I ordered a part from ebay seller who swore this was the correct part. Took me ages to fit as cant get oven out to access the back.... When finally got around to placing the bulge plate back on I found the element is too large and sticks out .5mm more than the old one. Will it matter if the element is touching or will I have to go through the rigmarole again and get a new part?
SOURCE: WHY CANT I TAKE ELEMENT OUT
If you cannot remove screws from inside oven compartment, then, yes, it will be neccescery for you to remove the oven from it's housing to gain access to the screws from the rear.
thanks for your help!. I needed to use it last night so i places a nut on both bulge plate mounting screws to make it sit out and not touch the element.- not sure what this will do to the heat flow as there is now a gap at edges all the way around. Might just take the bolts out??
