Question about Krups XP4030 Espresso Machine
No froth I have a krups Expresso machine XP 4030 (only a few months old)...perfect froth first couple of months. Now some steam but lousy froth! Cleaned everything. Cannot figure it out and not new to doing this...never with a krups tho. Running out of patience...help!
  • Anonymous May 12, 2009
    My Krups XP4030 has never had a good steady steam volume and is getting worse. The steam heater cycles on and off too soon and does not stay hot enough to give good steam. Also, had a selector valve problem from too much grease during initial assembly; steamed to the tray instead of the steam tube. Was able to fix that, but it's a major task to disassemble. Would not recommend the average person trying to do this repair. The steam system has major design faults.
    M. Kurtz, Auburn, WA
    Sergeant:
    Champion:
  • 245 Answers
Ing it back to store and tell them ur problem....u can ask for repair or a new machine
Posted on Apr 19, 2009
When I try to make espresso with my new XP2070, water comes out through the steam arm and not through the nozzles. I've tried it without coffee and all the water still comes out through the steam/hot water...
David, the XP2070 won't operate properly until you've set the clock on the unit.
In case you don't have an owner's manual, I've attached a copy of the manual from the Krups site that you can download and print for free.
Please take some time to reaquaint yourself with the setup and procedure for using the expresso portion of the unit, as you might just have some sequence issues that is preventing the expresso from getting brewed.
Otherwise, it could be that the unit has a faulty seal in the pressure vessel that isn't allowing the expresso side to function properly, hence the reason the water might be coming out of the frothing tube instead of through the expresso brewing section.
http://www.krupsusa.com/NR/rdonlyres/C308FB44-1EC6-4119-A060-C73BD65F4789/7355/XP2070espresso.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups K2 XP402040 Expresso maker. This makes the
Would you like to try not put too much coffee powder, and not make the coffee powder too firm ( I mean not press them too heavy.)
Or, not grind the coffee powder too thin....
Hope it helps you.
Oct 30, 2009 | Krups Coffee Makers & Espresso Machines
Missing milk frothing tube
should be listed in the owners manual with a part number
Aug 14, 2009 | Coffee Makers & Espresso Machines
I have a krups special edition. It looks like the xp 1020 edition. I don't have the instruction manual and would like to use it. This is an esspresso machine.
For the Steam Expresso machine you can go to; http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={706F793F-3236-4CA4-B5BA-C414DF982294}&SelectedProdRef=XP1020 and click on your machine for manual download.
Jun 05, 2009 | Krups Coffee Makers & Espresso Machines
Not frothing milk
that means that the steamer is not generating enough pressure steam.
This happens either because there is not enough heat, or if you release the steam when pressure is not enough.
Very common problem with the american maid makers.
bear also in mind that Krups are not the best at frothing milk, and this is also a basic model.
If you want the best capuccino Coffee machine, buy the italian ones, Gaggia, Delonghi, Ariete etc. that are all great at this, or get a bigger Krups as a replacement like the Krups XP405040 that is also good at capuccino
May 09, 2009 | Krups XP7225 Espresso Machine
My Krups XP4050 frother heats and makes bubbles but no froth
It doesn't froth because the air hole in the frother has become plugged with dried milk (cream). There are two types of frother - old one was a black rubber nipple with a stainless 2-3inch air tube rising above the milk. The plastic insert has a pin hole (really about the size of a straight pin!) that clogs. Use a sewing needle or straight pin to clear it.
Apr 01, 2009 | Krups XP 4050 Espresso Machine
Milk froths at 1st then doesn't after 1 week
Ensure first that you are using the steam pipe in the correct way to froth the milk.
If it still does not work, that means that the steamer is not generating enough pressure steam.
If you think you are doing everything in the right way, then contact the company and insist for having the machine fixed or replaced.
Nov 07, 2008 | Krups XP 1500 Espresso Machine & Coffee...
Krups XP4030 Espresso Machine Logo
613 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
