Question about Kenmore Dryers
Dryer won't get hot anymore.
Dryer: Kenmore Gas Dryer (Heavy Duty, Soft Heat, Ultra Fabric Care, Extra Capacity) Serial #: MD3901212 Model #: 97581110 Stock #: 75811
Problem: dry does not get hot when put on  Normal, P. Press, & Cotton - Medium-High) at all. It will still air dry (Delicates), but that literally takes hours on end to do. Since I have a family of four, that doesn't work for me.
Any suggestions as how to fix?
Brian
5 Suggested Answers
  • 489 Answers
SOURCE: cannot select all cycles
You have a problem with the display board and may need to be replaced.
Posted on Apr 28, 2008
futureloginn
  • 734 Answers
SOURCE: dryer won't start due to delay button lights up and won't go off
1. No power to the dryerMake sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
Posted on Dec 02, 2008
hunter19_46m
  • 7482 Answers
SOURCE: We have a Kenmore Ultra Fabric Care Heavy Duty 80
You probably have a faulty heating coil, or thermostats.
If you plan to repair it yourself, remove the back of the machine, locate the air tube going from the blower to the drum. Normally inside of the air tube is where you will find the heating coil, and thermostats.
Check your heating coil with a continuity meter across the two terminals.
Good luck,
I hope this helps
Posted on Oct 05, 2009
heatman101
  • 43501 Answers
SOURCE: i have a kenmore ultra
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 01, 2011
I have a kenmore ultra fabric care heavy duty 90 series soft heat i will not come on hum not nothing
heatman101
Aug 28, 2011 | Dryers
Kenmore dryer Ultra Fabric Care 90 series. No
If you have a gas dryer check out this tip...
If you have electric check out the tip for electric at the bottom of the gas tip...
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
heatman101
Mar 25, 2010 | Kenmore Dryers
Kenmore dryer shuts off after five minutes
The vent box inside the dryer still has lint in it. You need to reach way inside to get at it. Turn power off.
Jul 22, 2009 | Dryers
Kenmore, heavy duty dryer, 70 series extra capacity, not heating
The following link explains how to diagnose a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you require addtional assistance, please let me know. I hope this helps you diagnose your problem.
Aug 12, 2008 | Kenmore 63942 Dryer
Motor removal and replacement on a kenmore electric dryer 90 series model# 110.86984110
remove screw at each end of console. pull & flip back out of way. remove top, remove bottom panel, slide putty knife to release both retainer clips. remove screws to remove door panel assy. remove belt, remove drum. remove motor clamps & remove wires from motor conector.good luck.
Aug 07, 2008 | Dryers
Dryers Logo
172 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
