Question about Mtd 22" Yard Machine Push Mower
The blade is loose and when i start the mtd the blade spins aroun
Freely. how do i tighten the blade. and do you have any pictures of what it should look like when it is repaired?
  • 10,865 Answers
U will need a wrench and a block o wood to prevent the blade from turning while u tighten it. if u take the mower to an auto zone store they will loan u the wrench u need and even assist u
Posted on Apr 19, 2009
The blade does not tighten on the spindle and just spins freely. Even tightened down the center nut does not make a good connection to the blade.
There is a positioning "washer" that needs to be in place. If you don't line up the blade and position the washer it will not tighten. The blade will just spin around. Some even have a washer in front and in back. Be sure you have correct diameter of arbor that matches your blade too.
Feb 15, 2016 | Saws
Why can't the mounting nut be tightened?
The blade may not have been reinstalled correctly and/or the nut may have gotten cross-threaded or stripped in the proces
Oct 05, 2015 | Patton Dryers
Why can't the screw be tightened?
First of all, the blade has to be seated correctly on the spindle and the screw hand tightened to hold it in place. Next, a locking device such as a screwdriver has to be inserted crosswise between two teeth to prevent the blade from rotating. With the blade locked, the screw can be tightened. Finally, be sure to remove the locking device before operating the saw.
Oct 05, 2015 | Saws
I have a Husqvarna Z4217 was cutting and blades started making a rattling noise so I cut it off checking the blades the one on the right is loose but when I try to tighten it the pulley turns the blade...
You can use a block of wood and I even locked mine with a pair of vice grips or if there is room a pipe wrench. It would help to take it completely off and squirt some oil on the threads and start over then when you sharpen the blades they will be easy to take off later. I would sharpen the blades before you do this as well.
Mar 17, 2015 | Husqvarna Garden
Loose blade
loose the lock washer before you cut your own feet off or kill the neighbor with blade flying off ! Put bolt in and tighten make sure alignment pins on blade are where they are supposed to be . make sure no grass is caked up around any of the blade or drive shaft
Jul 26, 2013 | Mtd 22" Yard Machine Push Mower
Mtd engage blades it smokes and make noise
Have you physically moved each blade by hand (with the machine shut-off),spark plug disconnected to see if both or all of the cutting blades move freely if there is any binding you probably have a bad blade spindle bearing . If those move o.k. then you're going to want to check the pulleys on top of the deck, one of these which do not go to the blades may possibly have a bad bearing and is not moving freely causing the belt to be burning up.
Dec 03, 2012 | Garden
I have a 20 hp MTD Yard Machine with a 46 inch deck. I was cutting some thick overgrown grass today and the belt started smoking. I immediately disengaged the PTO gave it a minute and tried to re-engage...
you should take a picture of how the belt is on there now so you will know how to put it back on. check to see if the blades will spin freely with it not running of course. put your hand under it and spin the blade. if they don't spin you may have something wrapped around the spindles causing the blades not to spin causing the belt to smoke. if the belt is cracked or missing any chunks you may want to replace it. take a picture so you will remember how it goes back on.
Sep 18, 2017 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
MTD 42" CUT MOWER MODEL 42A707 TYPE 1238 01 CODE960 2085A. 1) Mower blades do not stop spinning when deck is raised all of the way. 2) Left blade intermitantly makes a horrible noise when cutting grass...
I think either the bolt holding the left blade onto the spindle is loose, or the cup washers under that bolt are flattened or missing. As a result, the blade is slipping on the shaft and probably making a squeal or squawk. Take off the deck, flip it over, and remove the blades. Note if the bolts seem tight. And look at the washers stacked under the bolts. Replace any missing washers, or flattened cup washer. Make sure the cup washer faces the right way (hollow side toward the blade). Tighten things back up securely - it takes a hefty pull on the end of a 2 foot long wrench to get enough torque.
Jun 18, 2010 | Mtd Garden
The newly purchased deck belt turning the blades is extremely loose
If idler is in tact and spring attached, it is likely that the belt isn't routed properly. If you try to route the rear-most portion of the belt around the idler, it will be loose. You must route the front-most portion of the belt around the center blade pully and then around the idler. Just Google "MTD 46 inch deck diagram" and you will go to a Parts Tree site with the proper diagram showing routing.
May 26, 2009 | Mtd Garden
My Yard Machines MTD blade won't engage. The belt that spins blade is loose when I try to engage deck.
My mtd 20 hp mower, blade will not engage, found a large spring and a small metal piece that came off and I have no Idea where it goes in order to get this blade going again, can some one give me some info Please..
Apr 19, 2009 | Garden
Mtd 22" Yard Machine Push Mower Logo
120 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
