Question about Logitech Cordless Desktop Wave Keyboard and Mouse
CAPS LOCK WONT GO OFF AND WINDOWS RESTART ISSUES
NEW WIRLESS KEYBOARD CAUSES PROBLEMS WHEN RESTARTING WINDOWS AND NOW I CANT GET THE CAPS LOCK TO GO OFF
    Sergeant:
    Champion:
  • 245 Answers
Uninstall software with ADD/REMOVE and reinstall it again.....with ur installation cd u have and follow the promps
Posted on Apr 19, 2009
What is wrong with my laptop? It is as if the shift key is stuck
Go into device manager in windows and delete it and reboot. If it comes back when it detects the keyboard and it works then it was a driver, if it does detect it or it wont work correctly then it is a bad keyboard. You can also try a plug in keyboard to see how it behaves, ps keyboards are not that expensive.
Oct 11, 2015 | Toshiba Computers & Internet
How do I get the caps lock light to turn on and off?
Unlock the Caps on Computers The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files. This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words. When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function. Open a word processing program. Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document. If lower case letters appear in the document, Caps are successfully unlocked. Proceed if the text is in All-Caps. Hold down "Shift" on the keyboard. Press the letter "P." A lower case "p" appears in the document. Release the "Shift" button. Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T." Press "Enter" on the keyboard. The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off. Restart the computer to save the setting.
Enable the Caps Lock Key The "Caps Lock" key is loved by some and disliked by others. The key turns all letters into capitals as you type. While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized. The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock." If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key. If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels. Updating the registry for the keyboard will enable the "Caps Lock" key. Open the Notepad program. Type the following: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout] "Scancode Map"=- Select "Save As" from the "File" drop down menu. Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window. Type "enable.reg" without quotes in the "File name:" field and click "Save." Minimize all open windows to view the desktop. Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled. b> Manually Update the Registry b> Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor. Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings. Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
b> b> b> Disable the Caps Lock Key in Windows Your computer's Caps Lock key has likely only collected dust since you first brought the machine home. The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often. Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
Restart your computer before beginning the process of disabling your Caps Lock key. Download the registry file necessary to disable your Caps Lock key. You have the option to disable your Caps Lock key or change the key to a number of different keystrokes. For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key. Double-click the registry file you have downloaded. A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry. Select "Yes" to install the registry file. Restart your computer, once again, to complete the registry change. Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key.
Feb 04, 2013 | ASUS R503u-rh21
CAP LIGHT DOES NOT COME ON
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key. Hope this helps
Jan 21, 2013 | Acer Computers & Internet
How to tell if caps lock is on
Some keyboards will have a light that goes on when caps lock is turned on
Type the following:
"Scancode Map"=-
Hope this helps
Nov 05, 2012 | Computers & Internet
Please help. i have a Packard Bell Easynote TJ74-RB-050 and the keyboard isn't working at all. im having to use the onscreen one which takes forever. i dont think the keyboard has got wet. it was...
It can happen for many things.
First if the keyboard become wet by water or other liquid then it happens.
2nd if the keyboard cable leakage from inside.
3rd if the keyboard circuit become fault or short circuit.
Solution under the here
1st, unplug your keyboard cable and then check your cable holder pin "if your keyboard is PS2 system" other wise no need. after unplug then plug your cable and restart your computer.
2nd, if your keyboard become wet then open it from back side and need to dry it just sunlight. after doing that please fitting your key board carefully.
3rd if your keyboard circuit become fault then you can wash it by thinner and then heat it by hot air gun.
other wise you need to a new keyboard. thanks
Apr 17, 2011 | Packard Bell Computers & Internet
The CAPS LOCK key does not light up any more!
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
or if this does not fix the problem
Click start control panel keyboard you can change your settings there
or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers
click start control panel keyboard hardware then properties you hould see driver details and have options to,update driver,roll back driver,uninstall
if your computer came with a motherboard disc the drivers could be on it
diconnect the keyboard then reconnect it then reinstall the driver
make sure the lead has a secure seating if applicable or the usb device
hope this helps
Apr 02, 2011 | Lenovo Computers & Internet
Dell Keyboar Problem -
This likely is one of two issues. A BIOS setting, and can be changed in the BIOS setup utility accessible at startup.
Or ...
If you are sure you have no computer virus or a hardware conflict than you can modify this setting by editing the registry on the computer. Normally, the computer applies the user settings when the user logs on, but it uses the default user profile when it is first turned on, before the user has logged on. To turn this functionality off, the default user settings must be modified. The Keyboard entry contains user preferences as defined by choosing the Keyboard icon in Control Panel. Entries are found under this registry path:
HKEY_USERS\.DEFAULT\Control Panel\Keyboard
InitialKeyboardIndicators REG_SZ Number set it default to 0.
If not:
* Run the Registry Editor (REGEDIT.EXE).
* Open HKEY_CURRENT_USER\Control Panel\Keyboard (If the Keyboard key isn't there, add it.)
* Double-click the InitialKeyboardIndicators value on the right. (If it's not there, select New from the Edit menu, then String Value, and type InitialKeyboardIndicators for the name of the new value.)
* Change the value to any of the following:
0 - all indicators off
1 - Caps Lock on
2 - Num Lock on
4 - Scroll Lock on
Or, combine them by adding the corresponding values:
3 - Caps Lock and Num Lock on
5 - Caps Lock and Scroll Lock on
6 - Num Lock and Scroll Lock on
7 - Caps Lock, Num Lock, and Scroll Lock on
* Close the Registry Editor when you're done.
All the change should take effect when next time you start Windows.
Aug 28, 2009 | Dell 0Y3740 Keyboard
I have installed a new lid on my acer aspire 3050. during the install of the wirless antenas I had to remove the keyboard. Unfortunately after re installing the keyboard etc I have now discovered a number...
reseat the keyboard connection. This happens when its only making slight connections. Some laptops can be pretty tricky, especially if the ribbon cable is a bit short on the keyboard. If this helps please rate my solution.
May 10, 2009 | Acer NSK8458AN Keyboard
Cap Lock on or off
Your EX 110 receiver has 3 indicator lights (LEDs) that display the status of the Caps lock, Function key, and the Num lock during normal operating mode. These lights will also flash when the connect button on the receiver is pressed.
LED A: Indicates that the Caps Lock (Capital lock) key is on when lit.
LED F: Indicates that the F keys are in Standard F Keys Mode when lit and in Enhanced F Keys Mode when the LED is off.
  • Your EX 110 keyboard has an Enhanced F Keys Mode for F keys that provides additional functions you can program. See Knowledge Base article 9526.
LED 1: Indicates when the Num Lock (Number lock) key is on. This function allows the number pad to produce only numbers
Feb 11, 2009 | Logitech Cordless Desktop EX110
Lazy finger causing keyboard to lock in all caps??
Does it happen with everything you type or just in particular programs? If it happens in Microsoft word 2003 highlight the area where the all caps is happening then go to Format, Font. Under the Font tab there is a section called Effects, in this section there is an All caps option, uncheck it.
If it types all caps everywhere there could be a short in your keyboard. You can solve this by taking your keyboard apart using a multimeter to find the short and reconnecting with solder or electrical tape. Getting a new keyboard or talking to tech support can also help.
Dec 08, 2008 | HP D8597A Keyboard
Logitech Cordless Desktop Wave Keyboard and Mouse Logo
215 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
