Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
The blades turn then stop on their own,is there an
It is a craftsman dyt 4000. When I engage the blades, the blades turn then stop on their own,is there an adjustment? There does not seem to be any rhyme or reason it just happens sporadically. However it does occur several times during each use. It may ride 40 feet cutting then the blades simply stop turning for a period and then they start again on their own. That is why I am thinking something must be out of adjustment.
  • bargainbin2
    bargainbin2 May 11, 2010
    Does this mower have a manual or electric clutch to start the blades.
  • 437 Answers
Look for your model number under the seat. Sears website is www.searspartsdirect.com. It sounds like a bearing may be wearing out, or a spring on one of the brake arms is not holding the brake arms off the pulleys;
Or an idler pulley is not holding tension on the belt.
There is not adjustment I know of, just replacing worn parts. Hope this helps. Good day.
Posted on Oct 22, 2009
Cuts off after engaging blades
I would have to say the blades are either sized or some safty thing is switching on when you engage the blades.
Apr 19, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have the DYT 4000 model. My tractor will start
SOUNDS LIKE YOU HAVE ONE OF YOUR OTHER SWICHES ARE BAD LIKE THE SEAT
Sep 29, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
24 hp intek has no power when under a load mainly when blades are engaged blows smoke like crazy.i pretty sure rings are shot,but the no powers got me stumped. valves are adjusted properly. i thought it...
I have good news for you,well sort of,the rings are probably ok.The intek engine is noted for blown head gaskets.They leak between the cylinder and the push rod chamber.A way to check is to start the engine for a minute,turn it off and pull the dipstick out,if you see vapors coming out of the oil fill tube it has a leaking head gasket.To check to see which cylinder is leaking, check the plugs,there will be a oil residue on one or even a brown crusty build up on the side that has the leaking head gasket.If you remove the head you will probably see a small piece of the gasket is missing on one side of it.
Aug 11, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Mower blades engages but when I stop to empty grass they will not
yes it is there is one under the seat & under the dash & there is also one connected to the clutch/ brake peddle which is more than likely the one giving you problems is the clutch/brake peddle switch
Jun 22, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman DYT 4000, 24 hp 48" deck. While I was mowing, the blades stopped turning, started again, and then stopped. I shut down, all looked OK, tried to start and nothing. No click, nothing. Any ideas?
there is a fuse in engine compartment that might have blown causing the engine or blades not to start but what probably happened was something got caught in the blades check under the deck & see if there is & also try spinning blades by hand & see what happens
Jun 12, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Replacing the blades on a craftsman dyt 4000
Not a hard job, but you will need a couple of tools. First, you will need a wrench that fits the nut that is holding the blade on. I prefer a closed end wrench, but an open end will do. Second, you will need a blade changing tool. The brand name is called a Blade Hog. It attaches to the deck and holds the blade in place so you can turn the nut. Raise the deck as high as it will go, attach the Blade Hog, and then loosen and remove the nut. Be sure and pay attention to which side is up on the old blade and put the new one on in the same manner.
hope this helps,
c
Sep 21, 2008 | Craftsman Garden
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
487 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
