Question about Sanyo EasyStreet NVM-4370 Car GPS Receiver
Stop play movies screen says no video player installed
My sanyo nvm 4370 gps usto play movies now the screen says no video player instaled
  • itekmusic Apr 24, 2009
    yes i can run all other applecations fine except video player screen keep saying ( no video player installed ) it use to work fine .... sanyo nvm 4370 easy street gps .....
  • KhaKev May 11, 2010
    Can you run other application such as Music, Photo, etc.. from the Main Menu? Sound like \ShellDisk\Shell\voPlayer (Video player) might be corrupted.
  • 20 Answers
ShellDiskShell oPlayer must be corrupted. I have a solution for you but you have to install MioPocket from SD card.
1) Download MioPocket from this link
http://www.gpspassion.com/FORUMSEN/topic.asp?TOPIC_ID=109690&whichpage=1
Extract and copy the following to the root of your SD card:
Folders:
Media
MioAutoRun
Files:
MioAutoRun.exe
MioAutoRun.mscr
MortScript.exe
Sanyo_AutoRun.inf
2) Download a copy ShellDisk from my device here
http://www.megaupload.com/?d=8S9QZ5IE
Extact ShellDisk folder and copy to SD card
3) From SD card, rename Sanyo_AutoRun.inf to AutoRun.inf
4) Create a new folder and name it MySanyo
5) Power on the device, insert the SD card and wait for the install to complete. Now you have a brand new interface with all the tools that Sanyo lacks.
6) To fix the Sanyo video issue, go to Tools menu and open up CE Commander (aka File Manager). Now need to backup your ShellDisk to MySanyo folder.Within CE Commander, open ShellDisk folder on the left side (you should see Log, SanyoNaviConfig, Shell folders and InstallLog.txt). On right right side open MySanyo. Now use a stylus pen and drag and drop one folder at a time from left to right. When prompt, hit Copy. When all folders and files are copied check on the right side and make sure they are there.
7) Let's confirm if Sanyo video player is really corrupted. On the left side go to ShellDiskShell oPlayer and doude-click on voPlayer.exe to open. If same error go to next step.
8) Now, on the left side go to ShellDiskShell folder. On the right side go to ShellDiskShell (this is my copy). First, you need to delete voPlayer folder from left side and drag and drop voPlayer folder from right side to left and hit Copy button.
9) Repeat step 7 and see if you can open it now.
10) Last but not least, recheck if everything is working without MioPocket. Press the red X button on the upper right until you see the power option menu. Select Shutdown and press OK.
11) Eject the SD card and slide the bottom switch to OFF and ON again.
Hope this helps.
Posted on Apr 26, 2009
  • KhaKev Apr 26, 2009
    Note: YixYa stripped out the backslash on the folder path so I give it antoher try with double backslahes and hope it shows.
    ShellDiskShell oPlayer should be ShellDisk\\Shell \\oPlayer.
    ShellDiskShell should be ShellDisk\\Shell
    etc...
    but you know what I meant.
  • KhaKev Apr 28, 2009
    New link for ShellDisk: http://www.megaupload.com/?d=FMXUH1DR (step 2 above)
Sanyo 4370 canot start code10
Your GPS battery is dried out, use the original car charger or one that can output at least 1.5 Amp.
Jul 20, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Installing mio pocket on Sanyo 4370
As long as you did not delete any of the Sanyo files MioPocket should not interfere with the original software.
May 27, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
How do i add a 3rd party media player to my Sanyo EasyStreet NVM-4370 the video player stop working
MioPocket 2.0 R44 and higher will full fill your need. If you need to boot from SD card (support up to 32GB SDHC), then you need this file http://www.gpspassion.com/upload2/Sanyo_NVM-4370_Autorun_files.zip
Apr 19, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
How to add music and video files to the sanyo nvm-4370 gps system
Option 1 (Internal Memory):
  • Connect the GPS to your computer with a supplied USB cable
  • For Windows, go to My Computer and find the connected drive (Removable Disk), when you open this disk you should see MobileNavigator folder
  • From the root of this drive, you can create 3 folders: Photos, Music, Videos and copy your media files respectively
  • Safely Remove Hardware the connected unit and unplug
  • Select your player/viewer (Photos, Music, Videos)
  • By default the internal memory (a can shape icon) is selected
  • Now enjoy your media
Option 2 (SD Card):
  • Assume your computer has a SD card reader
  • Insert the SD card to your computer
  • Insert the card to the Sanyo GPS
  • Tab the internal memory option (a can shape) to change to SD card option (sd card shape) to access files on SD card
Feb 26, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
My sanyo nvm 4370 video option say no video player installed
This unit only supports MPEG4/H.264 file. The files format has to be .MP4. This unit cannot play all MPEG4/H.264 movie files. Most movies out there are converted using DivX or XviD codec so if you need to convert them to this supported format. It will mostly cost you time if you found a free converter.
If you don't have time. You might try my basic hack to add a 3rd party media player that will play almost everything out there and it also supports sub-titles. You can check out my video on YT @ http://www.youtube.com/KhaKev.
Feb 11, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Computer froze after installing gps cd nvm-4370
Yes, use Windows XP when running updates instead. Some have experienced similar problem with Vista.
Jan 06, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Sanyo EasyStreet NVM-4370 Car GPS Receiver Logo
624 people viewed this question
Top Sanyo GPS Experts
Are you a Sanyo GPS Expert? Answer questions, earn points and help others
