Question about Sansui HDLCD3210 32 in. LCD TV
I am having trouble hooking up a PS3 I am receiving no signal
I am able to run a normal DVD, VCR and stereo but with the PS3 it simply doesn't take. I am using a universal remote rather than the oringinal remote. Could it be that I am not able to access the inputs I need? When I use the HMDI cord both ports are not reading it for either audio or video. Are there seperate inputs such as video 1 and 2 that my universal is unable to tap into? Any help would truly be appreciated. Thanks John
  • johnnyrock0 Apr 19, 2009
    I am able to access the following inputs on both my universal remote and on the tv itself composite 1 and 2 HDMI 1 and 2 component, PC and S Video none of these seem to be the correct input are there others that are simply not coming up such as video 1 or 2 like most other tv's?
    To hook up the PS3 there is a HDMI connecter that is an ubs that splits into the red yellow and white three prong cord. Unlike the PS2 it does not have the appropriate jacks to go three prong to three prong
  • 41 Answers
Is there buttons on the tv where you can switch inputs? if so try using those and get to the correct input. that would tell you if it is the remote or the tv.
Posted on Apr 19, 2009
  • ZaneD
    ZaneD Apr 19, 2009
    what kind of connection are you using to hook it up?
I need the wireing to hookup to a tv.
Hi, it depends on the kind of TV your using...
How to Hook Up a Receiver to an HDTV
Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
Instructions
things you'll need:
* HD television
* HD satellite or cable receiver
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar).
Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV.
Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row.
Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV.
Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will).
Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal.
Tips & Warnings
Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
Mar 15, 2011 | Audio Players & Recorders
I cannot get any sound to the speakers, hooked up receiver to new HD tv and not what input source or settings to use??
Hi, it's a general process to connect any receiver to a HD TV.
Things You'll Need:
* HD television
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Instructions
Tips & Warnings
Hope it helps.
Good luck..
Feb 23, 2011 | Kenwood VR-406 Receiver
How do i connect the vcr to tv
Instructions
  1. Lay out your items where you want them to stay. Hooking up a VCR and then not being able to fit it where you want it is a bit frustrating. Put the VCR where you will want it to stay and make sure that your cables are long enough to reach from the VCR to the television. Be sure to have the TV angled how you will watch it so that the cables can be measured appropriately.
  2. Connect your signal in from your source to the VCR. Whether it's cable or satellite, connect your source to the VCR through the coaxial cable input. This is often labeled as CABLE IN, but it's the same jack for a satellite signal as it is for cable. If you are using cable, you can run the wire right into the VCR or through a receiver. If you are using satellite, you will have to run the cable through a receiver.
  3. 3 Connect your VCR to the television with an RCA cable. To do this, run an RCA cable from the VCR OUT to the television IN.
  4. 4 Check your settings to be sure that the signal reaches the television. If you are connected through a receiver that will change the channels, you will have to set your VCR to either channel three or four to send that signal to your television.
  5. If you have other sources you want to use, either before or after the VCR in the signal flow, you can add them as needed. It's possible to connect two VCRs or connect a VCR to a DVD burner for archiving purposes. To do this, you'd simply run additional cables either IN or OUT of the VCR, corresponding with the appropriate IN or OUT of the other device. As long as your signal has a starting place and a final destination, you can set up all of your equipment how you'd like in the middle.
Jan 13, 2011 | Televison & Video
I have no TV box but do have cable, how do I hook up TV,VCR,DVD, and YAMAHA HTR 6030
For watching TV, your TV should have a monitor out. This will go to your CBL/Sat input on the receiver. If you have a newer TV, it will have an optical output,if you use that, you will have Dolby Digital surround when available, and digital stereo at all other times. For the VCR and DVD, if they are separate units, Run audio video from the VCR to the receiver to VCR 1, for the DVD, use Component video and optical or digital coaxial to the receiver. Then from the receiver run component video to the TV. If you need further help, post a comment and I will help you further. Hope this helps
Dec 28, 2009 | Yamaha HTR-6030 Receiver
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
I am having troubling hooking up my PS3 to my denon AVR-1907 receiver. I am using the PS3 component inputs and hooking them up to the "VCR" input.
Connect your component cable to the PS3 OUTPUT (there is no input) and connect that to the component IN on your receiver.
Jun 14, 2009 | Denon AVR-1907 Receiver
Sound Just Stopped Working
I have the same problem with my 49txi, and I called pioneer and a repair shop as well. Both told me that the 49txi has a known problem with over heating and that its boards unsolder themselves. I would have thought Pioneer would stand behind something this expensive, but that was the old Pioneer in the 80s, and the new Pioneer says we are on our own.
May 29, 2008 | Pioneer VSX-49TXi Receiver
Hooking up a DVD player to a Quasar TV/VCR Combo
Yes, for a workaround. The adapter would be 2 RCA female to 1 RCA male. You have to connect both the red and white to the female RCAs and use the male to connect to the TV's Audio INput. The yellow goes to the video. There should be no negative technical effect other than lost of stereo quality. The audio output of the DVD is line level and could normally tolerate this condition.
The correct method is to use a simple line level audio mixer and mix the L& R audio signal to produce a mono signal or to use a stereo amplifier for the sound output.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 07, 2007 | Quasar VV-1302 13 in. TV/VCR Combo
Sansui HDLCD3210 32 in. LCD TV Logo
310 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
