Question about Honda Water Pump Honda Engine
Honda GX120 engine keeps stalling out
We have a the above mentioned Honda engine attached to a 2'' water pump used to pump out the holding tanks of boats. For a while now when we start it will run for about a minute, start running rough and then stall out. It can be restarted again, right away, and the same thing will happen. We have installed a new filter in the tank, replaced the carburetor, removed the head to clean and inspect the valves (they look great) reassembled everything and the same problem exist. I don't know where to go from here. This problem started out slow and has gotten progressively worse to where it is today. After a few starts the spark plug is fouled black like it may be running too rich.
  • 1 more comment
  • Tom  Barnes
    Tom Barnes Apr 19, 2009
  • Kimbo too May 11, 2010
    you said that you replaced the carb, is the replacement a newie, or s/hand?. if its a s/hand one did you check the float level? try adjusting it. don't run the engine for long periods without an air cleaner either, that will shorten the life of the rings and valve seats.
  • billcurle May 11, 2010
    not sure if you have pump in to small area creating lack of air.take air filter out & run with plastic cover only.have found filters to be very restrictive.also check oil may have petrol in it,
  • 1383 Answers
SOURCE: pressure washer stalls
Pressure washers work under very dirty conditions, no wonder they encounter engine problems. Here are a few pointers from a former pressure pump tech. The unloader is a source of engine overloading however this can easily be checked with a pressure guage attached to the gun with a tee fitting having the guage and the normal tip used for the unit. The pressure should never rise over rated pressure. The pressure should drop considrably when trigger is released. The life of the pump and engine can be increased by setting max pressure to 75% of rating. Most engine problems are from following conditions:
Leaking or misadjusted valves; clogged muffer /spark arrester; weak spark coil that is about to fail completely; kill switch/oil sensor wiring and or sensor mal function; gas cap not venting properly causing vacuum in tank and wet or dirty air filter.
All these problems easy to check, fastest repair is to disconnect oil sensor wire to check oil safety system. Then temp replace coil with known good coil. Loosen muffer bolts to check for clogged muffler. Temp run engine without gas cap to check for vacuum. Finally if everything fails, run the engine with carb cleaner spraying directly into the intake. If the engine continues to run with carb cleaner then the problem is fuel delivey and faulty carb. enjoy
Posted on Dec 01, 2008
jeremythious
  • 37 Answers
SOURCE: 91 honda civic dx. Starts, runs for a few seconds then stalls
Try pounding on the gas tank with a rubber mallet or similar tool. (careful not to dent the tank) Try starting it. If it runs, replace the fuel pump (it's nfg). I've diagnosed numerous fuel pumps this way. Remember the pump needs to be replaced, if you drive it, you don't know when it'll fail for good. Hope this helps. Please post the results.
Posted on Feb 08, 2009
  • 16 Answers
SOURCE: 91 honda civic dx 1.5L quit running properly.
bro, check ur main relay. its under the dash. replace it, check also ur distributor(replace it). and also your ECU
Posted on Feb 22, 2009
Testimonial: "right answer but I received it much too late. I went to a mechanic and paid him to fix it."
  • 12 Answers
SOURCE: 98 Honda Valkyrie Tourer, engine stalls
Check vacuum line from #6 intake runner (port side rear cylinder) to the fuel petcock valve. The valve is vacuum operated for safety. It cuts off fuel to the carbs when the engine is shutdown. Hose could be cracked or diaphram in valve is cracked. Easy to inspect the valve.
Posted on Jun 07, 2009
SOURCE: My 1993 Honda TRX 90 Fourtrax has issues...
You will have to clean the carburator, blow the jets with compressed air,check the float level too and reset.
Good luck.
Posted on Jul 19, 2009
Van keeps shutting off on its own and overheating
you mean the engine, overheats then the engines stalls.?
that latter symptom is normal for overheating.
(some exceptions, ) my Corvette drops cylinders, 1 by 1 to stop
this.(but is still bad , if this happens)
does it overheat only stopped, only moving or both? (KEY question)
fix the over heat, cause. there are may ways to overheat.
from simple to comlex. and no web bunny on earth can guess it.
unseen.
ill list the simple:
1: low on coolant, no not the side tank, the actual rad is low,
check only on dead cold engine,below 125F (AZ temp)
2: bad RAD cap. not holding pressure.
