Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
Buzzing noise coming from my speakers....
It just started about 2 days ago for no apparent reason and the only way I can seem to get it to stop is to mute the audio on the unit. I have attempted to change the sound configuration settings (balance, treble, bass, SRS WOW) but nothing seems to work. Any ideas?
I just did this last week, i had the same problem all you have to do is grab some speaker wire and wrap it arround the RCA's(around the metal or gold piece outside the RCA) that go to your voice AMP and then ground the speaker wire(the one you wraped the rca's with). this will work. NO Noise filter will work cus I tried it
Posted on Sep 06, 2009
I had the same issue with realtek, just updated driver and all turned out ok, No more buzzing sound...
Posted on Dec 31, 2009
If you are using a cable box your sound on that or on the tv is too high and causes feed back.  Adjust both sound volums or better yet turn down the sound on the cable box all the way down.and just use the sond control on the tv
Posted on Oct 19, 2007
Britness or refresh rate can help
Posted on Sep 26, 2007
6ya staff
SOURCE:
I have a PSW-D112 that has little use, i just hooked it up 2 days ago and was working great and I shut it off by the switch on the back of the unit now today I went to turn it on and it made a buzzing...
What happens if you disconnect only the source end of the RCA's? Atmospheric noise can enter through the cables if their shields are grounded well.
Google: "speakers buzzing"
Aug 03, 2011 | JBL PSW-D110 Speaker
Subwoofer Emits a Buzzing Tone
The 2200 uF capacitor in the power supply has gone bad and the humming is a 60 Hz from the rectification of AC to 18 vDC.  Either get a new power supply or take apart the power supply and replace the bad cap.
Mar 16, 2009 | Altec Lansing AVS 500 Computer Speakers
Toshiba 36zp18q buzzing noise.
Humming sounds come from the power supply and buzzing sounds come from other circuitry. Most likely a capacitor somewhere.
Feb 18, 2009 | Toshiba 36A40 36" TV
Weird, annoying noise every so often
Is this happening on just on input?
If so... Check your connections. If you are using the component cables, make sure you haven't plugged the right audio into the red video input. it's a common mistake. I see it all the time.
If this is happening on all inputs, be sure the noise is coming from the speakers. Then replace the main board.
Nov 28, 2008 | Philips 42PFL7403D/27 42 in. LCD TV
Maytag gas dryer noise when burner comes on
The noise you are describing is coming from the gas valve solenoid coil assembly. This is usually indicative of weak coil.
If this is a warranty situation, request a factory authorized certified technician to replace the solenoid assy. at no charge.
If you want to fix it yourself, be sure and ask us for instructions on replacing the part safely.
Thank you for contacting us at FIXYA.com
May 28, 2008 | Maytag HYG2460AWW Gas Dryer
Distortion/noise and buzz in front left speaker
Try to see if the reciever will make the buzzing/noise without anything connected to it except power, and speakers. Tune into a local radio station and see if the noise continues. If the noise has stopped, then you know there is an issue with the player or cable.
Dec 28, 2007 | Onkyo TX-SR503 Receiver
Noisy dishwasher
i have aloud buzzing nose and humming what is the problem
Oct 29, 2007 | Dishwashers
ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
1,964 people viewed this question
Top ViewSonic Televison & Video Experts
Jaime Hernandez
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
