Question about Acer TravelMate 2300 Notebook
Cant get full disply up on remote monitor
Hi i used to be able to connect to projector or remote monitor easy with my lap top and see what you see on my laptop. ive recently had vista ultimate installed on my machine and now all i can get is monitor exstension! (my dispay extended onto another monitor as a second screen) i want to be able to put what you see on my laptop onto another monitor....can you help?
Tutorial
Hi Connect your computer monitor out VGA connector to Computer input VGA connector of projector. Select source in projector (with remote) as computer/RGB/VGA as terminology used on the projector..
The projector will work as large screen projection monitor for the projector.
If you want to use monitor and projector both, you can use 1IN-2 OUT VGA distribution amplifier (Commonly called as "VGA Splitter"
Jun 26, 2012 | NEC Np13lp - Projector Lamp - 180 Watt -...
Why wont my movietime projector play from my lap top when connected by the D-SUB, i have used fn +4
All lap tops are different and some are f7 or f10. The picture that your looking for is the one square half way over another square. and make sure that the input selected in the projector is the same as the input you've connected the laptop to.
Feb 28, 2011 | Optoma MovieTime DV10 Multimedia Projector
I am using a Dell lap top with Windows Vista to connect to a NEC VT590 projector. I want to show a PowerPoint presentation. As the computer is booting, the computer monitor is blank and the loading...
You need to configure the projector as a second monitor as explained here
http://www.online-tech-tips.com/windows-vista/multiple-monitors-vista/
Feb 02, 2011 | Computers & Internet
TRYING TO GET THIS PROJECTOR TO SYNC WITH DELL LAP TOP
press Fn button and F5.
or in display properties use the secondary display to be set as primary.
dont forget to vote fixya rating
Sep 13, 2009 | BenQ PB6110 Multimedia Projector
Monitor goes to sleeep on lap top
Hello, you can try this... Connect your laptop with an desktop monitor throughVGA cable.... then Click on start>> goto control panel>> Double click on Power Option>> Under Power Scheme it should be Poratble /Laptop >> Select Never under System Standbye, Trun off Monitor and Turn off Hard Disk.
Thank you for contacting Fixya support, please rate if that helps!!
Sep 06, 2009 | Relisys RLT1720 17" LCD Monitor
Multi Media Projector Problem
Open power point first, open full screen and proceed. Do not double click on the file.
In the explorer window, you can change the .ppt association away from the easy worship tool and restor it to power point. This will open .ppt files with power point.
Good luck
Apr 08, 2009 | Hitachi CP-S240 Multimedia Projector
In focus x3 projects computer start up screen, then just searches
the resolution may have changed. reselect the computer or auto-image.
Jan 20, 2009 | InFocus LP640 Projector Multimedia...
How to hook up BenQ PB6100 Digital Projector to a lap top?
Use a standard "video cable" that is used to connect a desktop to a monitor. Your lap-top will also have a similar video out - this is a blue colored outlet jack on your ap-top with three rows of 5-pin holes. The BenQ also has a similar blue receptor jack almost next to the place where you plug in the mains power cable on the rear of the unit.
Dec 20, 2008 | BenQ PB6100 Multimedia Projector
TDP-S20
Click the 2 box on the display settings and put a check mark ano the box that is say to extend the view on to this monitor. Hope this Helps.
Jun 17, 2008 | Toshiba TLP S30 Multimedia Projector
Power Point Presentation Using Sanyo Pro Xtra X Multiverse Projector
Don't forget to select the Fn key and F4 on HP laptops. It could also be the Fn key and F8 depending on the laptop brand. It is the apple key and the F7 key on a Mac notebook. On Laptops this will toggle the video to the aux port where the monitor cable connects to the projector. There are 3 modes. video on the laptop screen, video on the laptop and projector, or video to the projector only.
Master Rod
Mar 11, 2008 | Sanyo PLC XU35 Multimedia Projector
Computers & Internet Logo
106 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