3: wrong coolant mix or mixing 1 color coolant with another (bad)
4: water pump belt bad , or slipping or missing.
5: rad tubes clogged
6: fan dead,
7: RAD outside ofcore, blocked with filth.
8: blown head gasket,(or far worse)
9: bad water pump.
10: leaks anywhere, (this really is first)
one site that lists them all , every one,... is
http://www.fixkick.com/overheating.html
Nov 08, 2013 | 1995 Honda Odyssey
2002 Honda CR-V stalls, mostly when the gas tank gets low (aka light on) but not only then. Engine will not stay on unless its constantly gassed, when I come to lights, I put it in neutral and gas it
water in fuel. put some water remover or gas line antifreeze in and keep tank full. the reason its worse after sitting is because the water sinks to bottom of tank and then the car is trying to run on just water. after driving it mixes with fuel
Mar 11, 2013 | 2002 Honda CR-V
Toilet water tank keeps fillng above the water line. No leak anywhere.
Sounds like the float is not attached...it should be attached to the flapper ....it may need adjusting
Oct 16, 2012 | Fluidmaster Toilet Tank Complete Repair...
1996 honda shadow ace stalls periodaclly
Hi, Anonymous and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
13. Multi carburetors not in sync.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.fireblades.org/forums/honda-cruisers/88600-96-shadow-1100-ace-stalling-out-periodically-while-riding.html
Stalling Fuel problems
Honda shadow vt1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT1100C2 Owner Manual Page 3
Apr 14, 2011 | 1996 Honda VT 1100 C2 Shadow Sabre
1992 Volvo 240 sedan Sometimes Sputters when driving, and sometimes will stall. If I get out and shake it, it will start back up. Then check engine light comes on. Will drive fine for a few day's before...
could be the fuel computer under the dashboard. Could also be the electric pump in the tank. If you are lucky, as is often the case, it is not the pump, but the little rubber hose attached to that pump in the tank. Your car has 2 pumps, one in the tank, a submersible sending pump. The other is the main fuel pump under the hood. The tank one is easier to swap. There is an inspection plate in the trunk. You lift it out and then pull the unit by twisting the bung. I suspect the problem is here due to the fact you mention keeping it half full.
Sep 21, 2010 | 1992 Volvo 240
Honda gx120 starts runs for 45 secs, cut out then will restart 45
Sounds like fuel starvation. there is a small filter insde the tank. if you take the tank off you will see that where the fuel hose attaches to the tank. this spigot unscrews from the take to reveil the filter.
Hope This helps
Oct 01, 2009 | Karcher 2500 PSI Pressure Washer
2001 Hyundai Accent. Heating and stalls
If the water tends to keep going down then there has to be a leak somewhere. Try also looking at the hose coming from the overflow tank and see if the hose might be kinked. You might also be blowing antifreeze out the tailpipe. Take a look and if there is bluish white smoke then you have confirmed that theory,
Jun 10, 2009 | 2000 Hyundai Accent
We have a Honda GX120 engine attached to a 2'' water pump used to pump out the holding tanks of boats. For a while now when we start it will run for about a minute, start running rough and then stall out....
The one thing you did not mention was the type of spark your recieving at the spark plug. I recommend that a spark tester be used, which can be purchased at an auto parts store. Set the spark plug tester gap for 10,000 volts, or a good 3/8". You should see a nice sharp blue spark. If you are recieving this kind of spark, then with valves closed or at top dead center apply 30 psi into the cylinder. This test will let you know if the valves are seated properly. If valves are not seated properly you will hear the air come out from the intake or exhaust. So, it is either your ingnition coils or warped valves.
Apr 20, 2009 | Electrical Supplies
The gx 120 is only 3.5 hp, that's not a lot. For a 2" pump I would want twice that. You could look up engineering specs on other 2" pumps to see what they use. I've seen lawn mowers with more hp.
Apr 19, 2009 | Garden
Honda Civic Engine Problem
they are designed wih presure need to be in tank when you fill the car with engine runnig the gas cap removal will cause the engine to stall especially one with a week fuel pump.
Jul 06, 2008 | 2001 Honda Civic
Honda Water Pump  Honda Engine Logo
1,576 people viewed this question
Top Honda Tools & Hardware - Others Experts
John Loiselle
Level 1 Expert
Bill Boyd
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a Honda Tool and Hardware - Other Expert? Answer questions, earn points and help others
