these spacers are three small plastic fingers that hold them in place. On one the spacers one the small plastic fingers broke off (probably when the CD changer reset after I reconnected the battery after replacing a ECT sensor which had caused my Check Engine light to come on 6 months ago) which caused that CD to come loose and rattle around. I got the CD code and now the mode selections only show AM & FM. I tried to put the CD changer back into the radio and use it as a "5 CD" unit, but still had the no CD mode. Thinking of radio repair, not having a CD player or going aftermarket. EBAY has several similar radios, but not exact. An online Chrysler dealer (if they haven't been shut down yet) had an RBQ radio online for $499.00 (ouch). Good Luck to you.
    Problem Solver:
  • 10 Answers
Hello, I see your post is a few months old. If you still need help or a solution for this problem please feel free to contact me at rcruz@radiomedics.com
The loss of power to the unit should not have affected the CD player. It will re-sync upon powering back on but that is normal.
Regards,
Robert Cruz
1-877-4-RADIO-MD
Posted on Sep 09, 2009
Why doesn't door open?
With a dead battery the lock mechanism will not work nor respond to your fob! Use the normal key that you got with the car.
Feb 23, 2016 | Jeep 2003 Liberty LIMITED
Where is the bleeder screw for the heater located? Heater blowing warm air, I think I have an airlock.
Bleed screw, jeep liberty limited, 2002, 3.7 L, no heat - Fixya
www.fixya.com/cars/t14960103-bleed_screw_jeep_liberty_limited_2002
Nov 10, 2012 - bleed screw, jeep liberty limited, 2002, 3.7 L, no heat - Jeep Cars & Trucks question. ... Open Question ... Feel radiator and heater hoses, should be very warm to touch,if hoses ... Where is the location of the slave cylinder in a Jeep Liberty2005 ... Bleeding air out of a 2003 jeep liberty sport with a 3.7 motor.
Jeep Liberty - YouTube
? 7:17
https://www.youtube.com/watch?v=Nv0HpH2ymB4
Jan 24, 2014 - Uploaded by 1A Auto Parts
http://www.1aauto.com/1A/ThermostatHousingRel/Jeep/Liberty/ ... What no engine heater install 2007 3.8 j wrangler video ....When opening up the bleeder valve, do you just keep it crackedopen until you have no air bubbles ... already replacing the water pump at 138,000 on an '05 Liberty Limited 3.7L..
Nov 19, 2015 | Jeep 2003 Liberty LIMITED
We bought a used 2003 jeep liberty and the headlights are really dim. what would cause this?
Failing battery.
Failing Alternator.
Dirty battery contacts. Clean until shiny and coat with Vaseline.
Dirty or corroded connectors on the bulbs.
Bad ground connectting bulbs if they have a ground wire.
Better bulbs. I use Sylvania Silver Star, but the existing bulbs should be bright. Take it to an auto electrician if the above isn't obvious fixes when you look at them.
Nov 14, 2015 | Jeep 2003 Liberty LIMITED
What is wrong when my 2003 Jeep Liberty limited edition has a code of P0700?.Autozone cleared the P1776 code.,but problem started when new radiators were installed,drivg automatic shifting isn't right
You'll need to take it to a shop that works on transmissions.
Code 700 is a generic code that means the trans control module has found an error but no specific problem to test.
A transmission shop can check pump pressure and fluid flow among other things.
Sep 03, 2015 | Jeep 2003 Liberty LIMITED
Battery voltage low on 2003 jeep liberty 3.7 just changed altenator and battery
you reverse the battery cables?
you remove the alternator before pulling the battery NEG. LUG?
if you do pulled the alt, with out lug pull that blows a huge fuse.
battery voltage low and no voltage stated, nor how taken. (crankiing or not or both)
3.7 L PowerTech V6 (gasoline)
my guess is this is a NO CRANK post .?
"solenoid, code pops?" what is that, a noise? or?
what was **** ,
transmission wont , what.????
Nov 29, 2013 | 2003 Jeep Liberty
We changed the battery and could not find the radio code.Need ano
These Chrysler Jeep Codes are very hard to obtain for free from anywhere on the Internet.
You could try here
www.ukbookshelf.co.uk
as they offer a few of the older codes for free otherwise you will have to go to your Main Dealer or a Radio Decoding Service
Feb 15, 2010 | Jeep 2003 Liberty RBQ AM/FM Radio w/...
CD Changer doesn't work after changing battery on Jeep Liberty 20
The CD changer probably failed to establish it's link to the head unit when you put the new battery in.
Since you've already tried the clear button, I'd suggest unplugging the IP-BUS cable (black cable) from the back of the changer, wait a minute (literally, 60 seconds) and plug it back in.
Jul 20, 2009 | Jeep 2003 Liberty RBQ AM/FM Radio w/...
I have a 2003 jeep liberty limited edition. My battery died and i replaced it and when i started up my jeep again i went to listen to a cd and it wont go to the cd menu anymore. what could be the problem?
Your Jeep has a security feature.When you replaced battery it caused the cd player to lock up. You need to contact your local Jeep dealership to obtain the security codes to unlock cd player. They usually have that information available. Good Luck
Oct 16, 2008 | Audio Players & Recorders
Car Audio & Video Logo
683 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Oloyede Monsuru
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
