Question about RCA P61960 61" Rear Projection Television
Not all buttons on front work
I cant get the remote or the front buttons to work. The only buttons on front that work are channel and volume. The remote dont work at all. I have to unplug to turn off!!! Help!!!
  • Anonymous Mar 16, 2014
    Help
  • 61 Answers
Sounds like the front panel buttons are your trouble,you can disconnect these buttons from the rear of the set ,unplug the set and remove the back cover,just below the top screws you removed you can look under and see the top of the tubes,in front of the middle tube is a small board,unplug the right top cable and this will restore the set,just the front buttons will not work,use the remote
Posted on Mar 07, 2008
SOURCE:
My samsung le32r74bdx remote control wont change channels and cant turn volume on tv up or down
You can verify that the remote is working. Get a digital camera with a LCD display.
Aim the remote at the camera lens and press the volume and channel buttons. If you do not see
a flash through the camera the remote is bad or the batteries are dead.
If you know someone with any samsung hdtv remote, you can borrow it and try the volume/channel
to see if the tv remote receiver is good.
Feb 08, 2011 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Tv doesnt respond to buttons or remote
this is looking like a common LG problem our tv started doing this tonight
May 15, 2010 | LG 42LC2D 42 in. LCD HDTV
I have a philips I got from a hotel but i cant program the channel to 3 to hook up a dvd player even with a universal remote what do i do?
Channel 3 is probably locked out... here is how to fix it....
1) Press the Menu button on the remote or press both Volume buttons on the front of the TV to access the TV's internal menu's
2) Scroll to highlight INSTALL using down arrow on the remote or Channel - on the front of the TV.
3) Press the Right Arrow on the remote or Volume + on the front of the TV to access the INSTALL menu.
4) Scroll to highlight Channel Edit using down arrow on the remote or Channel - on the front of the TV.
5) Press the Right Arrow on the remote or Volume + on the front of the TV to access the Channel Edit menu.
6) Use the Left or Right Arrow on the remote or Volume + / - on the front of the TV until you get to Channel 3.
7) Use the Down Arrow on the remote or Channel - button on the front of the TV to select SKIPPED.
8) Press the Right Arrow on the remote or Volume + on the front of the TV to select OFF.
9) When finished press Exit on the remote or press the power button on the TV and then power the TV back on.
You should now be able to use channel 3.
Good Luck....
Jan 15, 2010 | Philips 20PT6441 20" TV
Remote will not change the volume
Is the front funtion button works in the TV the it could be a bad remote controller(the button switch inside) :)
Apr 14, 2009 | Hitachi 43FDX01B TV
Cant change channel
The up/down ch buttons will only go to channels that are set up in the tv....go to the menu....settings....and set up the channels you wish to view, once the channels are set up, the buttons will work
clarkco
Feb 27, 2009 | iLO 3200 32 in. LCD Television
Remote and caption problems
have you programmed the remote? or you can go into the menu button on the front of the tv, use the up down (either the volume or channel may move the selection) to locate the caption on/off control and turn it off that way. if you need the manual try here
http://tv.manualsonline.com/manuals/mfg/philips/19_inch_color_tv_cover_l9_pr1903c1.html
Dec 02, 2008 | Philips Magnavox Learning Universal Remote
Front buttens locked and no remote rca d52w19byx1 itc222
when using your remote once you get to where you want to Go to adjust press channel up & down buttons this will let you scroll up and down and then use vol- vol+ to make adjustments.use buttons on front of tv.ThankYou for using FixYa.Have a Nice Day.
Feb 05, 2008 | RCA D52W19 52" Rear Projection Television
RCA P61960 61" Rear Projection Television Logo
100 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
