Question about RTO Esab Handy Plasma 550 W/25' Pt 31XL Torch 0558002612
Pulsating Arc ESAB Handy Plasma 550 - Starts to cut then the arc pulsates and cuts a dotted line. The arc seems to be fine and the pulses are regular. What do I need to do to get it to cut a regular line?
  • 37 Answers
Sounds like one or two of the power diodes are defective (open), producing a half wave pulse instead of full wave, giving it a dotting effect.
Posted on May 15, 2009
Pilot arc is highely spreaded
change the cutting nozzle
Mar 23, 2012 | Hobart Welding Tools
Is the esab 1250 worth buying and how much should i buy it for
Hi:
Esab's plasmas and machines are the best for manufacturing and shop maintenance. Are made for the tough jobs. Retail price brand new price is around 3200.00 US dollars.Cutting wise is a high speed cutting machine and will cut up to 1-1/2".
Mar 07, 2011 | RTO Esab Power Cut 1250 Plasma W/Pt 32EH...
Powers on airs on air starts wen triggers pressed no arc.
inside the unit their is a part witch looks like a spark gap and that is what it is if this part gets dirty of has like a magnetic fuzz in it it will need to be cleaned as well the gap should be reset you will need to contact the manufacture for the specks do to different units have different settings wile you have the side off look for lose connections as well as arking marks for passable shorts their is a variety of things that can go wrong with thease units but what i said is most common do not use high pressure ari to blow clean a metal chip can damage transformer windings and then short out be careful of capacitors they can hold a nasty charge and aslo can be lethal if your not sure i highly suggest you take to a service center for the unit you have hope this helps.
Aug 27, 2010 | RTO Esab Handy Plasma 550 W/25' Pt 31XL...
ESAB 550 plasma cutter will not shut off, I suspect a bad switch
unlikely, the switch poles are not making contact or a wire has come adrift from one of the swiutch poles.
Jun 23, 2009 | RTO Esab Handy Plasma 550 W/25' Pt 31XL...
Plasma cutters Question
There are a few things about plasma cutting safety that are different from general welding safety tips This short list of plasma cutter safety tips is geared toward light duty plasma cutting using compressed air not large industrial units that use gas mixtures and water cutting tables. Electric Shock Can Kill - Operating a plasma cutter completes an electric circuit between the torch and the workpiece. The workpiece and anything touching the workpiece are part of the electrical circuit. - Never touch the torch body, workpiece or the water in a water table when the plasma system is operating. Voltages & Currents - Plasma cutter output voltages are much greater than welding voltages, usually 100-200 volts. Precautionary Measures - Do not pick up the workpiece, including the waste cutoff, while you cut. Leave the workpiece in place on the workbench with the work cable attached during the cutting process. - During plasma cutting operations do not move the work clamp. Wear insulated gloves and boots, and keep your body and clothing dry. - Do not stand, sit or lie on or otherwise touch any wet surface when using the plasma cutter system. - Insulate yourself from work and ground using dry insulating mats or covers big enough to prevent any physical contact with the work or ground. If you must work in or near a damp area, use extreme caution. Work Cable - Ensure metal-to-metal contact between work cable and workpiece or work table. - Work cable clamp should make contact with clean metal free of rust, dirt, painted surfaces, etc. - Do not attach work cable to the piece that will fall away when the cut is complete Plasma cutter Arc Rays Plasma cutter arc rays produce intense visible and invisible (ultraviolet and infrared) rays that can burn eyes and skin. Protective Clothing - Guantlet gloves, safety shoes and hat. - Flame-retardant clothing to cover all exposed areas. - Cuffless trousers to prevent entry of sparks and slag. - Remove combustibles, such as a butane lighter or matches, from your pockets before cutting. Noise Levels of Plasma Arc Cutting - Plasma arc cutting systems can generate noise levels in excess of 120 dB during high-amperage cutting operations. - Ear protection should be used when operating or working near plasma arc cutting operations. Toxic Fumes & Gases Plasma arc cutting can produce toxic fumes and gases that deplete oxygen and cause serious injury. - Keep the cutting area well ventilated or use an approved air-supplied respirator. - Do not cut in locations near degreasing, cleaning or spraying operations. The vapors from certain chlorinated solvents decompose to form phosgene gas when exposed to ultraviolet radiation. Pacemakers & Hearing Aids - Pacemaker and hearing aid operation can be affected by magnetic fields from high currents. Pacemaker and hearing aid wearers should consult a doctor before going near any plasma arc cutting and gouging operations Overall Plasma Safety - The plasma arc cutting process can be very safe. - By paying attention to safety standards and correctly setting up and operating the system, plasma arc cutting poses no more a threat than most welding processes.
Aug 27, 2008 | Miller Spectrum 375 Cutmate Plasma Cutter...
Plasma cutters problem
Depending upon the design of the torch (e.g., orifice diameter), electrode design, gas type and velocities, and the current levels, several variations of the plasma process are achievable, including: * Plasma Arc Welding (PAW) * Plasma Arc Cutting (PAC) * Plasma Arc Gouging * Plasma Arc Surfacing * Plasma Arc Spraying
Aug 27, 2008 | Miller 903777012 SPECTRUM 2050 PLASMA...
Plasma cutters support
Plasma Arc cutting is an excellent choice for most cutting applications but it is particularly well suited for applications where speed and excellent cut quality are important. Because of the intense heat of the plasma arc – around 40,000° F compared to 5,700° F, with gases used with Oxy-Fuel torches – the cut is clean with little or no dross.
Aug 27, 2008 | Miller Spectrum 1000 Plasma Cutter...
RTO Esab Handy Plasma 550 W/25' Pt 31XL Torch 0558002612 Logo
217 people viewed this question
Top RTO Welding Tools Experts
Bill Boyd
Are you a RTO Welding Tool Expert? Answer questions, earn points and help others
